Tip for translators
Tip for translators julien 12 Feb 06:51
  Tip for translators Axel Wernicke 12 Feb 07:08
julien
2008-02-12 06:51:36 UTC (about 17 years ago)
Tip for translators
A lot of changes are brought to update GIMP Help to v2.4. Doc writers add TODO comments on every changed or added item.
Here is a tip that can be useful to some translators: Being in the trunk/ repertory, the command find src/ -name '*.xml' | xargs grep -E 'TODO.*fr >todo.txt gives you a todo.txt file containing all TODO's for the 'fr' language.
'from' in a TODO comment will give an entry for 'fr', but this is rare and not a problem.
Under Cygwin: find src *.xml | xargs grep -E 'TODO.*fr' >todo.txt works.
Of course, replace 'fr' by your language id.
Julien
Axel Wernicke
2008-02-12 07:08:46 UTC (about 17 years ago)
Tip for translators
Hi, Julien,
great tip! Just to add what everybody knows probably anyways: There are other tags like
- - FIXME (more severe than TODO)
- - PENDING (mostly for links to pages that are not translated yet) and CHECK (less severe than TODO, more a reminder to have a look at it later again )
Greetings, lexA
Am 12.02.2008 um 06:51 schrieb julien:
Julien
