documentation of the clipping options
18 of 18 messages available
documentation of the clipping options Axel Wernicke 01 Feb 23:22
  documentation of the clipping options: no answer julien 05 Feb 06:40
   documentation of the clipping options: no answer Sven Neumann 05 Feb 08:15
    documentation of the clipping options: no answer julien 05 Feb 09:35
     documentation of the clipping options: no answer Roman Joost 05 Feb 10:28
     documentation of the clipping options: no answer Sven Neumann 05 Feb 20:09
   documentation of the clipping options: no answer Ulf-D. Ehlert 05 Feb 12:43
    documentation of the clipping options: no answer Axel Wernicke 05 Feb 20:12
    documentation of the clipping options: no answer Sven Neumann 05 Feb 20:20
     documentation of the clipping options: no answer Ulf-D. Ehlert 06 Feb 20:04
      documentation of the clipping options: no answer Sven Neumann 07 Feb 08:31
       documentation of the clipping options: no answer Ulf-D. Ehlert 07 Feb 21:33
  documentation of the clipping options Sven Neumann 05 Feb 08:18
   documentation of the clipping options Alessandro Falappa 05 Feb 12:24
   documentation of the clipping options Axel Wernicke 09 Feb 15:28
    documentation of the clipping options Sven Neumann 09 Feb 20:16
     documentation of the clipping options Axel Wernicke 09 Feb 22:05
      documentation of the clipping options Sven Neumann 09 Feb 22:27
Axel Wernicke
2008-02-01 23:22:13 UTC (about 17 years ago)
Hi list,
I just tried to enhance the general options for transform tools (see http://docs.gimp.org/en/gimp-tools-transform.html#gimp-tool-transform) .
Unfortunately I don't get what "crop to result" and "crop with aspect" actually do. Can somebody explain that to me on the list please?
Thanks a lot,
lexA
- --- Live is like a chocolate box, you never know what you wanna get... GPG Signatur auf http://wernicke-online.net/Impressum/ pr?fen
-----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.8 (Darwin)
iD8DBQFHo5uVR9mXLVsAbiQRAi9XAKDxkb/gvqI+OfDQ5hXl5LLXitP6hwCfcei9 8I57fhEbCG9QkAWBKnhh62Y=
=vhPL
-----END PGP SIGNATURE-----
julien
2008-02-05 06:40:01 UTC (about 17 years ago)
Your question got no answer.
That's a problem I have met since I have started writing help. Most often, experimenting, reading books, reviews, gimp forums, bugzilla, I can write explanations. And if I am wrong, others will correct.
There still remain some features, especially new functions, that I can't explain.
I can't read C code.
That's why I think that developers should write some explanations about the new features they add to GIMP. This list seems to be the right place for that.
If we can't get help from developers, I am afraid that some FIXME will persist
for ever.
Julien
2008-02-05 08:15:50 UTC (about 17 years ago)
Which is not at all surprising since Axel asked on the gimp-docs mailing-list. Guys, when you need to get an answer from the developers, then please ask on the gimp-developer list or at least on the gimp-user list. Who are you trying to reach here? There is probably no developer but me subscribed to this list and I don't always have the time to answer.
2008-02-05 08:18:45 UTC (about 17 years ago)
The general idea is described here:
http://svenfoo.geekheim.de/index.php/2006-12-26/transform-and-crop/
Please let me know if you need more information.
julien
2008-02-05 09:35:47 UTC (about 17 years ago)
Are you sure?
We are NOT developers. You well know them: I am afraid that we will be severely rejected with our dummy questions. Is "Developers should give some explanations about their new functions for doc-writers" a bad idea?
Julien
Roman Joost
2008-02-05 10:28:58 UTC (about 17 years ago)
Are you sure?
I don't think it's a bad idea, but I also think we could use the developers or users mailinglist to ask questions about functions implemented in GIMP.
This list is intended to discuss documentation related topics anyways...
Greetings,
Alessandro Falappa
2008-02-05 12:24:23 UTC (about 17 years ago)
For your, and others, information the two relevant links to Mukund site in your post have moved.
This is the new one (that I think contains both): http://www.mukund.org/journal/2006-12.html
Greets
Ulf-D. Ehlert
2008-02-05 12:43:06 UTC (about 17 years ago)
julien (Dienstag, 5. Februar 2008, 06:40):
If you could, you would find out (that's my experience) that the code is not documented. Typically no comments about the underlying algorithm, no headers explaining what which functions is doing, no word about the function parameters, etc. etc. [1]
For the developer everything is clear when he is coding (so he could easily describe what happens within his code), but there's no chance for a documenter unless he wants to spend many hours with the source code (since, of course, the functions called by the relevant function and the functions using this relevant function are also not documented...).
Ulf
[1] See e.g. "gimp_transform_resize_crop()" -------------- next part -------------- A non-text attachment was scrubbed... Name: not available
Desc: not available
Url : /lists/gimp-docs/attachments/20080205/4680b1fb/attachment.bin
2008-02-05 20:09:11 UTC (about 17 years ago)
Not at all. It is a good idea. That's why you are encouraged to ask the developers to explain the features so that you can document them. But you are not going to reach the developers here. Please ask such questions on the gimp-user list. Enough developers are subscribed there.
Axel Wernicke
2008-02-05 20:12:38 UTC (about 17 years ago)
Sven is probably right - I should not have asked this on the docs list. I just thought one of the documenters would be able to anser it. Btw. Recently I asked a CM related question on the user-list and got a RTFM as answer - kind of funny, if one considers that I was just asking because of the lack on information in the manual.
Anyways - I'll ask such things on the developers list the in the future.
Greetings, lexA
P.S: Thanks sven, I'll use your links to find the answer to my questions as soon as I'm back from my business trip on friday.
2008-02-05 20:20:22 UTC (about 17 years ago)
You are not supposed to read the source code to find out what is going on. What a waste of time. If something is not obvious, please ask.
From a developer point of view it is actually a lot more important to
write well-structured code with self-explaining function and variable names than to add comments. But if you want to discuss coding style, then we should really move this discussion to the gimp-developer list.
Ulf-D. Ehlert
2008-02-06 20:04:47 UTC (about 17 years ago)
Sven Neumann (Dienstag, 5. Februar 2008, 20:20):
Exactly!
BTW, everything may be considered to be a waste of time, even developing GIMP. ;-) Remember, we use computers to solve problems we wouldn't have without computers...
From a developer point of view it is actually a lot more important to write well-structured code with self-explaining function and variable names than to add comments.
Useful function and variable names are of course essential, but not sufficient. And there are many variables with self-explaining names, but also many without.
Yet another pointless discussion (waste of time, hmm ;-) )? Better just agree with me that we disagree... :-)
Ulf
Desc: not available
Url : /lists/gimp-docs/attachments/20080206/82967f83/attachment.bin
2008-02-07 08:31:36 UTC (about 17 years ago)
Feel free to send patches to improve this.
Ulf-D. Ehlert
2008-02-07 21:33:16 UTC (about 17 years ago)
Sven Neumann (Donnerstag, 7. Februar 2008, 08:31):
This is a nice catch-22.
Ulf
Axel Wernicke
2008-02-09 15:28:09 UTC (about 17 years ago)
Am 05.02.2008 um 08:18 schrieb Sven Neumann:
Thanks for the link. I think I now understand what this option is supposed to do. Assuming there is an one layer image, rotated by 45? with clipping set to "with adjust", there will be a layer with some transparent edges.
Now lets set clipping to "Crop to result" and rotate the layer with - -45?. What I would expect ist, that the in the result the layer/image would be cropped to the original size - meaning that the transparent border will be removed.
What happens instead is, that the layer size is reduced to 1x1 pixel! (GIMP 2.4.4 at Mac OS X)
Anything I could have done wrong here?
lexA
Remember: There are only two tools in life. WD-40, for when something doesn't move, and should, and Duct Tape, for when something is moving and it shouldn't.
So does the universe explode if you spray duct tape with WD-40?
iD8DBQFHrbh5R9mXLVsAbiQRAtK7AKDCn7mxxKgw4axvQnBHCr4D5WsgbwCguINO OOYYhK+uZFgIT26NYtp8Yzo=
=ju0h
2008-02-09 20:16:35 UTC (about 17 years ago)
Well, it's more targetted at small adjustments as you typically need to do to correct for a slightly tilted camera.
You have run into bug #472644.
Axel Wernicke
2008-02-09 22:05:39 UTC (about 17 years ago)
Am 09.02.2008 um 20:16 schrieb Sven Neumann:
OK, that makes sense. Unfortunately this bug is not exactly new. What do you think, might it make sense to put a note about the malfunction as note into the manual?
Greetings,
lexA
iD8DBQFHrhWjR9mXLVsAbiQRAtZMAKDYVZW14f/eUoytFz2GrJVqrPgfewCg18Bg hhs82nR/XgyPwH/DzqBMpKk=
=uR+U
2008-02-09 22:27:48 UTC (about 17 years ago)
Of course I hope that it is going to be fixed at some point. But it would certainly make sense to notify the user that the algorithm works nicely for small transformations but that is has issues when it is applied on, for example, a rotation by 45 degrees.
