zh_CN translation of src/toolbox/tool-align.xml
zh_CN translation of src/toolbox/tool-align.xml crquan at gmail.com 21 Nov 19:29
crquan at gmail.com
2007-11-21 19:29:48 UTC (over 17 years ago)
zh_CN translation of src/toolbox/tool-align.xml added, please someone could verify.
I learned there need Chinese gimp docs translators from: http://wiki.gimp.org/gimp/GimpDocsOpenTasks
I want to apply for this, and have started working on this, I'll send my `svn diff` later on,
to caiqian and wangtao: if you still have time and interest on this, we can work together.
?????????gimp-2.2??????????gimp-2.4??????? ?????????????????????????????????????????
On Nov 21, 2007 12:33 PM, wtchuanhua wrote:
Sorry????????????????????????????????? ?????????????~
Well. However, I hope you could give comments on my following translation patch:
I'm just a GIMP newbie, and translating is not my job, so some terms in Chinese is not very perfect, I hope you could give comments. I will send my following translating patches CC to you and the mailling list.
??????????????????????????????????? ??GIMP??????????????????????????????? ?????????????????????????????????
Index: src/toolbox/tool-align.xml =================================================================== --- src/toolbox/tool-align.xml (revision 2189) +++ src/toolbox/tool-align.xml (working copy) @@ -13,7 +13,7 @@
2007-08-14 ciampix: align tool stub page created -->
+ lang="en;de;es;fr;it;no;pl;ru;zh_CN">
@@ -51,6 +51,11 @@
2007-xx-xx
n.n.
+ $Revision$
+ 2007-11-21
+ cheng
@@ -63,6 +68,7 @@
Innrettingsverkt?yet
Wyr?wnanie
Align
@@ -104,6 +110,10 @@
@@ -120,10 +130,11 @@
Innrettingsverkt?yet i verkt?ykassa Wyr?wnanie na pasku narz?dzi
@@ -238,6 +249,16 @@
+ ????????????????(??Shift
@@ -264,6 +285,7 @@
Du kan aktivere dette verkt?yet p? fleire m?tar: Wyr?wnanie mo?na aktywowa? na kilka sposob?w: ?????????? ????? ??????? ??????????? ????????? : + ??????????????????
@@ -333,6 +355,14 @@
+ T??
+ T????
+ A??
@@ -447,6 +477,16 @@
@@ -471,12 +511,15 @@
??? ? ??????? ??????? ???????? ??????? Q.
+ ????Q??????
Key modifiers (Defaults)
Modifika?n? kl?vesy (v?choz?) @@ -533,10 +576,13 @@
????? ??????? ????? ?????, ????? ??????? Shift ??? ??????? ?? ????.
+ ?????Shift????????????
Sometimes it's easier to choose multiple layers using rubber-banding: click somewhere outside an imaginary rectangular @@ -624,6 +670,15 @@
@@ -645,7 +700,7 @@
Align options
Werkzeugeinstellungen f?rs Ausrichten @@ -659,10 +714,11 @@
@@ -822,10 +878,21 @@
Align
Ausrichten
Alineado
@@ -834,12 +901,13 @@
Innrett
Wyr?wnanie
Relative to:
Relativ zu:
Relativo a:
@@ -848,6 +916,7 @@
Relativ til:
Odniesienie:
This is the target - the image object the selected layer @@ -878,6 +947,9 @@
@@ -931,6 +1003,10 @@
??????? Shift. ????? ????????? ??? ??? ?????????? ?????????.
+ ???????Shift???????????????? + ??????rubber-banding????????? +
@@ -962,6 +1038,9 @@
@@ -995,6 +1074,9 @@
@@ -1027,6 +1109,9 @@
@@ -1053,6 +1138,9 @@
@@ -1088,12 +1176,15 @@
Distribute
Verteilen
Distribuir
@@ -1189,6 +1285,7 @@
Fordel
Rozmieszczenie
Align using rubber-band box Ausrichten mit Gummiband
@@ -1702,6 +1837,7 @@
Innrett med gummistrikk
Wyr?wnanie przy pomocy techniki rubber-band ???????????? ??? ?????? ??????????? ????????? + ???????(rubber-band)????
@@ -1745,6 +1881,9 @@
@@ -1819,6 +1958,13 @@
Cheng
