Light and Shadow - Drop Shadow an Bevel
Light and Shadow - Drop Shadow an Bevel Ulf-D. Ehlert 30 Sep 20:48
  Light and Shadow - Drop Shadow an Bevel Sven Neumann 01 Oct 08:18
Ulf-D. Ehlert
2007-09-30 20:48:16 UTC (about 18 years ago)
did anybody ever use this filter? It should "add a drop shadow to a layer, and optionally bevel it", but it seems to do nothing useful.
According to the source code, this filter
1. creates a copy of the drawable, 2. fills it with white,
3. blurs this plain white layer (does this make sense?), 4. uses this plain white layer as a bump map (or this?), 5. inverts it.
The result is a black layer below the drawable, optionally moved by the Diplacement options (without resizing the image).
Do I miss something? How is this filter to be used?
Ulf
2007-10-01 08:18:16 UTC (about 18 years ago)
Doesn't seem to make any sense to me.
I have the impression that this Python script can serve as an example for scripting GIMP with Python but that seems to be about the only use that it has. We should probably not install it in a stable release then. Could you perhaps open a bug report for this issue so that we can sort it out quickly before the 2.4.0 release?
