Gimp-docs Digest, Vol 40, Issue 7
1 of 2 messages available
mailman.5.1190746809.31503.... 07 Oct 20:29
  Gimp-docs Digest, Vol 40, Issue 7 Vitaly Lomov 26 Sep 09:12
Vitaly Lomov
2007-09-26 09:12:56 UTC (over 17 years ago)
Basically, make sure that your language, lang="XX" goes from gimp.xml through all includes to the section you translated. Then your build will show your work.
So, for tools you would have lang="XX" in top of gimp.xml, around line 585 of gimp.xml (toolbox references), in toolbox/intro.xml, and so on.
Subject: [Gimp-docs] New gimp docs translation To: gimp-docs at lists.xcf.berkeley.edu Message-ID:
Content-Type: text/plain; charset=UTF-8
I'm in the progress of making a new gimp docs translation into Lithuanian. The question I have is whether it is possible to build the docs while having an unfinished translation? For example, I have some part of the tools translated and I want to check how does it look when built. Do I have to fully translate some section, is it sufficient to have some KEY sections translated, or do I have to finish it all (it's a HUGE work) at first?
?ygis
