gimp snapshots theme
Hi Marco,
On Wed, Aug 15, 2007 at 11:26:01PM +0200, Marco Ciampa wrote:
Since last dev version of gimp-2.3 (2.3.19) need at least gtk+2.10.13 or
greater to compile, I was forced to install on /usr/local a newer copy
of gtk+ libs to start gimp and to be able to do some action screenshots.
Yeh - same problem here :(
Since then I was forced to use the Default theme in my kubuntu feisty that
was a little bit different (lighter) from the one that I was currently
useing (so I have to redo the snapshots just sent in the last commit @#$%!).
No - you don't have to do that. The screenshots are a mix of different
themes anyways. One exception: the theme is so weird looking that users
come into trouble comparing their dialogs with the screenshots.
All this rised in my mind a question. Why not to use the same theme for
all the translations and, if not (why?), is possible to know which theme are
currently used in the different languages (and why?) by the different
laguage teams?
That didn't work in the past and I guess it won't work in the future.
The problem is to define what and which theme can be used as a standard.
Each distribution comes with different (default) themes...
Greetings,
