may be wrong part in gimp help
may be wrong part in gimp help Choi, Ji-Hui 14 Jul 04:14
  may be wrong part in gimp help julien 14 Jul 21:10
   may be wrong part in gimp help Choi, Ji-Hui 15 Jul 10:49
   may be wrong part in gimp help Axel Wernicke 15 Jul 12:05
   may be wrong part in gimp help Sven Neumann 16 Jul 17:41
Choi, Ji-Hui
2007-07-14 04:14:46 UTC (almost 18 years ago)
hi, all.
according to http://docs.gimp.org/en/gimp-concepts-shortcuts.html
"If you type a sequence which has already been used, the command which is associated with this shortcut will be executed and no new shortcut will be created."
but I can reassign every key. It doesn't matter whether the key sequence is already assigned or not. for example, the default shortcut of "select all" is CTRL+A, and I want to use this shortcut to "none select". according to manual, I can't assign CTRL+A for "none select", but I can. Am I wrong, or manual is wrong?
Greetings.
julien
2007-07-14 21:10:07 UTC (almost 18 years ago)
You are right. This sentence must be deleted. It was true when this file has been written...
Julien
Choi, Ji-Hui a ?crit :
hi, all.
Greetings.
Choi, Ji-Hui
2007-07-15 10:49:17 UTC (almost 18 years ago)
Thank you, Julien
Axel Wernicke
2007-07-15 12:05:43 UTC (almost 18 years ago)
So, I'll go and remove the for all languages...
Am 14.07.2007 um 21:10 schrieb julien:
Julien
hi, all.
Greetings.
2007-07-16 17:41:57 UTC (almost 18 years ago)
Sorry that I have to disagree but it has definitely never behaved that way.
