Tutorial
Tutorial Albin Bernhardsson 26 May 00:31
  Tutorial Choi, Ji-Hui 26 May 03:28
  Tutorial julien 26 May 07:20
Albin Bernhardsson
2007-05-26 00:31:02 UTC (almost 18 years ago)
Tutorial
Is there any guide or tutorial in step by step on how to translate the GIMP manual into another language / writing on the GIMP Manual? (using Windows XP) I'm kinda stupid so I don't now how to start.
__________________
Choi, Ji-Hui
2007-05-26 03:28:56 UTC (almost 18 years ago)
Tutorial
Hi. welcome.
I'm Dust, the korean writer, and I use windows XP.
If you want to translate Gimp-Help-2, please see this page. http://wiki.gimp.org/gimp/TipsForContributing
and after translate some pages, debug and make patch file, and send your patch file to this mailing. then someone who have permission, apply your works.
and if you're using on Windows XP, these may help you.
http://docs.gimp.org/Layout/sandboxWindows.swf (buy we move from cvs to svn, so you have to install "subversion" on cygwin)
and don't skip this step. insert the line on /cygwin/etc/xml/catalog you can find more on
Good luck.
Greetings.
julien
2007-05-26 07:20:34 UTC (almost 18 years ago)
Tutorial
I can help you personnaly to start., as I did for several other newbies. You can contact me directly if you want.
Julien
