? ???, 20/05/2007 ? 16:41 +0900, Kevin Connor Arpe ?????:
Hello Kevin. Let me try to answer
This is my first posting, so many apologies if I am breaking any
informal rules.
The help for the Load Postscript dialog could use some work.  I, for
one, am a little confused.  And, I would like to contribute!
You are welcome!
To do this, I need some help for this list.
1. How do I find the author of this dialog?  I would to get some quick
thoughts on the available features.  I'll work this into some readable
help text.
Do you mean the author of dialog itself or it's docs?
Anyhow I suppose it should be rather hard. You can try to search the
ChangeLog and commit list and look at the contributors
http://svn.gnome.org/viewcvs/gimp/trunk/plug-ins/common/postscript.c?view=log
I suppose it will be easier just to ask question here or on gimp list.
Let's hope Sven will clear some trouble too.
2. When I write something, shall I contribute a "patch" to the regular
bug list?  I'm not 100% on this part.  As I understand GNU projects,
most of the time small, linear, non-complicated patches are best just
mailed whole and have the file manager patch manually.
Well, small patches are better of course. You can send them here for
example or attach to the bugzilla. We have a component GIMP-manual on
http://bugzilla.gnome.org
3. I already have my GNU Free Docs license on file with GNU
headquarters in Cambridge.  Can I assume this is good enough to
contribute to this proj
It's not required. I hope we aren't that bureaucratic like GNU guys.
-------------- next part --------------
A non-text attachment was scrubbed...
Name: not available
Desc: =?koi8-r?Q?=FC=D4=C1?= =?koi8-r?Q?_=DE=C1=D3=D4=D8?=
	=?koi8-r?Q?_=D3=CF=CF=C2=DD=C5=CE=C9=D1?=
	=?koi8-r?Q?_=D0=CF=C4=D0=C9=D3=C1=CE=C1?=
	=?koi8-r?Q?_=C3=C9=C6=D2=CF=D7=CF=CA?=
	=?koi8-r?Q?_=D0=CF=C4=D0=C9=D3=D8=C0?=
Url : /lists/gimp-docs/attachments/20070520/48a3706c/attachment.bin
