Fwd: comment in src/using/fileformats.xml
1 of 2 messages available
Fwd: comment in src/using/fileformats.xml Axel Wernicke 01 May 21:10
0BB6CF5C-852E-48B0-A54A-60A... 07 Oct 20:29
Axel Wernicke
2007-05-01 21:10:40 UTC (almost 18 years ago)
sorry folks, forgot to set you in CC:
Anfang der weitergeleiteten E-Mail:
Von: Axel Wernicke
Datum: 1. Mai 2007 07:59:03 GMT-04:00 An: Marco Ciampa
Betreff: Re: [Gimp-docs] comment in src/using/fileformats.xml
Hi list,
Am 01.05.2007 um 06:42 schrieb Marco Ciampa:
This comment present in src/using/fileformats.xml:
I think this is pretty much useless. The URL contains always the id of the file and a simple grep then can find you the associated file in the blink of an eye. Furthermore very often the id leads you to the file directly.
In this case the url reads as
file:///Users/axelwernicke/Documents/Projekte/gimp-help-2/html/en/ gimp-images-out.html#gimp-using-fileformats
so the ID is gimp-using-fileformats and surprisingly easy the file is located at src/using/fileformats.xml
is really necessary?
IMHO no.
Couldn't be avoided with a simple recursive string grep on src dir?
[x]
Greetings, lexA
