Mouse pointer icons
Mouse pointer icons julien 07 Feb 08:40
  Mouse pointer icons Sven Neumann 07 Feb 08:58
   Mouse pointer icons julien 07 Feb 18:41
    Mouse pointer icons Sven Neumann 08 Feb 07:52
julien
2007-02-07 08:40:47 UTC (about 18 years ago)
Mouse pointer icons
Where are the mouse pointer icons used in GIMP? I can't find them.
Julien
2007-02-07 08:58:25 UTC (about 18 years ago)
Mouse pointer icons
What exactly are you looking for? The cursors are compiled into GIMP. What kind of data or information do you need and for what purpose?
julien
2007-02-07 18:41:00 UTC (about 18 years ago)
Mouse pointer icons
For instance, the mouse cursor turns to a hand with the forefinger pointing upwards. I want to put this image in the Help, but I can't capture it and I can't find it among GIMP's files. Where this icon is?
Sven Neumann a ?crit :
2007-02-08 07:52:21 UTC (about 18 years ago)
Mouse pointer icons
That's a system cursor, it doesn't come with GIMP. These cursors can look rather different depending on what platform you are on and what cursor theme people are using. I don't know if it makes sense to include them in the user manual.
