autoindex-ng
8 of 8 messages available
autoindex-ng Roman Joost 29 Nov 15:24
  autoindex-ng Sven Neumann 29 Nov 15:38
   autoindex-ng Nickolay V. Shmyrev 29 Nov 16:59
    autoindex-ng Sven Neumann 29 Nov 17:30
     autoindex-ng Nickolay V. Shmyrev 29 Nov 17:50
      autoindex-ng Roman Joost 29 Nov 18:08
       autoindex-ng Nickolay V. Shmyrev 29 Nov 18:32
        autoindex-ng Roman Joost 30 Nov 08:50
Roman Joost
2006-11-29 15:24:30 UTC (over 18 years ago)
autoindex-ng
Hi folks,
I'm not able to compile the HTML files anymore with the autoindex-ng stylesheet. Is there anyone who needs this type of indexing or simple: does anyone have trouble creating HTML files so far?
Greetings,
2006-11-29 15:38:02 UTC (over 18 years ago)
autoindex-ng
Why has the change to autoindex-ng been made in the first place?
Nickolay V. Shmyrev
2006-11-29 16:59:37 UTC (over 18 years ago)
autoindex-ng
Sorry for this kind of troubles. Without autoidx-ng docbook-xsl stylesheets generate rather bad index for non-english languages. For example it doesn't recognize some iso8859-1 letters for french, puts everything into single Symbols category for Russian and Korean.
Autoidx-ng is supposed to solve this problem. Unfortunately, it doesn't work well with xsltproc. It takes too much memory for English and with new docbook-xsl it even denies xsltproc as xslt processor.
I see several options here:
1. Return back to autoidx. Will work but our index will be not perfect.
2. Copy-paste autoidx-ng in our stylesheets and correct it to take less memory and accept xsltproc. Not so good solution I suppose.
3. Fix xsltproc. That will require some time but I can try to do this work. Although I can say how soon this changes will be applied.
2006-11-29 17:30:45 UTC (over 18 years ago)
autoindex-ng
Until this is fixed, autoindex-ng shouldn't be used by default. Instead it should be made an option at configure time so that people like you can play with it but the rest of the team can continue their work.
Nickolay V. Shmyrev
2006-11-29 17:50:38 UTC (over 18 years ago)
autoindex-ng
I see. Is it ok to apply the attached patch then? -------------- next part -------------- A non-text attachment was scrubbed... Name: patch.diff
Type: application/octet-stream
Desc: not available
Url : /lists/gimp-docs/attachments/20061129/42a72c4e/attachment.obj
Roman Joost
2006-11-29 18:08:21 UTC (over 18 years ago)
autoindex-ng
Hi Nickolay,
Can you checkin your patch
for yourself? I'm just curious :)
Greetings,
Nickolay V. Shmyrev
2006-11-29 18:32:19 UTC (over 18 years ago)
autoindex-ng
Hi Nickolay,
Greetings,
I'm just pasting to let you know :) Patch is committed, sorry for troubles.
I'll try to look at xsltproc issue if there will be more time. Hopefully with new libxslt we'll be able to move to autoidx-ng.
Roman Joost
2006-11-30 08:50:30 UTC (over 18 years ago)
autoindex-ng
Greetings,
Thanks a bunch!
Greetings,
