revision tag
8 of 8 messages available
revision tag Manuel Quiñones 23 Nov 06:08
  revision tag Roman Joost 23 Nov 09:58
   revision tag Marco Ciampa 23 Nov 11:58
    revision tag Nickolay V. Shmyrev 24 Nov 07:51
     revision tag Sven Neumann 24 Nov 10:28
      revision tag Nickolay V. Shmyrev 28 Nov 03:08
       revision tag Roman Joost 28 Nov 08:35
     revision tag Sven Neumann 24 Nov 11:13
Manuel Quiñones
2006-11-23 06:08:45 UTC (over 18 years ago)
revision tag
Hello.
I've been contributing with Spanish content for a while, so this question may sound very dumb: what should I do with the revnumber in the revision tag? Should I increase it manually or what? This generates conflicts with my local copy every time I send a patch.
I've found this in the archive:
http://archives.free.net.ph/message/20060311.101522.26dab6d2.en.html
Should I leave it as $revision:$ ?
manuel -------------- next part -------------- An HTML attachment was scrubbed...
URL: /lists/gimp-docs/attachments/20061123/da43b83c/attachment.html
Roman Joost
2006-11-23 09:58:42 UTC (over 18 years ago)
revision tag
Yes - leave it as $revision$. It is replaced by the actual revision number by the CVS.
Greetings,
Marco Ciampa
2006-11-23 11:58:08 UTC (over 18 years ago)
revision tag
Dumber + dumb: would you please indicate me where I can find info about this way of handling revisions? I do not understand (I perhaps missed some msgs of revisions explanation) the meaning, how I can use them and how to produce HTML without such messages in the way...
TIA
Nickolay V. Shmyrev
2006-11-24 07:51:28 UTC (over 18 years ago)
revision tag
? ???, 23/11/2006 ? 11:58 +0100, Marco Ciampa ?????:
TIA
Well, probably you can extract some info from
http://www.eyrie.org/~eagle/notes/cvs/file-headers.html
Sometimes it's not used correctly! For example in gimp-new-layer-dialog.xml
$Revision$
I've just filed bug about it:
http://bugzilla.gnome.org/show_bug.cgi?id=378738
To avoid CVS conflicts you can just manually remote chunks from patches with revision or use "cvs diff" and "cvs update" to generate patches against latest revision.
-------------- next part -------------- A non-text attachment was scrubbed... Name: not available
Desc: =?koi8-r?Q?=FC=D4=C1?= =?koi8-r?Q?_=DE=C1=D3=D4=D8?= =?koi8-r?Q?_=D3=CF=CF=C2=DD=C5=CE=C9=D1?= =?koi8-r?Q?_=D0=CF=C4=D0=C9=D3=C1=CE=C1?= =?koi8-r?Q?_=C3=C9=C6=D2=CF=D7=CF=CA?= =?koi8-r?Q?_=D0=CF=C4=D0=C9=D3=D8=C0?= Url : /lists/gimp-docs/attachments/20061124/d11dcc3d/attachment.bin
2006-11-24 10:28:22 UTC (over 18 years ago)
revision tag
$Revision$
That's not quite right. You should use either $Revision$ or $Revision:...$ (with the dots replaced by the actual revision number). Thus, if you start a new file, just use $Revision$ and CVS (or actually RCS) will do the substitution to the second form and will take care of updating the version then.
http://www.stud.uni-hannover.de/stud/serv/cvsdoc/cvs_17.html
Note that the case is important. $revision$ won't work, but $Revision$ is correct.
2006-11-24 11:13:04 UTC (over 18 years ago)
revision tag
You can use the -kk option with 'cvs diff' to suppress keyword substitution. Differences that only depend on keyword substitution are then ignored.
Nickolay V. Shmyrev
2006-11-28 03:08:23 UTC (over 18 years ago)
revision tag
? ???, 24/11/2006 ? 10:28 +0100, Sven Neumann ?????:
$Revision$
Yes, I am wrong here, sorry for misleading whole list :) Nobody can know everything in particular about cvs admin flags.
Anyhow, this problem should be solved now, so thanks a lot.
Desc: =?koi8-r?Q?=FC=D4=C1?= =?koi8-r?Q?_=DE=C1=D3=D4=D8?= =?koi8-r?Q?_=D3=CF=CF=C2=DD=C5=CE=C9=D1?= =?koi8-r?Q?_=D0=CF=C4=D0=C9=D3=C1=CE=C1?= =?koi8-r?Q?_=C3=C9=C6=D2=CF=D7=CF=CA?= =?koi8-r?Q?_=D0=CF=C4=D0=C9=D3=D8=C0?= Url : /lists/gimp-docs/attachments/20061128/e2895f86/attachment.bin
Roman Joost
2006-11-28 08:35:38 UTC (over 18 years ago)
revision tag
On Tue, Nov 28, 2006 at 05:08:23AM +0300, Nickolay V. Shmyrev wrote:
?? ??????, 24/11/2006 ?? 10:28 +0100, Sven Neumann ??????????:
Nevermind :)
I'm still not convinced if this problem is solved. If you still find files with the sticky option, please reset the options :)
Thanks and Greetings,
