FYI: checkin messages
11 of 12 messages available
FYI: checkin messages Roman Joost 19 Sep 23:52
  FYI: checkin messages Axel Wernicke 20 Sep 01:05
   FYI: checkin messages Roman Joost 20 Sep 02:21
    FYI: checkin messages Marco Ciampa 20 Sep 02:42
     FYI: checkin messages Roman Joost 20 Sep 04:31
    FYI: checkin messages Axel Wernicke 20 Sep 04:04
     FYI: checkin messages Roman Joost 20 Sep 04:32
      FYI: checkin messages Michael Schumacher 20 Sep 05:22
20060920134225.22840@gmx.net 07 Oct 20:29
  FYI: checkin messages Roman Joost 21 Sep 00:27
   FYI: checkin messages Marco Ciampa 21 Sep 03:06
    FYI: checkin messages Roman Joost 21 Sep 04:14
Roman Joost
2006-09-19 23:52:33 UTC (about 19 years ago)
Hi folks,
small thing: some of you don't use the ChangeLog entry for the commit message. I just made a `cvs log ` accidently and saw, that the log only includes the ChangeLog entry sporadically.
A small example (gimp.xml):
(wrong) revision 1.163
date: 2006/06/24 20:46:08; author: marcoc; state: Exp; lines: +3 -3 Added italian content and fixed some errors
(correct)
revision 1.161
date: 2006/06/21 21:52:33; author: nshmyrev; state: Exp; lines: +2 -2 2006-06-22 Nickolay V. Shmyrev
* src/dialogs/brushes-dialog.xml: * src/dialogs/dialogs-content.xml: * src/gimp.xml: added russian content.
So, please use for each CVS commit your ChangeLog entry :)
Thanks,
Axel Wernicke
2006-09-20 01:05:50 UTC (about 19 years ago)
Hi Roman,
so you are talking about the Changlog commits only right? The commit message for all the other files describes the changes in that particular file, not the message for the batch commit at all?!
Greetings, lexA
-------- Original-Nachricht -------- Datum: Wed, 20 Sep 2006 08:52:23 +0200 Von: Roman Joost
An: GIMP Docs
Betreff: [Gimp-docs] FYI: checkin messages
Hi folks,
(correct)
revision 1.161
Thanks,
Roman Joost
2006-09-20 02:21:15 UTC (about 19 years ago)
No - I mean the whole commit (the batch in your words) not only the ChangeLog. The ChangeLog entry should tell what you have changed on the files.
Greetings :)
Marco Ciampa
2006-09-20 02:42:02 UTC (about 19 years ago)
Perhaps you can help me to understand the problem. Sorry I'm not a cvs expert but I do want to continue to use cvs correcting my mistakes instead of rely on someone for the commits (I can probably then be able to help someonelse on similars cvs errors).
Lets try do reproduce the problem. I usually do:
1) update local repo: cvs up 2) do some modifications on files: emacs src/gimp.xml 3) update Changelog: emacs Changelog 4) commit: cvs commit -m "Updated XX translation"
What is wrong?
TIA
Axel Wernicke
2006-09-20 04:04:13 UTC (about 19 years ago)
Hi Roman,
sorry I don't get it. The way I set the commit message to date is:
a.xml -> added german translation b.xml -> added german translation
Changelog -> 2006-09-10 lexA:
* a.xml
* b.xml: added german translation
Shouldn't it be this way?
greetings, lexA
-------- Original-Nachricht -------- Datum: Wed, 20 Sep 2006 11:21:02 +0200 Von: Roman Joost
An: gimp-docs@lists.XCF.Berkeley.EDU Betreff: Re: [Gimp-docs] FYI: checkin messages
Greetings :)
Roman Joost
2006-09-20 04:31:46 UTC (about 19 years ago)
What is wrong?
Point 4. Use your Changelog entry for the commit message. You may also want to have a look at one of the files (e.g cvs log gimp.xml)
Greetings,
Roman Joost
2006-09-20 04:32:29 UTC (about 19 years ago)
On Wed, Sep 20, 2006 at 01:03:53PM +0200, Axel Wernicke wrote:
Hi Roman,
* a.xml
Thats correct, but the problem isn't about the ChangeLog entry, it's about the commit message. Have a look a the reply to Marcos mail :)
Greetings,
2006-09-20 05:22:48 UTC (about 19 years ago)
Von: Roman Joost
Hi Roman,
Thus the commit messages for a.xml and b.xml in Axel's example are incorrect.
Roman Joost
2006-09-21 00:27:39 UTC (about 19 years ago)
What is wrong?
I do not have a Changelog entry at this point. The change log entry is generated from the log that is generated when commiting the files !?! It does not make sense to describe the changes in a.xml AND b.xml in the commit message from a.xml. Does it?
Hm.. no...
Let me try to explain it again.
You don't checkin every file which you have changed for itself. You check in all your changes together. To document what has changed, you create before you're checking in your changes a ChangeLog entry. After you created the ChangeLog entry, you checkin your changes.
At this point you can provide a message via the -m option or an editor pops up (at least thats the usual procedure I get). For this checkin message you use your last ChangeLog entry.
So, don't checkin every single file. Checkin all your changes and use the last ChangeLog entry for this.
Greetings,
Marco Ciampa
2006-09-21 03:06:31 UTC (about 19 years ago)
Many thanks for clarifying this point.
Just for the sake of curiosity: is it a gnu/gnome/? habit?
Roman Joost
2006-09-21 04:14:44 UTC (about 19 years ago)
Guess so - just learned it from Daniel Egger when I joined the project ;)
Greetings,
