FW: Layer mode Overlay - technical question
FW: Layer mode Overlay - technical question Sally C. Barry 05 Sep 05:56
FW: Layer mode Overlay - technical question William Skaggs 05 Sep 08:56
Sally C. Barry
2006-09-05 05:56:44 UTC (over 18 years ago)
Hello All!
I'm looking at the Layer Modes for the Glossary and one of my references is the C source code. I have a question about it which is mainly aimed at any technically-oriented people (developers) on the list.
In app/composite/composite-generic.c, the comments for the function gimp_composite_overlay_any_any_any_generic() say:
* Perform an RGB[A] overlay operation between the pixel sources * ctx->A and ctx->B, using the generalised algorithm: *
* D = A * (B + (2 * B) * (255 - A))
But the code does:
dest[b] = INT_MULT(src1[b], src1[b] + INT_MULT(2 * src2[b], 255 - src1[b], tmpM), tmp);
which looks to me like:
D = A * (A + (2 * B) * (255 - A))
Is this an error in the code, or simply an error in the comment, does anyone know?
Thank you!
Sally
William Skaggs
2006-09-05 08:56:24 UTC (over 18 years ago)
Well, it's certainly an error in something, but we haven't quite figured out how to handle it -- the problem is that straightforwardly fixing the mistake would change the appearance of existing xcf files, and we don't like to do that.
See Bug 162395 ? Soft Light and Overlay modes are identical:
http://bugzilla.gnome.org/show_bug.cgi?id=162395
for a lengthy discussion of this issue.
-- Bill
