group with previous
group with previous beyazit kelceoglu 30 Aug 07:30
  group with previous Roman Joost 31 Aug 01:35
   group with previous beyazit kelceoglu 31 Aug 01:52
beyazit kelceoglu
2006-08-30 07:30:20 UTC (over 18 years ago)
group with previous
hi there,
question one:
i wonder if gimp has a facility like photoshop which is "group with previous".
when you click between the layers with alt key pressed, you can group the upper layer with the previous one. so you can only make changes with the boundry of the lower layer pixels. this is very useful when you (well i do) comic painting.
i tried to search the net and gimp documents but i couldn't find any positive.
i tried to use layer mask (which makes same thing) but it was only grayscale.
if there is a way to do it with gimp, this will be life saver for me.
question two: is there any facility like layer set?
thanks in advance.
Roman Joost
2006-08-31 01:35:46 UTC (over 18 years ago)
group with previous
Hi beyazit,
first of all, I think you're posting your mail on the wrong list. I think you want to ask on gimp-user:
https://lists.xcf.berkeley.edu/mailman/listinfo/gimp-user
and second - avoid sending HTML formatted emails.
On Wed, Aug 30, 2006 at 05:30:16PM +0300, beyazit kelceoglu wrote:
question one:
i wonder if gimp has a facility like photoshop which is "group with previous". when you click between the layers with alt key pressed, you can group the upper layer with the previous one. so you can only make changes with the boundry of the lower layer pixels. this is very useful when you (well i do) comic painting.
If I understood you right, then such a feature doesn't exist yet. You can link layers together, which shows a chain symbol if you click between the eye and the thumbnail.
http://docs.gimp.org/en/gimp-dialogs-structure.html#gimp-layer-dialog
question two:
Not yet.
Greetings,
beyazit kelceoglu
2006-08-31 01:52:13 UTC (over 18 years ago)
group with previous
thank you for this.
i will do as you recommended. and thanks for the answers.
On 8/31/06, Roman Joost wrote:
Hi beyazit,
question one:
question two:
Not yet.
Greetings,
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
_______________________________________________ Gimp-docs mailing list
Gimp-docs@lists.XCF.Berkeley.EDU
