Glossary - visual class (again)
5 of 6 messages available
Glossary - visual class (again) Sally C. Barry 29 Aug 21:40
  Glossary - visual class (again) Sven Neumann 29 Aug 23:29
   Glossary - visual class (again) Sally C. Barry 30 Aug 06:55
1156958094.13874.28.camel@b... 07 Oct 20:29
  Glossary - visual class (again) Sally C. Barry 30 Aug 10:55
   Glossary - visual class (again) Sven Neumann 30 Aug 22:56
Sally C. Barry
2006-08-29 21:40:26 UTC (over 18 years ago)
Hello All -
I'm still considering writing a short entry on "visual class" and/or "True Color" in the Glossary, although I don't want to go into all of the details of what the X Window System means by this.
Dust's response indirectly reminded me that Gimp is running on Gtk, even when it is on a Windows PC. I am terribly ignorant of how exactly Gtk does this. Is there some sort of "X Server" that runs on top of MS Windows, so the visual class displayed in the Info Window really, truly *is* exactly the same visual class that I am familiar with in X?
Thank you all.
(Now back to "adaptive supersampling" and "image hose"...)
Sally
2006-08-29 23:29:38 UTC (over 18 years ago)
I don't think that this is information that the user should be worrying about. Especially since most users nowadays are probably using a TrueColor visual anyway.
No, there is no X server involved and there are differences but these differences are far beyond what belongs into the user manual.
Note that the development version of GIMP doesn't even show the visual type in the Info window any longer. So, if you want my advice on this, remove this part from the user manual as well.
Sally C. Barry
2006-08-30 06:55:01 UTC (over 18 years ago)
Hello Sven and All -
I agree that this information isn't terribly useful to the user and that the details of how the visual classes differ are far too esoteric. In fact, I have dragged my feet about defining it for the same reason. But I have noticed some confusion in the documentation itself, so I thought that a few words about it might be a good idea. Not all Gimp users are going to be programming experts.
OK, thank you. I'm not sure where to look up this information, so I do appreciate your response.
Thank you for that information, too. It does seem that the True Color description is not worthwhile at this point.
Best regards,
Sally
Sally C. Barry
2006-08-30 10:55:30 UTC (over 18 years ago)
In particular since GTK+ (or rather GDK) pretty much hides those differences. It is extremely difficult to tell the difference between a 16bit and a 24bit display if the rendering goes through GDK.
... which basically means (if I understand you correctly) that the entire GIMP rendering pipeline and I/O to and from files, etc. is done with the advertized 24-bit color depth, but the actual display may actually use only 16-bit color, without the user knowing about it (other than by looking at the image). Interesting.
Thanks again!
Sally
2006-08-30 22:56:28 UTC (over 18 years ago)
Of course GIMP doesn't care about the visual. After all you are not editing your image for a particular visual. If your visual is 16 bit, the conversion to 16 bit happens in GDK, or actually a part of it called GdkRGB. Since GdkRGB does color dithering, the user cannot even tell that the display is 16bit by looking at it. Well, perhaps if she is using a magnifying glass...
