What do I do with the glossary??
What do I do with the glossary?? Manuel Quiñones 02 Jun 08:01
  What do I do with the glossary?? Axel Wernicke 02 Jun 10:06
  What do I do with the glossary?? Jakub Friedl 02 Jun 10:27
  What do I do with the glossary?? Marco Ciampa 02 Jun 16:56
  What do I do with the glossary?? julien 02 Jun 22:55
   What do I do with the glossary?? Axel Wernicke 03 Jun 01:02
Manuel Quiñones
2006-06-02 08:01:57 UTC (almost 19 years ago)
Hello, I'm one of the spanish translators.
We have started recently our translation. I was seeing a lot of references to the glossary so I'm working on it now. I came to the problem that a term in spanish may not start with the same character as the original in english, but the terms are arranged by alphabetical order in the files.
I see in the source two approaches on this: the german translation was moved to the corresponding files, and a comment is left in the original file. Other translations like the italian one translated the terms in the place.
I think that the german approach is the best, but it's also prone to errors in the docs. I'm acting as the italian approach for now, so I may move the terms to the right place in the future. But is there a better solution for this?
Axel Wernicke
2006-06-02 10:06:35 UTC (almost 19 years ago)
Hi Manuel,
Am 02.06.2006 um 17:01 schrieb Manuel Qui?ones:
well, I think I introduced the german version. AFAIK there was a good reason for this. Lets take color as an example. This would show up in the glossary within the "C" section. The german word for color is Farbe. If I would have inserted the description directly beneath the glossary entry for color in the c.xml it would have shown up as "Farbe" in the "C" section of the glossary - This obviously makes no sense. Therefore I had to move it to the f.xml...
greetings, lexA
Jakub Friedl
2006-06-02 10:27:17 UTC (almost 19 years ago)
Dne p?tek 02 ?erven 2006 17:01 Manuel Qui?ones napsal(a):
Czech uses also the "german" approach. It is the correct way, imho.
Marco Ciampa
2006-06-02 16:56:31 UTC (almost 19 years ago)
Where (which definitions) are in this way exactly? If it is written in this manner it is not intentional...and the glossary is not finished so it's only a temporary solution...
Perhaps the best solution is what you suggested: to translate in place and then move the definitions under the chapter they belongs to in a second time...
Any suggestion for a better approach?
julien
2006-06-02 22:55:38 UTC (almost 19 years ago)
A question about the glossary:
Can we have the same 'id', distinguished with a 'lang="xx", in two different directories. For instance: in p.xml for the english version and 1- in c.xml
or
3- in c.xml ?
Julien
Axel Wernicke
2006-06-03 01:02:26 UTC (almost 19 years ago)
Hi Julien,
Am 03.06.2006 um 07:55 schrieb julien:
Can we have the same 'id', distinguished with a 'lang="xx", in two different directories. For instance: in p.xml for the english version and 1- in c.xml for the french
version
It works this way, e.g:
c.xml contains:
Color modes
Modalit? colori
?? ??(Color modes)
Color modes(????)
and f.xml contains:
Farbraum, Farbmodell
Please notice that I left a MARK comment in the place where the glossterm is described for en(glish). This way one can easily find out whether a specific glossterm was already translated to a certain language or not.
or must I have
2- in c.xml ?
Neither is this necessary, nor is it from my pov a good idea to make the id language specific. It just makes things more complicated.
greetings, lexA
Julien
