patch : fix and add korean translation
patch : fix and add korean translation Dust 06 May 00:18
Dust
2006-05-06 00:18:38 UTC (almost 19 years ago)
Hi all
somedays ago, I sent a patch file. and Axel Wernicke had merge my patch file, and he gave me some advices. (thanks, Axel)
So I fixed my works as his advice. and added more.
please, check my patch file agian. and if it's ok, may merge.
I compiled Gimp user manual on Linux. (just only korean part) then, I couldn't find any errors.
and I fixed all dead-link
Thanks, all
p.s. gimp-help-2.zip is contained patch file(gimp-help-2.patch) and my works(some xml files and png files)
http://mr-dust.pe.kr/gimp/gimp-help-2.zip
http://happybean.naver.com
