<revision>
7 of 7 messages available
<revision> julien 10 Mar 23:33
  <revision> Sven Neumann 11 Mar 02:15
   <revision> julien 11 Mar 06:18
   <revision> Daniel Egger 11 Mar 07:18
  <revision> Axel Wernicke 11 Mar 02:20
   <revision> julien 11 Mar 06:13
    <revision> Axel Wernicke 12 Mar 06:43
julien
2006-03-10 23:33:35 UTC (about 19 years ago)
<revision>
I don't well understand
Should it be:
1/
$revision:$
with only one revnumber for the file, or
2/
$revision:$
$revision:$
with a revnumber for every language in the file?
julien
2006-03-11 02:15:19 UTC (about 19 years ago)
<revision>
julien writes:
Should it be:
1/
$revision:$
2/
$revision:$
$revision:$
$revision$ refers to the CVS revision of the file and the value is inserted automatically. So a file can only have a single revision number, the first version should thus be sufficient.
PS: This will change somewhat next week when CVS is being migrated to Subversion. In a subversion repository there is only one revision number for the whole repository. Whether that is a problem or not, I don't know.
Axel Wernicke
2006-03-11 02:20:38 UTC (about 19 years ago)
<revision>
Am 11.03.2006 um 08:33 schrieb julien:
Should it be:
1/
$revision:$
2/
$revision:$
$revision:$
The first version is simply not valid docbook xml. Thats why it can't be used.
lexa
julien
julien
2006-03-11 06:13:29 UTC (about 19 years ago)
<revision>
Are you sure?
"1/" was the example given by Roman and used in toolbox/intro.xml or tool-rect-select.xml for instance: working well.
Another way to ask my question: must we have only one revnumber for the file (and for all languages) or a revnumber for every language in the file?
Julien
Axel Wernicke a ?crit :
Should it be:
1/
$revision:$
2/
$revision:$
$revision:$
lexa
julien
julien
2006-03-11 06:18:42 UTC (about 19 years ago)
<revision>
Sven's answer arrived while I was writing my own answer...
Julien
Sven Neumann a ?crit :
julien writes:
Should it be:
1/
$revision:$
2/
$revision:$
$revision:$
Daniel Egger
2006-03-11 07:18:38 UTC (about 19 years ago)
<revision>
Yay! Way to go.
Why would it?
Servus,
Daniel
-------------- next part -------------- A non-text attachment was scrubbed... Name: PGP.sig
Desc: This is a digitally signed message part Url : /lists/gimp-docs/attachments/20060311/f2bb57f6/PGP.bin
Axel Wernicke
2006-03-12 06:43:59 UTC (about 19 years ago)
<revision>
Hi Julien,
Am 11.03.2006 um 15:13 schrieb julien:
Are you sure?
not everything the build process does not complain about is valid docbook. Have a look at http://www.docbook.org/tdg/en/html/ revision.html to learn more about the element.
we do have more than on element for the revision number but get only one revision from cvs. Therefore the revision number is the same for all languages in one file/section.
Greetings,
lexA
btw. On which level do we do the revision tags anyway? One per sect1 and sect2 and sect3 or only the topmost of each file or ... ?
Julien
Should it be:
1/
$revision:$
2/
$revision:$
$revision:$
lexa
julien
