Metadata
Metadata Roman Joost 07 Feb 01:44
  Metadata Roman Joost 07 Feb 01:56
  Metadata julien 08 Feb 06:06
Roman Joost
2006-02-07 01:44:26 UTC (about 19 years ago)
Metadata
Hi folks,
just want to let you know that I introduced revision and date for several XML files in our manual:
2006-02-06 Roman Joost
* src/gimp.xml * src/introduction.xml
* src/concepts/basic-setup.xml * src/toolbox/intro.xml
* src/toolbox/other-tools.xml: revhistory introduced, as well as minor spelling fixes.
The online docs are updated as well. It would be nice if every docwriter can provide the date and revision.
- the revision is automatically set by the CVS and not language specific.
- the *info element (eg. sect1info, sect2info) is language specific. If you forget the lang attribute, the profiling step will produce invalid XML.
- Date and authorinitials are language specific as well (gimp.xml is currently an exception, because Axels last change applies to all language).
Feel free to post any questions :)
Greetings,
Roman Joost
2006-02-07 01:56:08 UTC (about 19 years ago)
Metadata
On Tue, Feb 07, 2006 at 10:44:00AM +0100, Roman Joost wrote:
Hi folks,
Ah ... I forgot - there is also still a bug filed:
http://bugzilla.gnome.org/show_bug.cgi?id=168255
Greetings,
julien
2006-02-08 06:06:49 UTC (about 19 years ago)
Metadata
The Revhistory is not movable and can mask the HTML text as in toolbox/intro
Roman Joost a ?crit :
Hi folks,
