Display filters
Display filters julien 29 Dec 12:00
  Display filters Axel Wernicke 29 Dec 12:13
  Display filters Roman Joost 30 Dec 06:40
julien
2005-12-29 12:00:40 UTC (over 19 years ago)
Display filters
"Display Filters" command is in View. Its id is "gimp-display-filter-dialog". Must the corresponding xml file be:
dialogs/display-filters.xml
or
menus/view-display-filters.xml
or else?
(xml structure is different either way)
Greetings
Julien
Axel Wernicke
2005-12-29 12:13:29 UTC (over 19 years ago)
Display filters
Hi Julien,
Am 29.12.2005 um 21:00 schrieb julien:
or
or else?
the rule pretty simple: if its a true dialog (one that can be docked, it should be in dialogs/* ( the file, as well as the chapter in the manual) if not, it's a simple command (may be one that has a dialog *window*) and belongs to the menu structure in file and chapter sense.
Greetings, lexA
Greetings
Julien
Roman Joost
2005-12-30 06:40:37 UTC (over 19 years ago)
Display filters
Hi Julien,
or
or else?
If you're refering to the filename, it should be:
display-filter-dialog.xml
and neither display-filters.xml nor view-display-filters.xml.
Greetings,
