Proposal for Metadata
8 of 8 messages available
Proposal for Metadata Roman Joost 18 Dec 04:31
  Proposal for Metadata Axel Wernicke 18 Dec 06:12
   Proposal for Metadata Roman Joost 18 Dec 10:31
    Proposal for Metadata Axel Wernicke 18 Dec 10:48
     Proposal for Metadata Roman Joost 18 Dec 11:36
   Proposal for Metadata Joao S. O. Bueno Calligaris 18 Dec 17:19
  Proposal for Metadata julien 18 Dec 22:27
   Proposal for Metadata Raphaël Quinet 19 Dec 11:55
Roman Joost
2005-12-18 04:31:13 UTC (almost 20 years ago)
I'm not sure if we already discussed this but I want to make a proposal for editing notes. The metadata we're currently adding with comments can be moved to the designated metadata elements. The advantage here is to provide the reader with detail information about what happened with the document in the past. This information is currently not provided.
To achieve this, I propose to transform the following example comment into the following structure (used it from toolbox/tool-airbrush.xml):
into:
Roman
Joost
Axel
Wernicke
$Id$
1.42
2005-11-27
lexa
changed to figure and sect3
1.41
2005-05-05
lexa
de reviewed
The author element specifies who initially wrote the document. The editor element who edited it afterwards. If proof readers mailed us fixes, we should put them into a element. The edition is filled in with a CVS specific variable, which is expanded during the checkin of the XML document. Afterwards it looks like this:
$Id: gimp-tool-airbrush.xml 1.42 2005-11-02 08:52:25Z romanofski $
The revhistory holds the equivalent entries of the current comments. The revnumber should be the last revision number added by the CVS (every docwriter can look it up in the edition tag). Unfortunately this element is necessary. In my opinion, the date is enough for our needs.
The disadvantage can be the verbosity. Having a big header of metadata is difficult to maintain. I propose, that we only hold five revision entries there. If the reader needs more information he can use other resources like the ChangeLog. I want to emphasise, that the info element shouldn't be used *as a ChangeLog*. Just a quick description about what has changed in the past and when it happen (like it is used now).
I would like to hear the opinion from other people.
Greetings, --
Roman Joost
www: http://www.romanofski.de
email: romanofski@gimp.org
-------------- next part -------------- A non-text attachment was scrubbed... Name: not available
Desc: not available
Url : /lists/gimp-docs/attachments/20051218/223f6312/attachment.bin
Axel Wernicke
2005-12-18 06:12:20 UTC (almost 20 years ago)
Hi Roman,
to be honest I don't see the benefit of changing the kind of comments we do by now. The information is almost the same, but due to that huge surrounding docbook structure it's very hard to read in the source. Right now I'd prefer to stick to the way we are doing it today, but may be you can convince me. I'd like to focus on how to make contributing easier - we could need some more editors, and right now writing content is very technically. To deal with all that docbook stuff is more like writing source code than like writing a book. I'd be very open minded to see proposals on how to change that.
Greetings, lexa
Am 18.12.2005 um 12:44 schrieb Roman Joost:
into:
Roman
Joost
Axel
Wernicke
$Id$
1.42
2005-11-27
lexa
1.41
2005-05-05
lexa
de reviewed
Greetings, --
Roman Joost
Roman Joost
2005-12-18 10:31:09 UTC (almost 20 years ago)
The advantage is, that people are able to see what happened with the article they're looking at. If the document is out of date, because the last change was a year ago, we could probably encouraged some people to change that. Of course a very vague assumption, but not an impossible one.
It is a very technical approach. The disadvantage about the current comments are, that our readers don't see the comments. Though we have to think about the releases. During releases we should skip to display this metadata.
Greetings,
Axel Wernicke
2005-12-18 10:48:31 UTC (almost 20 years ago)
Am 18.12.2005 um 18:59 schrieb Roman Joost:
That would of course work only if the revision entries were language dependant. Otherwise If someone translates content from the GIMP stone age the document seems updated recently to *ALL* readers, but was translated to a new language only :(
I think most of the content is independent of time anyway. It simply doesn't matter if a tutorial was written yesterday or two years ago. Where time (GIMP releases) matter of course is everything that is related to the reference part of the manual. May be we should hurry up to get up to date for the 2.2 release (I guess we are not that far away from that) and then freeze and release it as gimp-help 1.0. With this we could split up the changelog (which is btw. pretty large already now) and have a sweet start for bringing the relevant topics up to gimp 2.4 then.
So if we decide to switch to revhistory elements we need to - make sure we can hide it from release html / pdf versions - make it lang dependent (how is this supposed to work with cvs??) - define in which granularity it should be done (today we do it by file, but not sect1 sect2 specific)
- introduce it step by step
Greetings, lexa
Greetings,
Roman Joost
2005-12-18 11:36:26 UTC (almost 20 years ago)
Actually, I never thought about making this information language dependant. The current comments aren't language dependent, so this metadata shouldn't be as well. It is just developer information. The docs hosted on http://docs.gimp.org are developer snapshots, so I thought that displaying this information for the developer snapshots would be a nice to have feature for readers and esp. probably upcoming writers or proof readers.
Well, a tutorial written for GIMP 1.2 would be more or less unusable nowadays. Of course, if you really want to understand that specific feature, you're free to find the necessary triggers. But I think, that every aspect of the manual is dependent on the GIMP version and therefore dependent on time.
That wouldn't be the tricky part IMHO. Just using a customized stylesheet of the current stylesheets which suppresses the info elements should do the trick.
If we really want to do that, it would work like the current profiling works. But I don't think we should make it language dependant, just for the sake of completeness. It's just not worth it IMO.
Good point - haven't thought about that.
Yep or maybe after a 1.0 release? Hm.. step by step seems to be better ...
Greetings,
2005-12-18 17:19:00 UTC (almost 20 years ago)
On Sunday 18 December 2005 12:12 pm, Axel Wernicke wrote:
Re: [Gimp-docs] Proposal for Metadata Date: Today 12:12:12 pm
To: Roman Joost
CC: GIMP Docs
Message was signed with unknown key 0x47D9972D5B006E24. The validity of the signature cannot be verified. Status: No public key to verify the signature Hi Roman,
to be honest I don't see the benefit of changing the kind of comments ? we do by now. The information is almost the same, but due to that huge surrounding docbook structure it's very hard to read in the source. Right now I'd prefer to stick to the way we are doing it today, but may be you can convince me. I'd like to focus on how to make contributing easier - we could need ? some more editors, and right now writing content is very technically. To deal with all that docbook stuff is more like writing source code than like writing a book. I'd be very open minded to see proposals on how to change that.
That's just a great motive to change the comments to actual XM content: whatever tool one will use, it will have to read the XML content, decoding it, and later encode it back - the scripts I was trying earlier did just that, for example. The problem is: when you parse XML, you _do_not_ have access to comments. They are ignored by the parser - (unless you make a custom parser, but even there, you are violating XML specs). well..any program which does not know about the comments, obviously cannot write then back when re-encoding the document.
JS
julien
2005-12-18 22:27:49 UTC (over 19 years ago)
Managing xml file is difficult; they are getting hard to read. Adding all this stuff will worsen the situation. I agree, help user must know the author's name : but do you know who wrote most of files first?
I think it's not necessary to have the dates of all modifications in the history. Only the last one is useful: "Last review (en;fr)..."
Changes in the html structure are not interesting for help user, nor typo corrections, but they may be interesting for the help writer.
So, we may have two histories: - a history for help users, with only the author's name and last revision, that appears in html file. - a history between tags for doc writers.
atb
Julien Roman Joost a ?crit :
into:
Roman
Joost
Axel
Wernicke
$Id$
1.42
2005-11-27
lexa
1.41
2005-05-05
lexa
de reviewed
Greetings, --
Roman Joost
Raphaël Quinet
2005-12-19 11:55:05 UTC (over 19 years ago)
On Mon, 19 Dec 2005 07:27:56 +0100, julien wrote: [...]
I agree. Most users will not care about the full revision history of each file. At most, they may be interested in what was done in the last revision or in knowing whether they have the last revision or not. For most users, it may be sufficient to have $Revision$ or $Id$ included somewhere in the generated file. A link to the latest HTML version on docs.gimp.org may also be useful if they want to compare. That link could be visible or hidden in a comment. Or maybe we could have a link to the CVS log of the corresponding source file, like this: http://cvs.gnome.org/viewcvs/gimp-help-2/src/blah/blah.xml?view=log
The doc writers have different interests than the doc users. They will probably get most of the revision history from CVS anyway. Besides what is in the CVS log, a complement in the form of a short comment in the file can also be useful (like the current comments), but I think that these comments should be optional when the changes are small and they do not need to be longer than what we have now.
Again, take my comments with a pinch of salt as I am not contributing much to the writing effort anyway.
-Rapha?l
