Using id.as.filename
7 of 7 messages available
Using id.as.filename Roman Joost 18 Dec 01:44
  Using id.as.filename Axel Wernicke 18 Dec 06:07
  Using id.as.filename julien 18 Dec 22:34
   Using id.as.filename Roman Joost 19 Dec 00:01
    Using id.as.filename julien 19 Dec 11:40
  Using id.as.filename Raphaël Quinet 19 Dec 11:30
Using id.as.filename DES0LATEDREAMS4U@aol.com 18 Dec 06:33
Roman Joost
2005-12-18 01:44:34 UTC (over 19 years ago)
Hi everyone,
I just want to propose a slight change in the stylesheets for generating HTML. I think this has been discussed in several threads ago. I also want to vote for a change in the generated filenames, so that the id of the chapter is beeing used (e.g. html/de/gimp-file-open.html).
It is not intended that the change is used for an id lookup. The names we're currently use are just not usable by our readers who want to provide a link from their forum to a specific section.
Yes, there is a script [1], to create permanent links to our help pages. But, nobody uses it and therefore I think we should try something new. The scripts will still work to create permanent links. Sven and Mitch already proposed that change a year ago, so I would love to do this.
Any objections?
[1] - http://www.romanofski.de/lookup
Greetings,
Axel Wernicke
2005-12-18 06:07:21 UTC (over 19 years ago)
Hi Roman,
if I got that right the only thing that is needed to change the file names is the stylesheet? If so I'd be happy to see that happen!
Greetings, lexa
Am 18.12.2005 um 11:43 schrieb Roman Joost:
Hi everyone,
Any objections?
Greetings,
2005-12-18 06:33:58 UTC (over 19 years ago)
Skipped content of type multipart/related
julien
2005-12-18 22:34:39 UTC (over 19 years ago)
Like it was in Gimp-1.2 help? Well, on the condition that this is not new work for doc writers...
I think html names must be more simple. Why not "file-open.html" instead of "gimp-file-open.html"?
atb
julien
Roman Joost a ?crit :
Hi everyone,
Any objections?
Greetings,
Roman Joost
2005-12-19 00:01:14 UTC (over 19 years ago)
It's just a change in the stylesheet.
I would like to rely on the id's we're using as a filename. Manipulating on the id's is not necessary and may lead into errors IMO.
Greetings,
Raphaël Quinet
2005-12-19 11:30:52 UTC (over 19 years ago)
I'm all for it (even if my opinion does not count much as I do not work much on the translations). This would make it easier to link to the generated pages and would also allow the users to switch between languages in case they want to compare the translation in their own language with the English version. This is currently very difficult due to the differences in chapter numbering between the different languages. Using ids would make this much easier.
-Rapha?l
julien
2005-12-19 11:40:23 UTC (over 19 years ago)
When you diplay a directory content, file names are truncated if they are too long, and so they are sometimes not readable. That's why I suggested short names. But I understand how difficult manipulating id's is.
Greetings
julien
