error message
error message Marco Ciampa 15 Dec 23:06
error message Axel Wernicke 15 Dec 23:22
  error message Marco Ciampa 16 Dec 02:50
Marco Ciampa
2005-12-15 23:06:16 UTC (over 19 years ago)
error message
From the last two commits, I encounter this error message:
make
-- Profiling XML for en
-- Validating XML for en number of errors: 0 -- Profiling XML for it
-- Validating XML for it number of errors: 0 *** Validating profiled XML ***
Log files of the validation process have been generated in the xml directory.
Please correct any errors before writing new content. *** Copying images ***
cp: impossibile creare il file normale `html/./images/using/de/ui-log.png': No such file or directory cp: impossibile creare il file normale `html/./images/using/de/ui-performance.png': No such file or directory cp: impossibile creare il file normale `html/./images/using/de/ui-personal.png': No such file or directory cp: impossibile creare il file normale `html/./images/using/de/ui-upgrade.png': No such file or directory cp: impossibile creare il file normale `html/./images/using/de/ui-welcome.png': No such file or directory cp: impossibile creare il file normale `html/./images/using/hr/standard-setup.png': No such file or directory cp: impossibile creare il file normale `html/./images/using/hr/toolbox-description.png': No such file or directory
make: *** [stamps/images.stamp] Error 1
is it my fault? (In this case, please, be gentle! :-)
Axel Wernicke
2005-12-15 23:22:14 UTC (over 19 years ago)
error message
--- Urspr?ngliche Nachricht ---
Von: "Marco Ciampa"
An: gimp-docs@lists.XCF.Berkeley.EDU Betreff: [Gimp-docs] error message
Datum: Fri, 16 Dec 2005 08:06:08 +0100
This means there are new directories below the image directory which you did update from cvs correctly. The make process then tries to copy these new images to the html directory. Unfortunately there are the new directories missing yet - so you get an error.
To correct this I'd suggest to do a make clean; make or to remove the appropriate file from the stamps directory. (Should be something with "directoriescreated" in it.
Hope that helps.
lexa
Marco Ciampa
2005-12-16 02:50:23 UTC (over 19 years ago)
error message
Von: "Marco Ciampa"
To correct this I'd suggest to do a make clean; make Hope that helps.
Sorry I usually try to do a make clean before asking dumb questions. make clean worked flawlessly...
