docbook problem
docbook problem julien 03 Dec 00:02
  docbook problem Roman Joost 03 Dec 00:23
   docbook problem julien 03 Dec 07:33
julien
2005-12-03 00:02:48 UTC (over 19 years ago)
docbook problem
I had to re-install Mandriva 2005. I can't validate xml files:
[julien@localhost gimp-help-2]$ make validate ALL_LINGUAS="fr" -- Profiling XML for fr
I/O error : Attempt to load network entity http://docbook.sourceforge.net/release/xsl/current/profiling/profile.xsl warning: failed to load external entity "http://docbook.sourceforge.net/release/xsl/current/profiling/profile.xsl" compilation error: file ../stylesheets/profile.xsl line 5 element import xsl:import : unable to load
http://docbook.sourceforge.net/release/xsl/current/profiling/profile.xsl -- Validating XML for fr number of errors: 0 *** Validating profiled XML ***
Log files of the validation process have been generated in the xml directory.
Please correct any errors before writing new content. [julien@localhost gimp-help-2]$
Formerly, I solved this problem by installing docbook-dtd43-xml-1.0.2mdk.noarch.rpm but this doesn't work that time. When going on http://rpm.pbone.net I am lost among masses of "docbook..." rpm's.
Which rpm I have to install to solve the problem?
Julien
Roman Joost
2005-12-03 00:23:01 UTC (over 19 years ago)
docbook problem
Hi Julien,
Hm... hope it's Mandriva 2006, because I found only packages for Mandriva 2006 ..
[julien@localhost gimp-help-2]$ make validate ALL_LINGUAS="fr" [...] profiling errors
So either the docbook stylesheets are missing or the XML catalog is broken. You may try to install the following package:
http://rpm.pbone.net/index.php3/stat/4/idpl/2298689/com/docbook-style-xsl-1.69.1-1mdk.noarch.rpm.html
I don't know if docbook stylesheets are provided with the Mandriva Installation CD's, but you probably may have a look at the package list.
Greetings,
julien
2005-12-03 07:33:45 UTC (over 19 years ago)
docbook problem
Thank you Roman. I managed to make validate and html. I have some other small problems, but I'll see later. I am fed up with this installation.
All the best.
julien
