Some mess in CVS
Some mess in CVS julien 30 Nov 22:50
Some mess in CVS julien 01 Dec 00:22
Some mess in CVS Axel Wernicke 01 Dec 00:33
  Some mess in CVS julien 01 Dec 06:06
  Some mess in CVS Axel Wernicke 01 Dec 09:48
julien
2005-11-30 22:50:19 UTC (over 19 years ago)
Some mess in CVS
Oh, sorry. bug.xml ("Reporting bugs") is visible at end of the TOC.
julien
2005-12-01 00:22:16 UTC (over 19 years ago)
Some mess in CVS
(Previous message failed)
Hi folks,
concepts/imagewindow.xml and using/imagewindow.xml are same file. concepts/images.xml and using/images.xml are same file. src/bugs.xml and src/introduction/bugs.xml are same file
atb
julien
Axel Wernicke
2005-12-01 00:33:39 UTC (over 19 years ago)
Some mess in CVS
--- Urspr?ngliche Nachricht ---
Von: julien
An: GIMP Docs
Betreff: [Gimp-docs] Some mess in CVS Datum: Thu, 01 Dec 2005 09:22:14 +0100
(Previous message failed) Hi folks,
Hi Julien,
so, what exactly do you want to tell us? Did you duplicate them? Did you just find out about it? Do you want one of us to remove any of the files? What?
Greetings, lexA
atb
julien
_______________________________________________ Gimp-docs mailing list
Gimp-docs@lists.XCF.Berkeley.EDU
julien
2005-12-01 06:06:24 UTC (over 19 years ago)
Some mess in CVS
Axel Wernicke a ?crit :
>>concepts/imagewindow.xml and using/imagewindow.xml are same file. >>concepts/images.xml and using/images.xml are same file. >>src/bugs.xml and src/introduction/bugs.xml are same file >
> so, what exactly do you want to tell us? Did you duplicate them? Did you > just find out about it? Do you want one of us to remove any of the files? > What?
These files are duplicated in CVS. Is this normal? If not, I inform you so that you can correct this mess.
If it is normal, I think it's not a good idea to have duplicated files in help.
atb
julien
Axel Wernicke
2005-12-01 09:48:11 UTC (over 19 years ago)
Some mess in CVS
Am 01.12.2005 um 09:33 schrieb Axel Wernicke:
using/imagewindow.xml seems not to be used, last commit was in august this year.
concept creation was done by romanofski and is more recently change. So, it seems the using/* file should be removed from cvs? Roman, do you remember what the reason for the duplication might have been??
Didn't check the other files, but its probably the same issue with them. :(
Greetings, lexa
Live is like a chocolate box, you never know what you wanna get... GPG Signatur auf http://wernicke-online.net/Impressum/ pr?fen
-------------- next part -------------- A non-text attachment was scrubbed... Name: PGP.sig
Desc: Signierter Teil der Nachricht
Url : /lists/gimp-docs/attachments/20051201/6bf396fe/PGP.bin
