Problems building PDF file from gimp-help-2.0.9
9 of 12 messages available
Problems building PDF file from gimp-help-2.0.9 Keith Hanlan 23 Nov 20:07
  Problems building PDF file from gimp-help-2.0.9 Axel Wernicke 23 Nov 22:31
  Problems building PDF file from gimp-help-2.0.9 Roman Joost 24 Nov 00:14
   Problems building PDF file from gimp-help-2.0.9 Hans De Jonge 24 Nov 14:08
    Problems building PDF file from gimp-help-2.0.9 Roman Joost 25 Nov 00:38
Pine.LNX.4.55L.051124155941... 07 Oct 20:29
  Problems building PDF file from gimp-help-2.0.9 Axel Wernicke 24 Nov 14:23
   Problems building PDF file from gimp-help-2.0.9 Keith Hanlan 24 Nov 14:28
    Problems building PDF file from gimp-help-2.0.9 Roman Joost 25 Nov 00:36
   Problems building PDF file from gimp-help-2.0.9 Roman Joost 25 Nov 00:39
Pine.LNX.4.55L.051124085459... 07 Oct 20:29
20956.1132841999@www26.gmx.net 07 Oct 20:29
Keith Hanlan
2005-11-23 20:07:34 UTC (over 19 years ago)
I am trying to build the PDF version of the Gimp manual and am running into problems. I have an up-to-date FC4 installation and I am hoping someone can point me to a simple mistake that I can rectify.
I'm trying to keep it simple by doing the following: # ALL_LINGUAS=en ./configure --without-gimp --disable-network # make
# make pdf
But I get the following mess: |keithh@kph [219]* make pdf
|mkdir -p -- xml
|-- Profiling XML for en
|*** Profiling XML files ***
|*** Building LaTeX files ***
|-- Building LaTeX for en
|I/O error : Attempt to load network entity http://db2latex.sourceforge.net/xsl/docbook.xsl |warning: failed to load external entity "http://db2latex.sourceforge.net/xsl/docbook.xsl" |compilation error: file ../../stylesheets/plainprint.xsl line 6 element import |xsl:import : unable to load http://db2latex.sourceforge.net/xsl/docbook.xsl |make: *** [stamps/latex.stamp] Error 5
The configure command produced the following: |keithh@kph [217]* ALL_LINGUAS=en ./configure --without-gimp --disable-network |checking for a BSD-compatible install... /usr/bin/install -c |checking whether build environment is sane... yes |checking for gawk... gawk
|checking whether make sets $(MAKE)... yes |checking for a BSD-compatible install... /usr/bin/install -c |checking whether ln -s works... yes |checking whether make sets $(MAKE)... (cached) yes |checking whether make is GNU make... yes |checking for xsltproc... /usr/bin/xsltproc |checking for xmllint... /usr/bin/xmllint |checking for convert... /usr/bin/convert |configure: creating ./config.status |config.status: creating Makefile
|config.status: creating omf/gimp-C.omf |config.status: creating stylesheets/plainhtml.xsl |
| Rebuild the help files: no | Languages: en | Installation prefix: ${datadir}/gimp/2.0 | Optimize PNGs for HTML files: no
Any pointers?
On a related topic: the reason that I'm trying to build the PDF file is that I want to print a hard-copy. If I'm going to invest a lot of time learning a new tool, I want a manual that doesn't tie me to the computer. This begs the question: why not just supply the PDF on the website? This is *way* too much work for a manual.
Thanks, Keith Hanlan
Ottawa, Canada
Axel Wernicke
2005-11-23 22:31:14 UTC (over 19 years ago)
Am 24.11.2005 um 05:07 schrieb Keith Hanlan:
Good idea, we should have had that by our own. Guess what - we did: http://docs.gimp.org/en.pdf
But be warned, IIRC these files are not printable very well.
lexA
Thanks,
Keith Hanlan
Ottawa, Canada
Roman Joost
2005-11-24 00:14:02 UTC (over 19 years ago)
Just on start in short: Creating PDF's doesn't work currently. The LaTeX interpreter stops with an error. It seems that it can't place all the figures correctly and I haven't figured a workaround out for this yet.
A fix will be very, very welcome.
# make pdf
Looks good so fahr ...
|mkdir -p -- xml
It seems, that you either haven't installed the 'db2latex' XSL stylesheets[1] or you have a broken XML catalog (probably mostly located at /etc/xml/catalog). This catalog helps to find the stylesheets on your harddisk.
Looks good as well ...
As Axel already mentioned. We did put PDF versions on our project page (http://docs.gimp.org). Unfortunately, they're not very up-to-date because of the recent errors I'm running into ... Additionally, some of the figures in the manual are not placed correctly on a page. Well, having said, it's far from usable.
[1] - http://db2latex.sf.net
Greetings,
Hans De Jonge
2005-11-24 14:08:12 UTC (over 19 years ago)
I replaced the justification manually from: /begin{figure}[htb]
into
/begin{figure}[H]
and now it crashes somewhere else on a non-figure spot:
ages/using/nl/toolbox-description.png>]
! Argument of \user@active@arg" has an extra }.
\par l.1239 ...tinstellingen opslaan bij verlaten ..."} in het {\sffamily \bfseri...
I hope this helps a little bit? --
Hans de Jonge
+31 (0)24 844 96 85
+31 (0)62 20 57 101
Axel Wernicke
2005-11-24 14:23:22 UTC (over 19 years ago)
Am 24.11.2005 um 23:04 schrieb Keith Hanlan:
hmm, it should be 2.0.9 too! Pretty sure it is!
No, it doesn't look like the HTML version. The date is 2004 and there is only a "What?s New in The Gimp 2.0?" section. There is no "What?s New in The Gimp 2.2?" section.
Hmm, Roman - we need to do something about this - should I start trying to get that cow flying?
bummer. And there don't seem to be any up-to-date commericial books either.
Perhaps I should be also be asking if the docbook framework has a serious usability issue if it cannot produce printable documents. Is this a problem that is being addressed?
Well, a difficult issue. DocBook itself is xml. Publishing has not much to do with docbook itself, its more about xml stylesheets and translations. PDF transformations are mostly done via so called FOPs but this seems to be a standard the is mostly instable or incomplete implemented. Another way - the way the GIMP docs project is going - is to transform the xml into latex and generating pdf from latex. Unfortunately the docbook xml - latex transformation is an very complex issue that involves lots of "magic".
Good lord - how complicated. I think I'm going to miss troff!
As an outside observer, I'm curious as to why you couldn't use OpenOffice? Is it simply not up to the task of a 500 page book?
I know from my own experience that it's still a little rough around the edges but it is quite usable for moderately large documents. It can also produce HTML, DocBook, XHTML, and MSOffice XML. Don't get me wrong: I'm sure that there were good reasons. But from the outside, it looks like somebody has architected a monster.
Well it's not that bad - creating the html version is pretty straight forward. May be we should consider building a one file html as long as the pdf is out of order ...
... um, the gimp manual is up to 450 pages in around 7 (en;de;cs;nl;fr;sv;zh_CN) languages. A team of around a dozen people is working on it - thats nothing you want to do in OO !
But we could need some help with it everytime - so if you have questions or annotations to the manual - please ask and state them !
sincerely, lexA
Thanks,
Keith Hanlan
Ottawa, Canada
Live is like a chocolate box, you never know what you wanna get... GPG Signatur auf http://wernicke-online.net/Impressum/ pr?fen
-------------- next part -------------- A non-text attachment was scrubbed... Name: PGP.sig
Desc: Signierter Teil der Nachricht
Url : /lists/gimp-docs/attachments/20051124/395724cc/PGP.bin
Keith Hanlan
2005-11-24 14:28:52 UTC (over 19 years ago)
On Thu, 24 Nov 2005, Axel Wernicke wrote:
No, it doesn't look like the HTML version. The date is 2004 and there is only a "What=BFs New in The Gimp 2.0?" section. There is no "What=BFs New in The Gimp 2.2?" section.
Nice turn of phrase! I think I'll be able to use that one.
Well it's not that bad - creating the html version is pretty straight forward. May be we should consider building a one file html as long as the pdf is out of order ... ... um, the gimp manual is up to 450 pages in around 7 (en;de;cs;nl;fr;sv;zh_CN) languages. A team of around a dozen people is working on it - thats nothing you want to do in OO !
I figured as much. Is it possible to produce a single DocBook file? And can that file be loaded by OpenOffice long enough to do the transform? Perhaps I can just do an end-run around the problem.
Thanks very much for your help gentlemen. I'm looking forward to curling up with a nice fat book over the holidays.
Regards, Keith Hanlan
Ottawa, Canada
Roman Joost
2005-11-25 00:36:57 UTC (over 19 years ago)
Hi Keith,
You need XSL stylesheets which transform DocBook/XML to OpenOffice Open Document Format (hope I got it right). If there are any, we can produce OpenOffice documents.
The point is, LaTeX is currently the best system which can deal with this amount of text very well. Unfortunately, most of the grafics we use are converted to inlinegraphic elements in LaTeX. Those graphic elements are problematic to align correctly over a few pages and leads in to errors. I'm sure it's a mostly a fact of changing from the most mediaobjects to figure elements in DocBook.
Heh :)
Greetings,
Roman Joost
2005-11-25 00:38:21 UTC (over 19 years ago)
into
/begin{figure}[H]
I tried to change the alignment rules, but doesn't solve the problem unfortunately. Well, maybe I missed something, but it didn't work for me.
Thanks for your hint :)
Greetings,
Roman Joost
2005-11-25 00:39:08 UTC (over 19 years ago)
Hm, actually ... I'm missing the other Mail you're refering to and I don't understand what it is about ...
Greetings,
