Game of Thrones opening titles rebuilt in GIMP
2012-11-16 18:29:18 UTC (over 11 years ago)
I had some time to experiment with GIMP so I tried to rebuild the Game of Thrones title that comes up after the intro music - that solar eclipse thing. I only used a painting of a dragon that I found on flickr and the stony texture you can see around the medallion. I had some trouble to merge the dragons with the stones-texture and to create a look on them thats not too "flat". Especially the correct lighting was difficult - so I just made a higher contrast to conceal the differences. For the glowing metal stuff in the middle I've used the "Relief light" filter in the G'MIC plugin.
What do you think about it? If someone wants to take a closer look at the xcf file just tell me - it's 22MB so I will upload it if anyone wants it.
Cheers, devvv
2012-11-30 16:59:18 UTC (over 11 years ago)
Cheers,
devvv
Fantastic job, Brilliant in so many ways Devvv!
2012-12-01 16:45:59 UTC (over 11 years ago)
Thank you, I'm glad you like it!
2013-11-16 17:10:09 UTC (over 10 years ago)
really impressive, actually, im looking for a tutorial to make the iron text "games of thrones" in the main poster of this movie. I wonder can you intruct me how to do that? i'll very appreciate! Thank you! the text is here in the file i add
2013-11-18 07:45:25 UTC (over 10 years ago)
thanks ;) not exactly what you might need, but http://www.gimpusers.com/tutorials/hard-beveled-stoney-text-effect may give you some hints on creating such text effects!
2021-08-08 14:14:47 UTC (almost 3 years ago)
2021-09-15 11:00:00 UTC (over 2 years ago)
Hello. I study to be a graphic designer and here to learn as much as possible about the intricacies of the work. It's a pity I can't help anything. Now I have to write an essay in a professional field, I try to get inspiration here, although it may be better to seek help from professional services.
2021-09-15 11:14:44 UTC (over 2 years ago)
here is a link to one of them, really good: https://www.scribbr.com/.
