Tutorial: Compiling GIMP 2.8-RC1 for Ubuntu 12.04
Written by · Created on Apr 21, 2011, last updated almost 13 years ago CC BY-NC License
GIMP 2.8-RC1 didn't make it into Ubuntu 12.04 yet, so if you want to use it, you will have to compile it yourself or use a PPA repository. This tutorial illustrates how to compile GIMP yourself.
    This tutorial shows you how to compile GIMP 2.8-RC1 on Ubuntu Linux 12.04 (Precise Pangolin). However, you can use it for other GIMP/Linux versions too, because I’ll try to explain how to do it, and not to just tell you the necessary commands so you can compile it but don’t know what you’re doing.
    If a step doesn’t work as expected or there are required additional steps, please modify the procedure on your own and maybe leave a comment to inform other users about your findings.
    If there are newer versions available as the ones in the tutorial (for instance, for babl or GEGL), use the newer versions.
    First, create a temporary directory where the sources are put into:
    mkdir -p ~/tmp/gimp
    cd ~/tmp/gimp
    Then, fetch the source code of the GIMP version you want to compile and put it into the directory.
    So, either download the GIMP 2.8-RC1 sources and extract it. Open a console window and type:
    cd ~/tmp/gimp
    wget ftp://ftp.gimp.org/pub/gimp/v2.8/gimp-2.8.0-RC1.tar.bz2
    tar -xjf gimp-2.8.0-RC1.tar.bz2
    Alternatively, fetch the latest sources with git (make sure git is installed – install with sudo apt-get install git): Open a console window and type:
    cd ~/tmp
    git clone git://git.gnome.org/gimp
    We want to install GIMP into a special directory (/opt/gimp-2.8) so that it doesn’t interfere with the system’s GIMP package. To accomplish that, open a console window (if you didn’t do already) and type:
    export PATH=/opt/gimp-2.8/bin:$PATH
    export PKG_CONFIG_PATH=/opt/gimp-2.8/lib/pkgconfig
    export LD_LIBRARY_PATH=/opt/gimp-2.8/lib
    The PATH is a list of directories where binaries are looked for, PKG_CONFIG_PATH allows the pkg-config tool to recognize libraries compiled in our GIMP-2.8 directory and LD_LIBRARY_PATH allows shared objects to be located in some custom path.
    Please note that these exports are only stored for this session (= console window). If you close it and open another one later, you will have to type these lines again (or put it into .bashrc).
    If you compile only for your machine (i.e., you don’t want to run the compiled binary on other machines), you can also do
    export CFLAGS="-march=native -O3"
    It allows the C compiler to use all instructions your processor supports and will optimize the compiled code for greatest performance.
    Now we have the GIMP source ready. Before the next step, install all development dependencies that the system-packaged GIMP requires. The chances for GIMP 2.8 needing these libraries is high and so we don’t need to install everything by hand:
    sudo apt-get build-dep gimp
    This will probably install a bunch of packages, so be patient.
    Now lets’s try to ./configure the source:
    If you downloaded the tarball (.tar.bz2):
    cd ~/tmp/gimp/gimp-2.8.0-RC1
    ./configure --prefix=/opt/gimp-2.8
    Or if you fetched the sources from git:
    cd ~/tmp/gimp/gimp
    ./autogen.sh --prefix=/opt/gimp-2.8
    The configuration fails saying that babl >= 0.1.10 is required but not found. So we have a look on the babl webpage. There is no tarball for >= 0.1.10 so we fetch the source via git:
    cd ~/tmp/gimp
    git clone git://git.gnome.org/babl
    babl-configure throws an error if libtool is missing, so install it using sudo apt-get install libtool. Then:
    cd babl
    make -j5
    sudo make install -j5
    The -j argument controls how many processes are created simultaneously. Use number of CPU cores + 1 — for instance, if you have 4 CPU cores, use -j5. This makes compiling faster, but not the resulting binary, of course.
    Now let’s try to compile GIMP again:
    Now there’s another error: “Package requirements (gegl >= 0.1.6) were not met.”
    As you may have guessed — now it’s required to go to the GEGL webpage and download the latest GEGL version:
    cd ~/tmp/gimp
    wget ftp://ftp.gimp.org/pub/gegl/0.2/gegl-0.2.0.tar.bz2
    tar -xjf gegl-0.2.0.tar.bz2
    cd gegl-0.2.0
    Now check the output of the configuration script. It tells you which libraries are found and used. If you need some features that have not been configured now, install the necessary libraries and run the ./configure script again.
    Finally, compile with: make -j5 && sudo make install -j5
  9. 10
    Time for trying to compile GIMP again:
    Watch the output again. If there are libraries missing or if you want to enable additional features, install the required libraries (compiling should not be required for these libs, they are available as -dev package) ./configure again until everything is OK.
    GIMP is now configured and ready to compile.
  10. 11
    Compile GIMP (takes some time, depending on your machine) and install it:
    make -j5
    make install -j5
  11. 12
    GIMP should have been installed to /opt/gimp-2.8 now. Now, run it with /opt/gimp-2.8/bin/gimp-2.8
  12. 13
    … check Window / Single-window-mode and it’s ready to use :)
This topic (Compiling GIMP 2.8-RC1 for Ubuntu 12.04) has been rated 4.0/5.0.
GraphicAid
over 6 years ago
Great post.I learn form this blog.
Josh
over 7 years ago
Informative, I could not finish it, but I will keep on.
drucifer82
over 11 years ago
Nothing past step 5 works for me.
VulcanHades member for over 11 years VulcanHades 2 comments
over 11 years ago
Awful and outdated tutorial. Running these scripts only return errors. I have followed every step and downloaded everything. It says it can't connect to the various sites and can't find the directories. And some commands keep looping despite failing.
This is useless for the average user. All I see is a nerd masturbating and forcing people to make mistakes then force them to correct what they've done. Trying to explain how it works doesn't mean anything if it doesn't even work and the process is too complicated and not straight forward enough.
Martyn
almost 12 years ago
Thanks - excellent tut.
Me
almost 12 years ago
No thanks, the original UI rocks! :)
For the rest, it's a nice how-to.
thank you
Daniel H.
over 12 years ago
This is a nice explanation of the processes involved, however it glosses over the requirements and/or show-stoppers an unwary user may encounter.
For example, if a user is using a version of GNOME which is too old (for example RHEL 6.x) then far more dependencies will have to be called in and compiled. Additionally, you won't be able to integrate it with the running instance of the GNOME desktop because of the different versions of of the same libraries running. So if foreign language input is required in a GiMP project, the only way to accomplish this is to type the string(s) into another application, then copy-paste the strings into GiMP.
It can be done, but it all takes a whole lot more work than is indicated in the tutorial above and the use of the application is not quite as easy either.
Rukiri
over 12 years ago
This is a great walkthrough, personally use git for all babl, gegl, and gimp because they are reliant on one another. So it's best to be up to date.
pietro909
over 12 years ago
Really, really thank you man! I wouldn't leave my 12.04 to have Gimp2.8 and thank to your tutorial I'm working on my brand new gimp :)
Thank you a lot.
madhanprasath
almost 13 years ago
i want to know how to compile GIMP 2.8-RC1 on windows , pls tell me the steps to followed ..,
flogimp member for almost 16 years flogimp 2 comments rated this topic with 4/5
almost 13 years ago
Hi
openSuse 11.4
Thanks for your tutorial. I followed your instructions and got all dependencies installed.
But when I run configure for gimp it complains about the wrong glib.
=== START
checking for GLIB - version >= 2.30.2... no
*** Could not run GLIB test program, checking why...
*** The test program failed to compile or link. See the file config.log for the
*** exact error that occured. This usually means GLIB is incorrectly installed.
configure: error: Test for GLIB failed. See the file 'INSTALL' for help.
=== END
What would be the best and/or quickest solution ? I would love to get the Gimp running but hesitate to change my Linux Version since everything else I need works perfectly.
Anonymous
almost 13 years ago
Tried this with te latest development version (2.9.1)
IT WORKS !! thanks
But this version works slowwwwly.
Any idea ?
MKirsch
about 13 years ago
I tried to follow the Tutorial but first, when i did the export cflags thing, this terminal was no longer able to compile. C compiler canot creat executable.
Then, when i updated babl as shown, and tried to compile again, ive got the same error that babl isnt right version and not the gegl one so i cannot get behind that step. Any advices?
Palehorse
about 13 years ago
I have been in IT for 10 years, and am 50 y/o MIT grad. I STILL would not dream of encouraging a layman to compile. You simple don't know what damage you can do, or even what the numbers mean. I shudder when I hear folks suggest PPAs too... BUT if linux is unimportant to you, a hobby on an old comp, hey have fun. But do expect to screw up. tip: clonezilla
David
about 13 years ago
Thanks very much for the ride!
Worked perfectly fine for me on Kubuntu 12.04 (x64)
@ erroneus: All commands used are well known stadard. If you feel unsecure about what is beeing done feel free to google "man " for explanations. You're welcome =)
kir0ul
about 13 years ago
The only thing was that it couldn't create some directories so I used "sudo make install -j5" at step 11, and it worked fine for me, thanks!
erroneus member for over 13 years erroneus 2 comments rated this topic with 3/5
over 13 years ago
I would like to see one for CentOS/RHEL.
What seems to be missing from this tutorial is an explanation of what is being done and why in many cases... you know, like "why use this option?" or what does it mean?
GiMP really needs to be more independant of the OS than it is in the case of Linux. GiMP started with Linux and somehow it's the hardest to get installed for anything but the bleeding edge distros? Some of use use GiMP for productivity you know.
blacktoon member for about 15 years blacktoon 1 comment
over 13 years ago
Its impossible to compile Gimp 2.8 using this tut. If you not a IT Expert you can compile gimp only by hazard and luck...this tut is for nothing...gimpuser wiki is for nothing...buying a book, forget it.
Gimp must be supported by Big Bill, I suggest, it's absolutly daunting using Gimp on Linux, it's seems more stupid than all the windows shit together. Poor world.
Muhammad Ifthikhar, Kannur, Mathamangalam
over 13 years ago
Thank you.
Enjoyed each steps.
Thank you...
suluke
over 13 years ago
For me, on Ubuntu 12.04 x64 gegl complained about missing glib and recommended building it from source. I could skip this by running
sudo apt-get install libglib2.0-dev
AC2
over 13 years ago
To compile and use Gimp 2.8 on Ubuntu Lucid 10.04 have a look at this:
http://ubuntuforums.org/showthread.php?p=11946325
FATj2112 member for over 13 years FATj2112 3 comments
over 13 years ago
Thanks for the tip,Linux is a no go for Me,I run windows 7.
I'm just a bit suprised that everything didn't come in one package with 2.8,I'm new at this & I really don't want to screw up my computer,I just want to learn how to create cool stuff!
quacero
over 13 years ago
thanks for this work, it's work fine on my Ubuntu 12.04.
redforce member for about 19 years redforce 230 comments
over 13 years ago
It's not *that* difficult. You're just not used to it because your distributor manages the packages for you. So if you don't want to dive into the details of compiling, you may just use an unofficial package or wait for the next release of your favourite Linux distribution. It will contain GIMP 2.8 for sure. For instance, Fedora 17 RC already comes with GIMP 2.8.
over 13 years ago
Why is this so difficult! I'm not an "I.T."!
This just confuses & frustrates Me!
tobyreme member for over 13 years tobyreme 1 comment
over 13 years ago
Compiling in Ubuntu 11.04
In Step 7, I downloaded babl soucre, but on trying to compile I received error msgs about a mismatch in the version number expected and the version number installed of libtool.
Running 'autoreconfig --force' fixed the error.
In Step 8, ditto.
I found this solution here:
http://askubuntu.com/questions/56937/babl-recreate-aclocal-m4-with-macros-from-libtool-2-4
Thanks
tobyreme
redgimp member for over 15 years redgimp 2 comments
over 13 years ago
Thank you morpheeze, you got me past step 5. I am currently working on step 8, trying to find missing libraries.
ceas member for over 13 years ceas 2 comments
over 13 years ago
line 4925: syntax error near unexpected token `2.2
line 4925: `LT_PREREQ(2.2)'
in step 7
how to deal with this
morpheeze
over 13 years ago
Enable Source Code in Software Sources for Step 5. Don't forget to sudo apt-get update before. After that Step 5 works.
redgimp member for over 15 years redgimp 2 comments rated this topic with 5/5
over 13 years ago
In step 5, sudo apt-get build-dep gimp, I get the error message:
Unable to find a source package for gimp. Can anyone indicate how to resolve this? I assume that the previous steps installed the necessary packages. Is Dexter Filmore's comment an indication of what to do?
spartan2276 member for over 14 years spartan2276 9 comments rated this topic with 5/5
over 13 years ago
Yeah but no...Here is a PPA for Ubuntu 12.04 and I think for 11.04 and 11.10.
sudo add-apt-repository ppa:otto-kesselgulasch/gimp
sudo apt-get update && sudo apt-get install gimp
Gaz
over 13 years ago
all OK up to step 5 - Os-x SL does not know the apt-get command, I get "sudo: apt-get: command not found"
so now I'm scuppered as you don't have the option to follow a os-x tut and no alternative is mentioned I guess I just have to wait for full versions (binaries) to come out for mac.
not what I'd call a release!!
Passer
over 13 years ago
unfortunatelly the following error appears while configuring gimp: configure: error: Package requirements (atk >= 2.2.0) were not met:
Requested 'atk >= 2.2.0' but version of Atk is 2.0.0
Dexter Filmore
over 13 years ago
On Ubuntu 11.10 I had to compile prexed to the gimp-2.8 dir:
babl
gdk-pixbuf
gegl
glib
gtk
pango
and install
automake-1.11
intltool
gtk-doc-tools
python-gtk2-dev
before the compile finally went through.
Some static test builds every once in a while would be nice.
Jarno
over 13 years ago
tried the PPA, and when i launched gimp, it said package manager managed to install wrong versions of gegl and babl.. so i installed 2.6.12 :/
mailinator
over 13 years ago
@Jarno: Except when it doesn't work ;) For instance, if you have a HP laptop:
https://bugzilla.gnome.org/show_bug.cgi?id=673387
There are problems, advantages and disadvantages on every platform. I think there will never be a computer where "everything works".
But if you don't want to compile yourself, you can use a repo like
https://launchpad.net/~otto-kesselgulasch/+archive/gimp/
(Click on "Technical details about this PPA" for installation instructions, it's really easy.)
Jarno
over 13 years ago
these are one of the moments i want to delete linux and install windows.
no problems with debendencies, missing libraries, outdated packagemanager repositories. no downloading 3 additional libraries or compiling sourcecode for hours... just 1 exe to double click and gimp is installed.
Kai
over 13 years ago
I had some troubles with step #7.
The gegl site lists getting gegl via git:
git clone git://git.gnome.org/gegl
and using
./autogen.sh --prefix=/opt/gimp-2.7
The wget version listed above did not. Hope it helps someone...
Olivier Pons
over 13 years ago
Ubuntu 10.04:
I've installed everything, now I get this message when I try "./configure -prefix=/opt/gimp-2.7":
checking for CAIRO... yes
checking for PANGOCAIRO... no
configure: error: Test for PangoCairo failed.
- We require Pango with the optional support for Cairo compiled in.
- See the file 'INSTALL' for more help.
What is strange is that if i do a :
find /opt/gimp-2.7 | grep cairo
there are a lot of files AND there IS this file:
/opt/gimp-2.7/lib/libpangocairo-1.0.so
So gimp should be able to compile, right???
The compile error is on the line 17008 in the compile file.
Any idea how to compile pango with the optional support for Cairo?
ebvienna
over 13 years ago
mamboze
over 13 years ago
Would this compilation run on Ubuntu 10.04. I've had a look thru the tutorial and there doesn't seem to be anything that is specifically 11.04 but I might be wrong.
BillyG member for over 13 years BillyG 1 comment rated this topic with 3/5
over 13 years ago
I have been attempting to compile GIMP version 2.7.4 with the instructions given in this article. After many adventures, made necessary by the far greater number of missing libraries, the configure script came down to the Python headers and then refused to compile because it could not find the Python 2.6 headers. I have looked. My Python headers are in /usr/python2.6. How do I proceed from here?
DzaDze member for over 13 years DzaDze 1 comment rated this topic with 4/5
over 13 years ago
Mine error:
What to do now ?
Peter
almost 14 years ago
brilliant! one window at last! thanks!
serge
about 14 years ago
Hi
I need also install plugin save for web. How i can do this?
Georgiy S
about 14 years ago
Thank you. I spent hours on this with 2.7.3, but it was worth it.
ill
about 14 years ago
this is the first time i try to compile something.
i could fix some error by realizing, that i have to correct the syntax in some cases (typographic " ", dashes etc.), but now i got stucked here:
:~/tmp/gimp$ ./autogen.sh --prefix=/opt/gimp-2.7
bash: ./autogen.sh: Datei oder Verzeichnis nicht gefunden
what did i do wrong?
SpEcIeS member for about 17 years SpEcIeS 133 comments
over 14 years ago
@billn: There is a PPA for gimp 2.7.2. But if you use it, you cannot install 2.7.2 beside 2.6. It will replace 2.6.
Just open a terminal and type:
sudo add-apt-repository ppa:matthaeus123/mrw-gimp-svn && sudo apt-get update && sudo apt-get-install gimp
billn
over 14 years ago
Will someone convert Gimp 2.7+ to a deb package so idiots like me can use it? I hope someone can help me...
Bryce
over 14 years ago
There are bugs filed against Ubuntu to update babl and gegl. See: https://launchpad.net/ubuntu/+source/babl
BN
over 14 years ago
Can you supply a solution to?
WARNING: aclocal's directory is /usr/share/aclocal, but...
no file /usr/share/aclocal/gtk-2.0.m4
You may see fatal macro warnings below.
If these files are installed in /some/dir, set the
ACLOCAL_FLAGS environment variable to "-I /some/dir"
or install /usr/share/aclocal/gtk-2.0.m4.
configure.ac:497: warning: macro `AM_PATH_GTK_2_0' not found in library
Bryce
over 14 years ago
Thanks SO MUCH. Though I think given how easy git is to install, you should rewrite to use git only. Then you'll have all the configure vs. autogen.sh issues worked out also.
BN
over 14 years ago
Stuck at:
configure.ac:509: error: possibly undefined macro: AM_PATH_GTK_2_0
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
Erasme
over 14 years ago
Hi and thank you redforce.
It worked perfectly.
I just didn't do export CFLAGS="-march=native". It made the configuration fail.
akovia member for almost 17 years akovia 1 comment rated this topic with 4/5
over 14 years ago
Got stuck at making babl:
Version mismatch error. This is libtool 2.4 Debian-2.4-2, but the
definition of this LT_INIT comes from libtool 2.2.6b.
You should recreate aclocal.m4 with macros from libtool 2.4 Debian-2.4-2
and run autoconf again.
I was about to go look for an updated version of libtool, but after reading comments about copying over all the themes, icons, and GTK, and other additional packages I'm not so sure anymore. My drive is getting a little low on space and not sure it's worth it anymore.
I would recommend cleaning up the additional information from the comments and adding it to the guide as a footnote. Thanks anyway though. I may revisit this again once I free up some space or can't wait any longer for some single window gimpness.
over 14 years ago
Addition: Since you use a different version of gtk+ for gimp 2.7.2, gimp will look awful. You need to copy the engines from /usr/lib/gtk-2.0/2.10.0/engines to /opt/gimp-2.7/lib/gtk-2.0/2.10.0/engines, the theme you are using from /usr/share/themes to /opt/gimp-2.7/share/themes and the icon theme your are using from /usr/share/icons to /opt/gimp-2.7/share/icons.
over 14 years ago
I'm compiling on 10.10 at the moment. I need newer versions of: glib, gtk+, gdk_pixbuf, cairo, pixman (for cairo).
You can get these packages with:
wget http://ftp.gnome.org/pub/GNOME/sources/gdk-pixbuf/2.22/gdk-pixbuf-2.22.1.tar.bz2
git clone git://anongit.freedesktop.org/git/cairo
git clone git://anongit.freedesktop.org/git/pixman.git
(see Granner's comment for glib and gtk+)
over 14 years ago
I think for Ubuntu 10.10, you need glib and maybe gdk_pixbuf
Granner member for almost 18 years Granner 21 comments rated this topic with 4/5
over 14 years ago
I also miss the right glib
Just do it with wget (version number is 2.28.3:
Go back to your /tmp/gimp/ folder.
cd ~/tmp/gimp/
wget http://ftp.gnome.org/pub/GNOME/sources/glib/2.28/glib-2.28.1.tar.bz2
then
tar -xjf glib-2.28.1.tar.bz2
Switch too:
cd ./glib-2.28.1
./configure -prefix=/opt/gimp-2.7.2
make -j3
--> that in my case i think you will use make -j5 or whatever
sudo make install
Afterwards you will see that you havn't the right GTK+ version. If so do the follow:
Go back to tmp/gimp folder again:
cd ~/tmp/gimp/
wget http://ftp.gnome.org/pub/GNOME/sources/gtk+/2.24/gtk+-2.24.3.tar.bz2
Then:
tar -xjf gtk+-2.24.3
and:
cd ./gtk+-2.24.3
make -j3
sudo make install
--> you see it is really easy and just try and error thing... godawful ...
MC-Photography member for almost 16 years MC-Photography 2 comments
over 14 years ago
Some comments:
You can use --disable-gtk-doc with autogen if you don't have or want "gtk-doc".
In step 6, you need to go to the babl-directory and run the "autogen" script, followed by "make" to install babl.
But I failed at missing or not finding Glib. So I need to work on that now first.
