random plugin loading problem
random plugin loading problem Jayesh Salvi 10 Feb 01:38
  random plugin loading problem Sven Neumann 10 Feb 13:22
  random plugin loading problem Jayesh Salvi 10 Feb 19:30
Jayesh Salvi
2008-02-10 01:38:04 UTC (about 17 years ago)
I wrote a plugin few days back (GimpPublishr)
to publish images to Flickr/Picasa. It was tried by many and I had received various complaints about plugin not getting loaded, even after deploying in right directory. In some cases they had hit a bug in plugin which would prevent Gimp from loading the plugin. In recent versions I fixed some bugs in the plugin and put a top level try-except block with a crash report dialog, so that any bug in plugin won't go unnoticed silently.
But even after that I kept hearing few cases where users won't see the plugin loaded and still won't get any crash report.
Today I started working on the same plugin again after some gap. Today I tried it under two different installations of Gimp - on my Fedora 8 desktop and in a Ubuntu VM. I am running same version of Gimp at both places, using same plugin files. Interestingly, the plugin doesn't load in my ubuntu VM, but it does in my Fedora 8 desktop. I cleaned my $HOME/.gimp-2.4 directory multiple times, but same result.
Note these observations: 1) I also noticed that when the plugin gets loaded successfully on my fedora box, the $HOME/.gimp-2.4/pluginrc file gets modified and I see following entry appended to it:
(plug-in-def "/home/jayesh/.gimp-2.4/plug-ins/publishr.py" 1202602069
I don't see that happening on Ubuntu VM.
2) On BOTH the systems, when the Gimp splash image is diplaying the plugins it is loading at startup, I DO SEE publishr.py (my plugin file) being loaded. But I doubt that the register() function gets called in the ubuntu case. I put a deliberate "raise Exception" just before register() function, however it doesn't make any difference.
Both are running same gimp version. $ gimp --version
GNU Image Manipulation Program version 2.4.0-rc3
The dump of gimprc is same on both systems (except for the web-browser parameter). For Fedora 8 it is as follows.
$ gimp --dump-gimprc # Dump of the GIMP default configuration
(temp-path "${gimp_dir}/tmp") (swap-path "${gimp_dir}")
(num-processors 1)
(tile-cache-size 1024M)
(interpolation-type cubic)
(plug-in-path "${gimp_dir}/plug-ins:${gimp_plug_in_dir}/plug-ins") (module-path "${gimp_dir}/modules:${gimp_plug_in_dir}/modules") (interpreter-path
"${gimp_dir}/interpreters:${gimp_plug_in_dir}/interpreters") (environ-path "${gimp_dir}/environ:${gimp_plug_in_dir}/environ") (brush-path "${gimp_dir}/brushes:${gimp_data_dir}/brushes") (brush-path-writable "${gimp_dir}/brushes") (pattern-path "${gimp_dir}/patterns:${gimp_data_dir}/patterns") (pattern-path-writable "${gimp_dir}/patterns") (palette-path "${gimp_dir}/palettes:${gimp_data_dir}/palettes") (palette-path-writable "${gimp_dir}/palettes") (gradient-path "${gimp_dir}/gradients:${gimp_data_dir}/gradients") (gradient-path-writable "${gimp_dir}/gradients") (font-path "${gimp_dir}/fonts:${gimp_data_dir}/fonts") (default-brush "Circle (11)")
(default-pattern "Pine")
(default-palette "Default")
(default-gradient "FG to BG (RGB)")
(default-font "Sans")
(global-brush yes)
(global-pattern yes)
(global-palette yes)
(global-gradient yes)
(global-font yes)
(default-image
(width 420)
(height 300)
(unit pixels)
(xresolution 72.000000)
(yresolution 72.000000)
(resolution-unit inches)
(image-type rgb)
(fill-type background-fill)
(comment "Created with GIMP"))
(default-grid
(style intersections)
(fgcolor (color-rgba 0.000000 0.000000 0.000000 1.000000)) (bgcolor (color-rgba 1.000000 1.000000 1.000000 1.000000)) (xspacing 32.000000)
(yspacing 32.000000)
(spacing-unit inches)
(xoffset 0.000000)
(yoffset 0.000000)
(offset-unit inches))
(undo-levels 5)
(undo-size 64M)
(undo-preview-size large)
(plug-in-history-size 10)
(pluginrc-path "${gimp_dir}/pluginrc") (layer-previews yes)
(layer-preview-size medium)
(thumbnail-size normal)
(thumbnail-filesize-limit 4M)
(install-colormap no)
(min-colors 144)
(color-management
(mode display)
(display-profile-from-gdk yes)
(display-rendering-intent perceptual) (simulation-rendering-intent perceptual) (display-module "CdisplayLcms")) (color-profile-policy ask)
(save-document-history yes)
(transparency-size medium-checks)
(transparency-type gray-checks)
(snap-distance 8)
(marching-ants-speed 100)
(resize-windows-on-zoom no)
(resize-windows-on-resize no)
(default-dot-for-dot yes)
(initial-zoom-to-fit yes)
(perfect-mouse yes)
(cursor-mode tool-icon)
(cursor-updating yes)
(show-brush-outline yes)
(show-paint-tool-cursor yes)
(image-title-format "%D*%f-%p.%i (%t, %L) %wx%h") (image-status-format "%n (%m)")
(confirm-on-close yes)
(monitor-xresolution 96.000000)
(monitor-yresolution 96.000000)
(monitor-resolution-from-windowing-system yes) (navigation-preview-size medium)
(default-view
(show-menubar yes)
(show-rulers yes)
(show-scrollbars yes)
(show-statusbar yes)
(show-selection yes)
(show-layer-boundary yes)
(show-guides yes)
(show-grid no)
(show-sample-points yes)
(padding-mode default)
(padding-color (color-rgb 1.000000 1.000000 1.000000))) (default-fullscreen-view
(show-menubar yes)
(show-rulers yes)
(show-guides yes)
(show-grid no)
(padding-color (color-rgb 1.000000 1.000000 1.000000))) (activate-on-focus yes)
(space-bar-action pan)
(xor-color (color-rgb 0.501961 1.000000 0.501961)) (default-threshold 15)
(move-tool-changes-active no)
(trust-dirty-flag no)
(save-device-status no)
(save-session-info yes)
(restore-session yes)
(save-tool-options no)
(show-tips yes)
(show-tooltips yes)
(tearoff-menus yes)
(can-change-accels no)
(save-accels yes)
(restore-accels yes)
(menu-mnemonics yes)
(last-opened-size 10)
(max-new-image-size 128M)
(toolbox-color-area yes)
(toolbox-foo-area no)
(toolbox-image-area no)
(theme-path "${gimp_dir}/themes:${gimp_data_dir}/themes") (theme "Default")
(use-help yes)
(show-help-button yes)
(help-locales "")
(help-browser gimp)
(web-browser "htmlview %s")
(toolbox-window-hint normal)
(dock-window-hint normal)
(transient-docks no)
(cursor-format pixbuf)
(fractalexplorer-path
"${gimp_dir}/fractalexplorer:${gimp_data_dir}/fractalexplorer") (gfig-path "${gimp_dir}/gfig:${gimp_data_dir}/gfig") (gflare-path "${gimp_dir}/gflare:${gimp_data_dir}/gflare") (gimpressionist-path
"${gimp_dir}/gimpressionist:${gimp_data_dir}/gimpressionist") (script-fu-path "${gimp_dir}/scripts:${gimp_data_dir}/scripts")
Can someone help me understand the plugin load mechanism? What variables (built-in/environment/config) play role in plugin loading?
Thanks, Jayesh
2008-02-10 13:22:31 UTC (about 17 years ago)
Most probably those users either don't have GIMP with Python support or they did not set the executable bit on the plug-in.
Jayesh Salvi
2008-02-10 19:30:29 UTC (about 17 years ago)
I got it, at least in my case that is.
On ubuntu gimp-python is a separate package, unlike fedora. When I installed gimp-python, it works.
Jayesh
Jayesh Salvi wrote:
I wrote a plugin few days back (GimpPublishr ) to publish
(num-processors 1)
(global-brush yes)
(global-font yes)
(default-image
(width 420)
(height 300)
(unit pixels)
(image-type rgb)
(default-grid
(xoffset 0.000000)
(yoffset 0.000000)
(undo-levels 5)
(undo-size 64M)
(min-colors 144)
(color-management
(mode display)
(snap-distance 8)
(perfect-mouse yes)
(default-view
(show-menubar yes)
(show-rulers yes)
(show-guides yes)
(show-grid no)
(show-menubar yes)
(show-rulers yes)
(show-guides yes)
(show-grid no)
(show-tips yes)
(show-tooltips yes)
(tearoff-menus yes)
(save-accels yes)
(use-help yes)
(help-locales "")
(help-browser gimp)
Thanks, Jayesh
