Crop to selection not working
Crop to selection not working shugazi 21 Aug 14:02
  Crop to selection not working sillyfrog 25 Aug 05:14
   Crop to selection not working shugazi 27 Aug 14:42
    Crop to selection not working MJohnsontenthousand 01 Oct 11:37
  Crop to selection not working stav 03 Apr 22:02
2018-08-21 14:02:16 UTC (over 6 years ago)
Hey there! All of a sudden, the "Crop to Selection" option is grayed out for me under both Image and Layer. I've tried different file types, existing files, new files... I've unistalled & reinstalled Gimp. It still won't let me crop anything no matter what I try! Any suggestions?
I'm on Windows 7 (64-bit ) running the latest version of Gimp (2.10.6)
Thank you!
2018-08-25 05:14:46 UTC (over 6 years ago)
Thank you!
I had the same issue, after much messing around I found that my selection tool mode was set to "Subtract", not the normal default of "Replace". No idea how I did this, but it stayed that way even after a reboot.
I found if I double clicked on the selection tool, it would highlight the configuration, and at the top there I could change the mode back to normal (also using Shift would do what I needed).
Hopefully this helps someone else!
2018-08-27 14:42:29 UTC (over 6 years ago)
THANK YOU SO MUCH. This solved it for me, I thought I was going crazy. Thank you!
2018-10-01 11:37:26 UTC (over 6 years ago)
Thank both of you, humans from the far distant past. You have saved that bitch I was about to choke, and she will be forced to build statues to honor you.
2019-04-03 22:02:07 UTC (about 6 years ago)
Yes, the answers here helped me, I had to change the Rectangle Select Mode to "Replace" and then select again; thanks!
