Resolution
7 of 7 messages available
Resolution leon.white140@ntlworld.com 14 Dec 17:27
  Resolution Richard Gitschlag 14 Dec 17:58
  Resolution Alexandre Prokoudine 14 Dec 18:00
  Resolution Barry Say 14 Dec 20:19
   Resolution Greg Chapman 15 Dec 00:30
   Resolution Richard Gitschlag 15 Dec 09:15
   Resolution Barry Say 15 Dec 09:38
2012-12-14 17:27:35 UTC (over 12 years ago)
Resolution
Is there a way to change the resolution of a picture without it changing the size.
I cannot find a way to separate the two..
Thanks...Leon
Richard Gitschlag
2012-12-14 17:58:56 UTC (over 12 years ago)
Resolution
It's under "Image > Print Size...".
From: leon.white140@ntlworld.com To: gimp-user-list@gnome.org
Date: Fri, 14 Dec 2012 17:27:35 +0000 Subject: [Gimp-user] Resolution
Thanks...Leon
gimp-user-list mailing list
https://mail.gnome.org/mailman/listinfo/gimp-user-list 		 	   		  =
2012-12-14 18:00:03 UTC (over 12 years ago)
Resolution
Are you looking for Image / Print Size ?
Barry Say
2012-12-14 20:19:39 UTC (over 12 years ago)
Resolution
Hi Leon,
1. If you select Image > Scale Image, The Scale image box opens. 2, Change the Image Size units to something convenient. 3. Note the width.
4. Change the resolution to what you require. 5. Change the width back to the original size, the height will follow. 6. Select Scale Image
The size of the image will remain the same in cm but its size in pixels will change. I often do this to publish scans on the internet. I regularly scan stuff at 300 dpi and preserve this as a record, but I will generally reduce the resolution to 100dpi fore web publishing to save on bandwidth.
Barry
I cannot find a way to separate the two.. Thanks...Leon
Greg Chapman
2012-12-15 00:30:21 UTC (over 12 years ago)
Resolution
Hi Barry,
If you are saying that you scan to a PDF then that is entirely appropriate if your intention is to produce a small file that a site's visitors will download and print.
However, in case newcomers are reading, it should be pointed out that it is pretty pointless for an image to be displayed on a web page, where dpi is completely irrelevant. For screen display all that matters are pixels. For that purpose you scale to the desired width and height in pixels. Adjusting X or Y resolution (i.e. dpi) is meaningless.
Greg Chapman
http://www.gregtutor.plus.com
Helping new users of KompoZer and The GIMP
Richard Gitschlag
2012-12-15 09:15:37 UTC (over 12 years ago)
Resolution
I wonder, is there any way to automate those steps ....
Date: Fri, 14 Dec 2012 20:19:39 +0000 From: barry12@nspipes.co.uk
Subject: Re: [Gimp-user] Resolution
Hi Leon,
3. Note the width.
Barry
Barry Say
2012-12-15 09:38:05 UTC (over 12 years ago)
Resolution
A small clarification.
I do a lot of stuff with A5 pages. At 100 dpi an A5 image will turn out at at about 825 x 1175 pixels. I find this gives sufficient resolution for most purposes, looks good when displayed at native size on the screen, and is the appropriate size to store as a page in an .odt document which can then be transformed to a .pdf which is reasonably economic in size. Thus a single image file can serve many purposes and if I wish to refine the post processing to improve quality or reduce storage overheads then I only have one file to worry about thus making maintenance more straightforward.
Yes, I was a bit wooly in my description, but I think the method works.
Barry
On 12/14/2012 08:19 PM, Barry Say wrote:
Hi Leon,
Barry
