problem with brush dynamics
12 of 12 messages available
problem with brush dynamics friesenlyle 07 May 19:46
  problem with brush dynamics narkfestmojo 07 May 22:30
  problem with brush dynamics Michael Schumacher 07 May 22:33
   problem with brush dynamics narkfestmojo 07 May 22:58
    problem with brush dynamics Jody 09 May 20:52
    problem with brush dynamics Leo_in_NJ 12 May 04:19
     problem with brush dynamics Alexandre Prokoudine 12 May 05:38
      problem with brush dynamics Leo_in_NJ 12 May 08:44
   problem with brush dynamics friesenlyle 07 May 23:36
    problem with brush dynamics Madeleine Fisher 08 May 17:59
  problem with brush dynamics Jody 09 May 20:41
   problem with brush dynamics Alexandre Prokoudine 09 May 20:49
2012-05-07 19:46:12 UTC (almost 13 years ago)
Am I the only one or are there others. The brush dynamics matrix is all greyed out and there is no way to activate it. Maybe Im doing something wrong. I understand that you can either set the brush dynamics preset or set the matrix. Also the curve editor doesnt seem to be working either. HELP!!!
2012-05-07 22:30:52 UTC (almost 13 years ago)
Having exact same problem; it looks like the design intent of the program is for you to adjust, modify and add to brush dynamics, yet it doesn't seem to work. The brush dynamics from version 2.6 were a lot better then this... sorry, but sometimes simpler is better.
I am using the x64 version on Windows 7 HP x64
2012-05-07 22:33:11 UTC (almost 13 years ago)
Did you create a copy of the dynamics? THhe ones that come with GIMP are not editable (same for other resources, e.g. brushes).
Regards, Michael
2012-05-07 22:58:37 UTC (almost 13 years ago)
OK, just tried this and it works.
Open 'dynamics menu' and duplicate one of the presets then you can access the duplicated preset in 'dynamic menu editor' and do what you want.
Thanks Michael
2012-05-07 23:36:57 UTC (almost 13 years ago)
Awe sweet. Its working. Where was my brain. Thanx Mikael
Madeleine Fisher
2012-05-08 17:59:27 UTC (almost 13 years ago)
I made my own personal one--a new dynamic setting works, too.
-- friesenlyle (via gimpusers.com)
gimp-user-list@gnome.org
2012-05-09 20:41:51 UTC (almost 13 years ago)
The brush dynamics matrix and curve editor also don't work for me.
2012-05-09 20:49:46 UTC (almost 13 years ago)
The solution is the same: duplicate the preset.
2012-05-09 20:52:38 UTC (almost 13 years ago)
Thanks Michael
Thanks! I did not know how to do that. That works for me as well. Jody
2012-05-12 04:19:40 UTC (almost 13 years ago)
OK, so how do you copy the dynamics? I can't find a "Dynamics Menu" I found the dynamics editor, but its menu has nothing but a checkbox reading "Edit active dynamics".
Hate it when you can't get to step 1.
Thanks Michael
2012-05-12 05:38:33 UTC (almost 13 years ago)
Sorry, I thought it was pretty obvious that you do it inthe list of brush dynamics presets, not in the editor :)
2012-05-12 08:44:28 UTC (almost 13 years ago)
Stumbled upon it. Paint dynamics is a new dockable diaglog, found under the Windows menu.
