Problem script-fu gimp-text-layer-get-text
Problem script-fu gimp-text-layer-get-text Volker Lenhardt 08 Aug 10:57
  Problem script-fu gimp-text-layer-get-text Ofnuts 08 Aug 19:00
   Problem script-fu gimp-text-layer-get-text Volker Lenhardt 08 Aug 21:21
    Problem script-fu gimp-text-layer-get-text Rob Antonishen 09 Aug 12:53
     Problem script-fu gimp-text-layer-get-text Volker Lenhardt 09 Aug 16:40
Volker Lenhardt
2011-08-08 10:57:19 UTC (over 13 years ago)
Gimp 2.6.8 on Linux openSUSE 11.3
I need to extract text and font from a text layer. No problem, I thought, with gimp-text-layer-get-text and gimp-text-layer-get-font.
But I find that the original text layer was cropped with plug-in-autocrop-layer. Nevertheless Gimp lets me edit the text with the text edit tool - after a confirmation dialog.
But I can't get the text with script-fu. Is there a way to manage it? There are many files involved.
Volker
2011-08-08 19:00:47 UTC (over 13 years ago)
The layer name is "usually" the text contents, so instead of getting the text you can retrieve the name. Your Mileage May Vary.
Volker Lenhardt
2011-08-08 21:21:37 UTC (over 13 years ago)
Am 08.08.2011 21:00, schrieb Ofnuts:
It does vary, I'm sorry for it. Thank you all the same.
Volker
Rob Antonishen
2011-08-09 12:53:46 UTC (over 13 years ago)
You can access it using sed/grep or some such tool. Opening the xcf file in a text editor, even after an autocrop, the text information remains in the following format:
(text "test text") (font "Sans")
(font-size 18.000000)
(font-size-unit pixels)
(hinting yes)
(antialias yes)
(language "en-us")
(base-direction ltr)
(color (color-rgb 0.000000 0.000000 0.000000)) (justify left)
(box-mode dynamic)
(box-unit pixels)
I posted a grep example here: http://registry.gimp.org/node/25145#comment-11229
-Rob A>
Volker _______________________________________________ Gimp-user mailing list
Volker Lenhardt
2011-08-09 16:40:57 UTC (over 13 years ago)
Am 09.08.2011 14:53, schrieb Rob Antonishen:
(hinting yes)
(antialias yes)
(language "en-us")
(box-mode dynamic)
(box-unit pixels)
-Rob A>
Thank you very much indeed. That's the solution. I'll make me a script to meet my needs.
Volker
Volker
