Huion tablets compatibility check request
Huion tablets compatibility check request torba 29 Jul 09:49
  Huion tablets compatibility check request Ross Martinek 29 Jul 19:28
   Huion tablets compatibility check request torba 29 Jul 19:54
    Huion tablets compatibility check request Ross Martinek 01 Aug 22:30
   Huion tablets compatibility check request Richard 03 Aug 15:53
    Huion tablets compatibility check request Ross Martinek 03 Aug 16:07
2017-07-29 09:49:05 UTC (over 7 years ago)
With recent versions of Gimp I'm experiencing problems with my Huion h610pro tablet. Clicking on canvas makes a single mark but dragging the stylus doesn't move the cursor at all. Tools that use single clicks work without problems. The last version of Gimp that works fine is 2.8.18. Is this something that the Gimp team could look into for future patches? I really like the new additions in 2.8.22 and I'm bummed out that I have to miss out on these.
My huion driver is a custom version of v11.
There's also another problem - often the tool changes when the stylus touches the tablet. Sometimes it's enough to cycle through a few tools and the choice sticks.
PS: I already posted here:
http://www.gimpusers.com/mailmsg.php?88192%40forums.gimpusers.com so feel free to remove this post if necessary.
Ross Martinek
2017-07-29 19:28:29 UTC (over 7 years ago)
Glad I didn’t update beyond 2.8.18.
You didn’t mention what OS you use. This would be useful for diagnostics, and so it could be determined whether this was a Windows, Mac, or Linux problem.
I’m on a Mac, OS 10.12.6, running Huion driver V11.1.8. Works fine with GIMP 2.8.18. It would be a disaster if I upgraded and suddenly couldn’t use the tablet.
In my configuration, GIMP always wants to see the pen set as airbrush at startup. I usually have to select another tool three times before it takes. Thereafter it’s fine.
Ross
On Jul 29, 2017, at 4:49 AM, torba wrote:
Hello, With recent versions of Gimp I'm experiencing problems with my Huion h610pro tablet.
PS:
-- torba (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
2017-07-29 19:54:15 UTC (over 7 years ago)
Yes, I forgot to post my system specs, didn't want to multiply the posts so I just included them in my profile. Anyway, it's:
Win10 64bit Anniversary update
on a Medion Erazer x7817
i7-3610QM,
12 gigs of ram
and only integrated gpu.
cheers
Ross
Ross Martinek
2017-08-01 22:30:11 UTC (over 7 years ago)
Oh FRAK. Can’t help with Windows. Hopefully someone using that OS will be able to help.
Best of luck,
Ross
Anyway, it's:
i7-3610QM,
12 gigs of ram
cheers
Ross
Richard
2017-08-03 15:53:39 UTC (over 7 years ago)
About the only people who can truly help you are those running GIMP (similar version) on Windows (preferably 10) with a same/similar brand tablet as yours ... and there probably aren't many on this list who do. That leaves the rest of us just guessing at answers...
For starters, GIMP is indeed configured to have the stylus pen assigned to Airbrush and the stylus eraser assigned to Eraser by default, both of which are separate from the tool associated with the core mouse pointer (Paintbrush, I think). This IS configurable, however ... under Edit > Preferences > Input Devices, you can allow GIMP to save the device->tool mappings upon exit or you can manually save them so it will start with your preferred tools per device.
Sent: Saturday, July 29, 2017 12:28:29 PM
To: torba
Cc: gimp-user-list@gnome.org; notifications@gimpusers.com
Subject: Re: [Gimp-user] Huion tablets compatibility check request
Glad I didnt update beyond 2.8.18.
You didnt mention what OS you use. This would be useful for diagnostics, and so it could be determined whether this was a Windows, Mac, or Linux problem.
Im on a Mac, OS 10.12.6, running Huion driver V11.1.8. Works fine with GIMP 2.8.18. It would be a disaster if I upgraded and suddenly couldnt use the tablet.
In my configuration, GIMP always wants to see the pen set as airbrush at startup. I usually have to select another tool three times before it takes. Thereafter its fine.
Ross
> Hello,
> tablet.
> cursor at all.
> out on these.
> sticks.
> PS:
> List address:    gimp-user-list@gnome.org
> List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
> List archives:   https://mail.gnome.org/archives/gimp-user-list
Ross Martinek
2017-08-03 16:07:01 UTC (over 7 years ago)
Does this work on a Mac? I don’t recall GIMP recognizing the Huion tablet and stylus in that dialog, though they seem to work well except for this default.
Ross
Numbers may not lie, but neither do they tell the whole truth. From: gimp-user-list > on behalf of Ross Martinek > Sent: Saturday, July 29, 2017 12:28:29 PM To: torba
Cc: gimp-user-list@gnome.org ; notifications@gimpusers.com Subject: Re: [Gimp-user] Huion tablets compatibility check request
Ross
PS:
-- torba (via www.gimpusers.com/forums ) _______________________________________________ gimp-user-list mailing list
