Need help for gegl translation
| Need help for gegl translation | Julien Hardelin | 25 Aug 14:44 |
| Need help for gegl translation | Peter O'Regan | 27 Aug 11:28 |
| Need help for gegl translation | Julien Hardelin | 27 Aug 18:59 |
To translate gegl correctly, I need to understand. And I don't understand well some strings, not finding explanations on the Web:
-/"how wide peel off bands for ink order vis"/
What is "vis"?
- "/Do a chain of operations, with key=value pairs after each operation
name to "//
//"set properties. And aux=[ source filter ] for specifying a chain with
a "//
//"source as something connected to an aux pad."/
"aux pad" : auxiliary tablet computer?
- /"Changes the light level and contrast. This operation operates in
linear "//
//"light, 'contrast' is a scale factor around 50%% gray, and
'brightness' a "//
//"constant offset to apply after contrast scaling."/
"50%% gray": 50%?
I hope I don't disturb you too much.
Julien Hardelin
Hi Julien,
I'm not in front of the reference right now, but from the context you've provided it appears Vis would be shorthand for visibility. I'd guess that's dealing with some layer order drawing rules.
Aux pad is an auxiliary input to the gegl chain. If you envision the tree-like structure connecting processing elements, the Aux pad wouldn't be connected along the main input / output line. Instead it could be from anywhere in the pipeline (including an independent element or self sufficient generator like white noise) . Pad is a synonym for the connection point which comes from circuit board terminology.
50% gray is a color reference that is standard terminology in image processing. Because we as humans don't perceive contrast linearly, 50% gray does not correspond to the midpoint of the color scale (e.g. 127/255 if you were in 8-bits). You can read a bit more about it here: https://en.m.wikipedia.org/wiki/Middle_gray
Hope that helps!
Peter
What is "vis"?
- "/Do a chain of operations, with key=value pairs after each operation name to "//
//"set properties. And aux=[ source filter ] for specifying a chain with a "//
//"source as something connected to an aux pad."/"aux pad" : auxiliary tablet computer?
- /"Changes the light level and contrast. This operation operates in linear "//
//"light, 'contrast' is a scale factor around 50%% gray, and 'brightness' a "//
//"constant offset to apply after contrast scaling."/"50%% gray": 50%?
Julien Hardelin
List address: gimp-developer-list@gnome.org List membership: https://mail.gnome.org/mailman /listinfo/gimp-developer-list
List archives: https://mail.gnome.org/archives/gimp-developer-list
Thank you, Peter.
Le 27/08/2016 13:28, Peter O'Regan a crit :
Hi Julien,
Hope that helps!
Peter
What is "vis"?
Julien Hardelin
List archives: https://mail.gnome.org/archives/gimp-developer-list_______________________________________________ gimp-developer-list mailing list
