Cubic Interpolation vs No Halo
14 of 14 messages available
Cubic Interpolation vs No Halo C R 27 Apr 08:03
  Cubic Interpolation vs No Halo Liam R. E. Quin 27 Apr 17:09
   Cubic Interpolation vs No Halo C R 28 Apr 06:58
   Cubic Interpolation vs No Halo Nicolas Robidoux 28 Apr 22:59
    Cubic Interpolation vs No Halo Liam R. E. Quin 28 Apr 23:34
     Cubic Interpolation vs No Halo C R 29 Apr 06:31
      Cubic Interpolation vs No Halo Nicolas Robidoux 02 May 20:24
  Cubic Interpolation vs No Halo Øyvind Kolås 07 May 13:38
   Cubic Interpolation vs No Halo C R 07 May 15:00
   Cubic Interpolation vs No Halo Karl Günter Wünsch 09 May 10:11
    Cubic Interpolation vs No Halo Øyvind Kolås 09 May 13:16
     Cubic Interpolation vs No Halo Akkana Peck 09 May 15:15
      Cubic Interpolation vs No Halo C R 14 May 12:21
    Cubic Interpolation vs No Halo Alexandre Prokoudine 09 May 14:47
C R
2016-04-27 08:03:15 UTC (about 9 years ago)
I assume the reasoning behind using cubic as the default for all the scale and transform tools is to cut back on the complaints of how slow GIMP is at the moment, but the quality loss in the current cubic interpolation algorithm is quite bad.
Can we shift the default to No Halo or Lo Halo? Also, it's probably safe to assume that if the user chooses an interpolation type in the tool, they are saying something about the quality of the results they are after vs speed. I think setting the value in one tool should set the value automatically in other tools, and treat it as a "global" value of sorts.
It's just that I spend a lot of time lately switching to No halo for my professional work.
Thoughts?
-C
Liam R. E. Quin
2016-04-27 17:09:48 UTC (about 9 years ago)
It depends on what you're doing - in some cases Cubic gives better results. In addition nohalo and lohalo can take several minutes to scale an image.
You can change the default tool option in preferences/tool options.
I'd rather see it moved out of tool options and into preferences with a single setting in that case. In practice I fairly often copy a small section of an image and experiment with a cobination of blur and different downsizing algorithms. In addition, more upscaling options would be good, maybe after 2.10 - waifu2x, if unencumbered, would be a good candidate. So I think having the algorithm choice right there in scale image makes experimentation easier, and helps people dscover the option.
So maybe a preference to say the default would be good. And hey! there is one :-)
Liam
Liam R. E. Quin
C R
2016-04-28 06:58:10 UTC (about 9 years ago)
Thanks Liam. I suppose this will work okay for my purpose. Thanks for the tip.
-C
Liam
Liam R. E. Quin
Nicolas Robidoux
2016-04-28 22:59:11 UTC (about 9 years ago)
Liam:
Do you ever find LoHalo (snail crawling notwithstanding) worthwhile?
Nicolas
Liam R. E. Quin
2016-04-28 23:34:31 UTC (about 9 years ago)
On Fri, 2016-04-29 at 00:59 +0200, Nicolas Robidoux wrote:
Liam:
Yes, but because it's so slow I use it less than once a month.
It feels like it takes half an hour or so, but I suspect it's probably more like 10 minutes.
Most often I'm working with scanned engravings that have lots of almost-parallel almost-horizontal lines, and the trouble is moiré-like patterns that creep in. A gaussian blur before down-scaling, followed by a sharpen, usually helps. We lost the old gimp 2.6 sharpen filter, but the newer unsharp filter works.
Sometimes lohalo scales down without introducing the problems.
Liam
Liam R. E. Quin
C R
2016-04-29 06:31:00 UTC (about 9 years ago)
Are there plans to fix the cubic interpolation so it doesn't toss away quite so much resolution?
It seems to me it didn't do that quite so much before.
-C
Liam:
Liam
-- Liam R. E. Quin
Nicolas Robidoux
2016-05-02 20:24:33 UTC (about 9 years ago)
I suspect that it would make very little difference when downsampling, but maybe sigmoidization, as used in LoHalo, is not worth the computational cost.
Very easy to modify the code:
Remove the extended_sigmoidal and inverse_sigmoidal function definitions, and then replace these strings (which trigger the function calls) by nothing throughout
https://git.gnome.org/browse/gegl/tree/gegl/buffer/gegl-sampler-lohalo.c
I also wonder if the nested ifs in the downsampling component should be replaced by non-nested branches (that contain the previous tests, but are not nested).
Øyvind Kolås
2016-05-07 13:38:42 UTC (about 9 years ago)
I've pushed code to GEGL master that makes the resamplers called "linear" and "cubic" do a tiny bit more than just interpolation. These operations now do a (possibly sparse) box-filtering when scaling down instead of scaling up. Doing point sampling with interpolated values is probably not what a user expect "cubic" or "linear" scaling down to be anyways,. even if this is what it currently is. GEGL now does a 2x2 averaging of values for bilinear and a 4x4 sparse box filter averaging for cubic. Due to how this code uses whole pixels for averaging it might yield slightly sharper result than nohalo in many cases.
C R
2016-05-07 15:00:07 UTC (about 9 years ago)
Awesome! Thanks. :) It will be great to get a decent result from cubic again.
-C
scale
at
quality
Karl Günter Wünsch
2016-05-09 10:11:11 UTC (about 9 years ago)
The more you change the default behavior of existing filters the more it makes the use of GIMP impossible in a setup where you build up a workflow... It's bad enough to outright drop the previously available scaling algorithm but to tinker and thus in some cases invalidate existing workflows without the user being made aware of it is ridiculous for a tool like the GIMP...
I would ask you to reinstate the old code and have the new selectable under a new name - then at least an existing workflow could remain intact and the user would be made aware (a little bit at least) that there may be something better available...
regards Karl Gnter Wnsch
Øyvind Kolås
2016-05-09 13:16:22 UTC (about 9 years ago)
This was a fix for the 2.9 series - any releases of 2.9 thus far have been development snapshots and you shouldn't be establishing unchangable workflows based on the behavior of development snapshots. The new behavior you will get from cubic and linear *resamplers* in GIMP master + GEGL master resembles what the stable releases of GIMP have been doing for at least the last half decade, whereas GIMP 2.9 for a while has produced the equivalent of slightly randomized nearest neighbor when scaling down with cubic and linear. Other things that might happen for 2.10 is lanczos being reinstated if *you (or someone you convince)* implement lanczos as a GeglSampler, and the nohalo sampler being dropped unless it starts having performance of similar magnitude to nearest/linear/cubic/lohalo.
Nope - won't happen. Linear and cubic resamplers should provide reasonable results - instead of a random broken thing, which is why I also implemented similar fixes to GIMP itself early in the 2.x series. If you've been blurring your photos before scaling them down with cubic to compensate for cubic being broken in 2.9, you should no longer be doing so.
/pippin
2016-05-09 14:47:58 UTC (about 9 years ago)
I would ask you to begin with carefully evaluating the impact of the changes by testing a newer build of GIMP, *then* posting to this mailing list on the subject. That way we would be sure that whatever your claim is, it is based on having hands-on experience with what you talk about. Thank you.
Alex
Akkana Peck
2016-05-09 15:15:05 UTC (about 9 years ago)
yvind Kols writes:
As someone who down-scales a lot (and who expects workflow and defaults to change now and then when using development releases), I want to thank yvind for the new code. Downscaling with Cubic looks much better now (compared to the previous 2.9 behavior), and is much faster than LoHalo/NoHalo. Good stuff!
...Akkana
C R
2016-05-14 12:21:41 UTC (about 9 years ago)
Cubic seems to be giving much better results now. Thanks again Øyvind! I no longer feel it necessary to always switch to NoHalo. Thankyou thankyou thankyou!
Much respect,
-C
it
ridiculous
Øyvind Kolås writes:
As someone who down-scales a lot (and who expects workflow and defaults to change now and then when using development releases), I want to thank Øyvind for the new code. Downscaling with Cubic looks much better now (compared to the previous 2.9 behavior), and is much faster than LoHalo/NoHalo. Good stuff!
...Akkana _______________________________________________ gimp-developer-list mailing list
https://mail.gnome.org/mailman/listinfo/gimp-developer-list List archives: https://mail.gnome.org/archives/gimp-developer-list
