Why the endless background conversions between linear and regular sRGB TRC?
28 of 28 messages available
Why the endless background conversions between linear and regular sRGB TRC? Elle Stone 29 Aug 17:03
  Why the endless background conversions between linear and regular sRGB TRC? Simon Budig 29 Aug 18:42
   Why the endless background conversions between linear and regular sRGB TRC? Elle Stone 29 Aug 23:01
    Why the endless background conversions between linear and regular sRGB TRC? Jon Nordby 30 Aug 10:11
     Why the endless background conversions between linear and regular sRGB TRC? Jon Nordby 30 Aug 11:12
     Why the endless background conversions between linear and regular sRGB TRC? Elle Stone 30 Aug 11:55
      Why the endless background conversions between linear and regular sRGB TRC? Michael Natterer 30 Aug 12:30
      Why the endless background conversions between linear and regular sRGB TRC? Alexandre Prokoudine 30 Aug 12:41
       Why the endless background conversions between linear and regular sRGB TRC? Alexandre Prokoudine 30 Aug 12:42
      Why the endless background conversions between linear and regular sRGB TRC? Tobias Oelgarte 30 Aug 12:45
      Why the endless background conversions between linear and regular sRGB TRC? Jon Nordby 30 Aug 13:48
  Why the endless background conversions between linear and regular sRGB TRC? Jon Nordby 29 Aug 19:07
  Why the endless background conversions between linear and regular sRGB TRC? Øyvind Kolås 30 Aug 16:17
   Why the endless background conversions between linear and regular sRGB TRC? Elle Stone 30 Aug 18:08
    Why the endless background conversions between linear and regular sRGB TRC? Øyvind Kolås 30 Aug 22:30
     Why the endless background conversions between linear and regular sRGB TRC? Øyvind Kolås 30 Aug 23:01
      Why the endless background conversions between linear and regular sRGB TRC? Elle Stone 31 Aug 15:37
       Why the endless background conversions between linear and regular sRGB TRC? Alexandre Prokoudine 31 Aug 15:51
        Why the endless background conversions between linear and regular sRGB TRC? Elle Stone 31 Aug 16:27
         Why the endless background conversions between linear and regular sRGB TRC? Tobias Oelgarte 31 Aug 16:57
         Why the endless background conversions between linear and regular sRGB TRC? Simon Budig 31 Aug 17:05
          Why the endless background conversions between linear and regular sRGB TRC? Guillermo Espertino (Gez) 31 Aug 18:51
           Why the endless background conversions between linear and regular sRGB TRC? Simon Budig 31 Aug 19:12
            Why the endless background conversions between linear and regular sRGB TRC? Alexandre Prokoudine 31 Aug 19:23
            Why the endless background conversions between linear and regular sRGB TRC? Guillermo Espertino (Gez) 31 Aug 20:16
             Why the endless background conversions between linear and regular sRGB TRC? Tobias Ellinghaus 31 Aug 20:46
              Why the endless background conversions between linear and regular sRGB TRC? Guillermo Espertino (Gez) 31 Aug 21:12
       Why the endless background conversions between linear and regular sRGB TRC? Jon Nordby 31 Aug 17:30
Elle Stone
2012-08-29 17:03:53 UTC (over 12 years ago)
Why does /babl/babl/util.h provide functions that transforms back and forth between linear gamma TRC and the regular sRGB TRC? I'm sure there is a reason, but the reason is not apparent to me.
Why does the /babl/babl/util.h code get executed from fast-float.c, float.c, model-rgb.c, model-gray.c, and several other files, resulting in endlessly performed conversions between linear and regular sRGB TRC in the background of all image processing?
That conversion from linear gamma to the sRGB tone response curve and back gets executed literally hundreds of thousands of time, every time you do anything at all using Gimp.
For example, open a 300px by 200px image file - functions that call the functions in util.h get executed over a million times (printf statements to konsole terminal, with scrollback set to unlimited, save as text file, open with kate, see how many lines).
Convert that small image to another color space, another million and a half times functions that call the functions in util.h get executed. Use curves, generate a thumbnail, do anything at all, more executions.
And yet replacing the code with code that says "value_in=value_out" doesn't seem to change the way Gimp works at all, except for the better:
*my lcms2 high bit depth color conversion code works *16-bit tiffs open without the erroneous "gamma 2.2 correction" being applied *the weird "gamma=0.45" gegl blurring error that I reported doesn't happen when you blur a linear gamma high bit depth image.
I suspect several other weird gamma 2.2/0.45 errors also might be related to the babl/babl/util.h functions.
The only possible rationale that I can see for constant conversions back and forth between linear gamma and sRGB "almost gamma 2.2" TRC would be if Gimp expects that ALL high bit depth images have an embedded profile that has the sRGB TRC, and converts to linear gamma for processing, then back to the sRGB TRC for some other reason that I haven't been able to imagine.
But in point of fact, ProPhotoRGB has a gamma=1.8 TRC, lookup table profiles can have very peculiar TRCs, ECI RGB and the LStar profiles have the LStar TRC, AppleRGB has gamma=1.8 TRC, BetaRGB and many other common working spaces, including "simplified" sRGB, have a true gamma=2.2 TRC. Custom working spaces and camera input profiles can have other diverse TRCs. Monitor profiles do *not* always have the sRGB TRC. Some monitor profiles aren't even matrix profiles. This diversity of TRCs is handled quite well by using LCMS to convert from one color space to another.
Respectfully, with kindest regards, and also with ever-increasing curiosity, Elle Stone
(If anyone wants to try my lcms2 high bit depth color conversion plug-in, here's the download link, with instructions for compiling: http://ninedegreesbelow.com/temp/gimp-lcms-6.html)
Simon Budig
2012-08-29 18:42:40 UTC (over 12 years ago)
Hi Elle.
Sorry, I can't comment on most of these issues. However there is one important caveat:
16 bit loading code in the tiff plugin is highly experimental and I am not at all sure that it does the correct thing.
I just committed a bugfix for Bug #678815 https://bugzilla.gnome.org/show_bug.cgi?id=678815
which fixes loading issues with some tiffs. I failed to properly specify the format that the tiff plugin uses to transmit the data to the core.
Basically all of the plugins (including your lcms port) use the old pixel-region API for accessing the image data. This also means that they don't specify a proper working format, this even could be the reason for all kind of potentially useless conversions.
But I have the strong impression that no-op'ing a core function is the wrong thing to do. It is much more likely, that the plugins mis-specify their working format and subsequently bogus stuff is happening.
Maybe this helps?
Bye, Simon
Jon Nordby
2012-08-29 19:07:01 UTC (over 12 years ago)
Babl is a pixel format conversion library. It can convert between RGB pixel representations with linear gamma and gamma-corrected, separate alpha channel and premultiplied alpha, or to/from other pixel formats like HSV, HSL, LAB.
Rendering to to screen / the windowing system is done using sRGB. So anything that causes canvas updates when the image itself is not in sRGB will trigger such conversions.
Also, any legacy code paths that are still in place before the GEGLification might cause conversions to sRGB. I don't know exactly which parts those are in the current codebase, but anything that uses the deprecated pixel manipulation functions are likely candidates. I note that the lcms plugin still uses these interfaces, and I suspect that is what is causing the implicit (and unwanted) conversions you are seeing.
Elle Stone
2012-08-29 23:01:34 UTC (over 12 years ago)
Earlier to day I found Mitch's blog post: http://gimpfoo.de/2012/04/17/goat-invasion-in-gimp/ - which coheres nicely with what both of you are saying about the "old" vs "new" way of accessing pixel data.
So it looks like my next step is to replaced the deprecated functions in the lcms plug-in. So I will start doing exactly that. It was the next step anyway, but I was feeling very discouraged about the whole babl/babl/util.h thing.
Could you explain more about what you mean by "rendering to the screen is done using sRGB"? What about the actual monitor profile?
Back in the day, a decent CRT monitor could easily be calibrated to match the sRGB color space, because sRGB was based on the display characteristics (tone curve, primaries, "dial-a-white-point" and 0 black point) of the CRT monitor. (See "All the Colors, Some of the Colors, the Colors of Daylight":
http://ninedegreesbelow.com/photography/all-the-colors.html).
Today's LCD monitors are not well-characterized by sRGB. It is not just a matter of the LCD monitor native white point not being D65. The phosphors are different, which means the primaries are different, which means the color gamut is different. And unlike a CRT, with an LCD you can't get (0,0,0) displayed to the screen (the sRGB black point assume "zero light" can be sent to the screen). Which means you cannot really calibrate your monitor to use the sRGB TRC. (See "sRGB Not So Good for LCD Monitors":
http://ninedegreesbelow.com/photography/srgb-bad-monitor-profile.html and "Image Display Technology": http://www.marcelpatek.com/LCD.html.)
A wide gamut monitor profiled in its native state would be an even worse fit to sRGB, though compared to a regular LCD, a wide gamut LCD monitor can achieve a much closer calibration to sRGB, IF one chooses to give up the extra color gamut. But why would you want to give up all that extra color gamut goodness?
My own LCD "native state" monitor profile covers 93% of the sRGB color space, but the sRGB color space covers only 84% of my monitor profile color gamut. If I calibrated my monitor to match sRGB as closely as possible, I would end up with a monitor profile color gamut that is actually smaller than sRGB, at the additional price of less smooth tonal transitions - a very bad move, it seems to me.
So to repeat my question, how does "rendering to the screen . . . using sRGB" cohere with using an LCD monitor that is not well-described by the sRGB color space profile?
Kindest regards, Elle
Articles and tutorials on open source digital imaging and photography
gimp-developer-list@gnome.org
Jon Nordby
2012-08-30 10:11:23 UTC (over 12 years ago)
Cairo, the library used for rendering to the screen in GTK and GIMP expects its input as sRGB*. See app/display/gimpdisplayshell.c for example of how we use this library. The Babl format "cairo-ARGB32" is short for "R'aG'aB'aA u8": 8 bit unsigned integer gamma-corrected, pre-multiplied alpha. The LCMS plugin is used before this step to do the conversion with the actual monitor profile.
* It is unclear to me how strict this expectation is as this is not documented anywhere in Cairo. Perhaps someone here can shed some more light?
Today's LCD monitors are not well-characterized by sRGB. It is not just a matter of the LCD monitor native white point not being D65. The phosphors are different, which means the primaries are different, which means the color gamut is different. And unlike a CRT, with an LCD you can't get (0,0,0) displayed to the screen (the sRGB black point assume "zero light" can be sent to the screen). Which means you cannot really calibrate your monitor to use the sRGB TRC. (See "sRGB — Not So Good for LCD Monitors":
An RGB30 (10 bits per channel) image format was added in Cairo 1.12 earlier this year. I don't know if any if the display backends used on Linux, Mac OSX or Windows handles this format yet. It could be the output it still clamped or converted to 8 bit per channel even on wide gamut displays. I highly suspect that would be the case on X11.
Jon Nordby
2012-08-30 11:12:26 UTC (over 12 years ago)
Corrections : the LCMS display filter module is used, not the LCMS plugin. File: modules/display-filter-lcms.c The conversion is done _after_ the image has been rendered into the Cairo image buffer. See the call to
gimp_color_display_stack_convert_surface in gimpdisplayshell-renderer.c
Elle Stone
2012-08-30 11:55:15 UTC (over 12 years ago)
Regarding sRGB and rendering to the screen: Could you explain more about what you mean by "rendering to the screen is done using sRGB"? What about the actual monitor profile?
So if I understand what you are saying (I don't think I do): First the lcms plugin converts the image to the actual monitor display profile. Then "something" converts the image to sRGB and sends the image to Cairo? And then Cairo sends the image to the screen?
I don't think that is what really happens. If it were happening, all images displayed by Gimp would have a magenta color cast as displayed on my monitor. And they don't. Perhaps Cairo just sends RGB numbers to the screen (and doesn't care what these numbers "mean"), and Gimp is sending the monitor profile RGB numbers to Cairo.
Bit depth and ICC profile color gamut are two different things. Bit depth determines how many steps to get from min to max. For example, 8-bits gives you 255 steps to get from solid green (0,255,0) to solid yellow (255,255,0). 10 bits gives you 1023 steps to cross the same distance. But the "meaning" of solid green and solid yellow is determined by where the monitor profile (or any other ICC profile) locates solid green and solid yellow in an reference space (profile connection space) such as XYZ or Lab space.
Kind regards, Elle
Michael Natterer
2012-08-30 12:30:36 UTC (over 12 years ago)
Don't work under the assumption that anything in git master works as it should. It's safe to assume that *nothing* works as it should, and needs to be fixed. So if something doesn't seem to work, the bug could be in many places.
--mitch
2012-08-30 12:41:00 UTC (over 12 years ago)
FYI, color management in Cairo is a work in progress. Adrian needs input on desired API, though. Without it he cannot proceed further.
http://inkscape.13.n6.nabble.com/Creating-color-managed-PDFs-td4964914.html
2012-08-30 12:42:27 UTC (over 12 years ago)
Also, http://cgit.freedesktop.org/~ajohnson/cairo/log/?h=color-space
Tobias Oelgarte
2012-08-30 12:45:59 UTC (over 12 years ago)
Am 30.08.2012 13:55, schrieb Elle Stone:
If I'm not entirely mistaken then there should be only one real conversions. In this lcms would convert the linear color to a pseudo sRGB, which is actually the monitor display profile. This is because Cairo only supports sRGB and does no conversion to the monitor profile on it's own. So the colors have to be converted before passing them them to Cairo (regardless if sRGB or RGB30).
Kind regards, Elle
Right. I do not really understand why the conversions should be such painfull. Ideally all image data (except alpha) should be handled as linear internally. This has effectively nothing to do with color management (only depth conversion), except that we want to give every channel/layer a own profile to avoid rounding errors on low bit depth. Rounding errors would occur if we have a 8bit sRGB image and would convert it to 8bit linear RGB. So we have a dilemma:
A) Storing everything as 32bit float linear RGB would dramatically decrease programming overhead and computation time (no color conversion, except for final output), but it would consume a great amount of RAM for just 8 or 16 bit images.
B) Leaving the the values as they are and doing conversions every time a pixel is accessed saves a lot of RAM. The downside is that every pixel has to be converted from "channel" profile and depth to another profile and depth if doing some stuff. This could be drastically speed up if there are specialized methods that can do the operation the short way, but i doubt that it would be beneficial to implement all permutations.
Personally i would favor scheme A) since performance is one of my biggest concerns for GIMP right now. RAM is important, but it doesn't really matter as much. This steady conversions from one color space to another are really a performance killer.
Option C) would be a cache for Option B) that keeps the image data as it is (uncoverted, original bit depth), but stores the pixel information as linear RGB 32 bit. But it would not store the whole layer, it would just store what is "On Screen", already resized, transformed, etc, but not flattened. That way only one layer must be converted (cache->layer) while drawing.
Kind regards,
Tobias Oelgarte
Jon Nordby
2012-08-30 13:48:39 UTC (over 12 years ago)
You understood me correctly, but what I said it turned out to be wrong. Quoting myself from the follow up email:
"Corrections : the LCMS display filter module is used, not the LCMS plugin. File: modules/display-filter-lcms.c The conversion is done _after_ the image has been rendered into the Cairo image buffer. See the call to
gimp_color_display_stack_convert_surface in gimpdisplayshell-renderer.c"
So the pipeline is at the moment:
GeglBuffer (format depending on image precision setting) -> | gegl_buffer_get | -> sRGB (without a profile or with the profile of the document?) -> | display filter stack | -> sRGB in monitor profile -> | Cairo |
This is actually one more conversion and one step earlier than we need to. Ideally the pipeline should look like this:
GeglBuffer -> | display filter stack | -> sRGB in monitor profile -> | Cairo |
That way we only convert to the monitor profile as a last step. This would require GEGLifying the display filter stack and all the modules it uses.
Yes, you are probably right that Cairo itself does not care about the meaning of the RGB values, and that this is up to the display system and screen.
Øyvind Kolås
2012-08-30 16:17:14 UTC (over 12 years ago)
I'll only reply to the question in the topic, repeating quite a bit of the information I put in a write up two weeks ago: http://gimp.1065349.n5.nabble.com/GIMP-GEGL-storage-precision-and-color-management-td34899.html
When operating in 8bit precision is that a GEGL powered GIMP assumes that 8bit precision data is stored with sRGB gamma (this will probably be changed to apply to 16bit integer as well), data with higher bit-depths are stored with a linear gamma ramp in the layer buffers.
The working space of the layer modes currently used by GIMP are implemented with sRGB gamma based compositing, thus for higher bit-depth data - we must convert from linear to the sRGB working space - perhaps go back to linear for some other operation, and in most cases we convert back to 8bit sRGB for display (with proper color management we'd go from higher bit-depth to the displays ICC profile or similar). All these legacy 8bit layer modes are scheduled for replacement with operations working in linear light (linear gamma) - at that stage a lot of conversions back and forth (in floating point) will be avoided.
Importing 8bit or 16bit images that do not contain sRGB data - should result in precision promotion to probably 32bit floating point, where the data can be well represented ... pending a _potential_ conversion back to the source ICC profile. Note that babl's built in floating point representations have unbounded gamuts thus can represent all of sRGB / ProRGB / AdobeRGB and data with other 8bit profiles. Using the sRGB for 8bit and 16bit integer precisions means that (web destined) JPG and 8bit/16bit PNGs without associated profiles should be possible to directly manipulate.
Elle Stone
2012-08-30 18:08:50 UTC (over 12 years ago)
But this is a ***very wrong*** assumption. Many people work with 8-bit images that are NOT sRGB images and DON'T use the sRGB TRC (AppleRGB, ColorMatch, LStar, etc).
And many, many more people work with 16-bit images that are NOT sRGB images and DON'T use the sRGB TRC (ProPhoto, Beta, WideGamut, etc).
In point of fact the extended scRGB does NOT cover all of the ProPhotoRGB color space or the CIE 1931 color space. scRGB leaves out a good chunk of the all-important greens.
Quoting from Wikipedia, which has a very nice picture that everyone ought to go take a look at: http://en.wikipedia.org/wiki/ScRGB
"Negative numbers enables scRGB to encompass most of the CIE 1931 color space while maintaining simplicity and backward compatibility with sRGB ***without the complexity of color management***. The cost of maintaining compatibility with sRGB is that approximately 80% of the scRGB color space consists of imaginary colors."
The point of scRGB is MicroSoft's and Hewlett-Packard's attempt to yet again not deal with color management. But color management is part and parcel of all high end image editors, and well-integrated with Linux. So why on earth would any Linux image editor want to follow in the MS/HP footsteps and use scRGB, with the attendant loss of ability to represent all of the real world colors and the attendant requirement of using very high bit depths to maintain image integrity?
If you stick with normal, well-accepted working spaces like ProPhotoRGB and BetaRGB, you can edit using 16-bits without banding. If you force image data into the scRGB color space, to maintain the same degree of accuracy/lack of banding you will ***need*** to go to 32-bit/64-bit floating point, because of the way scRGB works. That is the price you pay for having 80% of your working space occupied by imaginary colors. That will place a huge and unnecessary overhead on image editing with Gimp.
Right now the default babl/base/util.h DOES NOT WORK with any 16-bit image that doesn't have the sRGB TRC. Please see this page for an example using Gegl blurring:
http://ninedegreesbelow.com/temp/gimp29-gegl-blur-prophoto.html
My color conversion code is NOT involved in blurring, and to make double sure, I replaced my lcms2 plug-in with the default Gimp lcms plug-in. The Gegl blurring ONLY works with images that have the sRGB TRC.
With increasing dismay, but still with warmest regards, Elle Stone
Øyvind Kolås
2012-08-30 22:30:51 UTC (over 12 years ago)
sRGB, AppleRGB and other 8bpc representations are a work-around for the limited values expressable in 8bit - you are better off doing the actual processing in linear light RGB and not permitting these arbitrary working spaces; this reduces this other spaces to be a space efficient way of packing the color data into 8bit.
The "RGBA float" space of babl does not leave out greens, blues, purples or imaginary colors of any magnitude. The entirety of the tristrimulus gamuts expressable in any RGB triplet space can be expressed. (granted some parts of this 32bit floating point representation is not the most _useful_ real world colors, but no colors are being left out).
You were yourself arguing for linear light processing earlier ;) To me this is about doing things more correctly and not rely on the legacy of 8bpc hacks. Moving the 8bpc hacks over to be properly color manages (having completely user defined arbitrary working spaces for operations like blur and compositing is not really a color managed workflow). All processing in a GEGLified GIMP is already happening in 32bit float, the additional overhead to pay by using single (or half (16bit)) precision float for storing image content is not a large price to pay for accurate color management.
Your assessments on what works when opening your image files has little bearing on correctness of what is going on. Your changes to babl is equivlent to declaring that black and white is the same thing and complaining about being run over by cars in a zebra crossing. ;)
I do hope you stick around, we need people able to understand color and the implications of controlling it properly. But it seems like you think we're 98% done with dealing with color in the brave new world of geglified GIMP while the truth is that we're probably ~20% there. Very few things are expected to work correctly right now and the rest can be figured out as we're gaining more solid ground.
Øyvind Kolås
2012-08-30 23:01:08 UTC (over 12 years ago)
You should also note that babl's "RGBA float" format is not inspired by or defined by scRGB, but could more well be described as a linear light / physical color space, with the same RGB primaries as sRGB, a linear gamma curve, white at 1.0, 1.0, 1.0 - black at 0,0,0 extendable towards the limits of floating point representation negatively and positively.
It has been pointed out to me that this in some way resembles some aspect of scRGB - however I arrived at the behavior of the space before I ever looked at anything that had to do with it. To do color management properly - the important thing is to tag all your buffers with the relevant color profile, a proliferation of "source data profiles", "standard press profiles", "optimized 8bit working spaces" and more does not help the user keep their colors under control, instead it makes it easier to mis-configure your workflow/system. Building a system around linear light instead of gamma encoded processing; with strict coordination of the color spaces involved should lead to more predictable control over results.
With the strict color management architecture of GEGL - you would lose the memory gains from storing layer data in lower precision with custom profiles in terms of additional conversions that would then be necessary for when temporarily linearising data and increasing precision for 32bit processing (and back again to destructively store the new results). In the future when the system is in place; there is the option to add direct 8bpc and 16bpc fast paths for sRGB processing (as well as maybe add ugly hacks permitting the user to pretend that the 8bit or 16bit data is not in sRGB but some other space; including problems resulting from gamma problems then present when blurring, scaling, compositing and more...) neither of those are something I'd consider of importance until basics are covered.
Elle Stone
2012-08-31 15:37:06 UTC (over 12 years ago)
I keep coming back to this question. If your goal is to convert all images to your linear light working space for image processing, why not do the conversion one time and be done with it?
I did some preliminary checking. LCMS can do the conversion between your linear light profile and the monitor profile. At least I think it can, per this post:
[Lcms-user] negative float clipping and gamma 1.0 http://sourceforge.net/mailarchive/message.php?msg_id=29167076
So it looks like LCMS can now convert from linear gamma built-in sRGB with negative values to XYZ space. I played with the transicc utility and sure enough, negative numbers were being transformed from linear sRGB to XYZ and back. I'm pretty sure any other profile with a linear gamma TRC will also work.
Assuming the new LCMS capacity works the way I think it does, then you could use what Jon Nordby described in a previous post to this thread, and let LCMS take care of sending the properly transformed linear light information to the monitor display:
(I think "sRGB in monitor profile" probably means "sRGB or monitor profile". Jon - yes? no?)
This ability to use negative floating point numbers with a linear gamma profile (only a linear gamma profile, no other TRC) is a new LCMS capability. It would not have been around at all when you thought up your linear light profile, which perhaps MS/HP then "borrowed" from you. :)
Perhaps the new LCMS capability would eliminate any need for constantly converting back and forth between sRTB TRC and linear gamma TRC.
Your choice of white point (1,1,1) is intriguing, being at odds with the almost universally used D50 white point of XYZ=(96.420,100.000,82.489), and also the V2 sRGB D65. By the way, the lcms V4 matrix sRGB profile uses D50, in keeping with the V4 ICC profile specifications.
Are the primaries for your linear light profile as defined in babl/extensions/CIE.c?
/* sRGB/HDTV phosphor colours */
static const double pxr = 0.64F;
static const double pyr = 0.33F;
static const double pxg = 0.30F;
static const double pyg = 0.60F;
static const double pxb = 0.15F;
static const double pyb = 0.06F;
If so, I will experiment to see what happens using lcms utility "transicc" to convert from your linear light space with its unusual white point, to regular color spaces (including camera and monitor as well as working spaces), and back.
Just a thought: If your linear space used the identity profile, with RGB primaries of (1,0,0), (0,1,0) and (0,0,1), I don't think you would need negative float values to cover the entire 1931 CIE XYZ color space, conversion computations would be drastically simplified, and I'm pretty sure you'd have less space devoted to imaginary colors. But this whole negative floating point values thing for ICC profiles is new territory to me. I've known about it theoretically for a long time, but until now never had the wherewithal (the new LCMS utilities/capabilities) or reason (your linear light color space) to acquire any practical understanding.
Cheers, Elle Stone
2012-08-31 15:51:09 UTC (over 12 years ago)
Isn't it what yvind defined as a noble goal in his mail few weeks ago? :)
Didn't he also say that the relevant part of code is more like 20% done and hence should not be treated as what the team had in mind for final design? :)
Elle Stone
2012-08-31 16:27:26 UTC (over 12 years ago)
The ultimate goal of working in a linear light color space is both clear and noble.
The purpose of the constant background converting back and forth between two tone curves, sRGB TRC and linear gamma, is not clear at all.
"In service of the noble goal" doesn't explain *why* the conversions are done over and over again instead of just once. I really, really, really want to know why those relentlessly repeating background conversions between sRGB TRC and linear gamma are happening. But I will stop asking. And maybe some kind soul will send a private email giving an explanation that I can understand.
I was excited to find out that the latest LCMS can do color conversions involving negative floating point numbers. If the Gimp code is only 20% finished, then perhaps the information I just gave about the new ability of LCMS to do conversions involving negative floating point numbers might be pertinent to crafting the remaining 80%. But if not, then I apologize for posting it.
Elle
Tobias Oelgarte
2012-08-31 16:57:50 UTC (over 12 years ago)
Am 31.08.2012 18:27, schrieb Elle Stone:
I support this. Working in linear light color space has many advantages. One of them is the potential speed. The other would be tools that only need to work inside one color space.
At the moment it is also not clear to me. But i guess that it has to do with all the legacy code that currently is in the way, because this parts haven't been rewritten. I assume that this parts just got a wrapper (it does the color conversion, currently every time) to be able to work on the core while not making everything unusable.
But if I'm wrong and it should stay like this, then this is a real problem.
In the case I'm not lier than i have given the explanation above.
Elle
Lets see what the developers have in mind. If they do it right, then there should be two solutions with the empowered to choose which one he likes, because both have a distinct advantage and disadvantage:
A) The buffer of any type / color space will be converted at load/creation time to linear RGB float. Anything else works only with linear RGB float. Final output will be converted to sRGB or device color profile.
B) The buffer will be loaded and stored in native/original format. Every access to the buffer which is not linear RGB float will force a conversion, which might need caching for better speedup. The core still works entirely in linear RGB float. and the final output will be converted to sRGB or device color profile.
While (A) would be fast it is very memory intensive for larger images. The method (B) might be very slow in comparison, but it needs much less memory.
Ideally the user would load layers/buffers and would have the choice to convert the buffer to any color space/format he likes, with the hint that linear RGB float is the fastest that does not need any conversion. So the user would have to option if he wants speed or less memory consumption.
But maybe someone wants to enlighten me that both things are not mutually exclusive.
Tobias
Simon Budig
2012-08-31 17:05:15 UTC (over 12 years ago)
Well, it is not on purpose. It is basically a side-effect of trying to port Gimp to the new infrastructure without e.g. changing the visual output of e.g. layer modes, while avoiding changing the math (Or do it in an incremental manner while keeping the results consistent).
Ok, for an example have a look at gimp/app/operations and grep the string "R'G'B'".
As you can see, a lot of them are designed to work in a R'G'B' mode, since this was the working assumption in our old 8 bit core. We need as-identical-as-possible results and the easiest way to port them to GEGL and adding support for the high-bit-depth modes is to let the operations work in "R'G'B'A float" and port the math in the most straightforward way possible.
Now every time some of these operations is involved, the GEGL core needs to convert the "RGBA u16" data as stored in the image to "R'G'B'A float" so that the operation can properly work in its expected working format. And of course before the new data ends up in the pixel storage it needs conversion back to "RGBA u16".
Of course this is not good and has a massive speed impact, ideally the operation should be able to work on "RGBA u16" directly, but then the math becomes nontrivial (we need compatible results). This is optimization work that we have not even really started tackeling.
I fully expect to have other problems like this on all kinds of different places and I don't know which of these point it actually is you're hitting with your test cases.
With your "elimination" of the conversion in util.h you probably have introduced visually different results for these kind of operations (because e.g. the "addition" mode now adds up in a linear fashion, while it earlier worked in Gamma mode). Of course it is debatable how certain layer modes are supposed to work, but we also need to maintain some backwards compatibility, so that old XCF files in a new Gimp look the same as always.
But I
Please not, keep it on the list. These things are tricky and they deserve to be pulled into the open :)
And don't stop asking.
Bye, Simon
Jon Nordby
2012-08-31 17:30:28 UTC (over 12 years ago)
Yes.
2012-08-31 18:51:38 UTC (over 12 years ago)
El 31/08/12 14:05, Simon Budig escribi:
I can only speak as a user, and I'm not sure about how other users feel about this, but even after 6 years of GIMP as my main and only bitmap manipulation software, I wonder how much of a big deal would be to ditch legacy appearance.
Of course several of my old files will look different, but if I think of it as a compromise to get a better GIMP, I'm all for it. If I had to modify old files to make them look right in linear blending, it wouldn't be very difficult, and for those cases when getting the same results is critical, I still could use GIMP 2.8 Keeping legacy seems like an anchor for any program, and I wonder if keeping a legacy version as a separate product wouldn't make more sense than leashing the power of GIMP could have and squeezing dev's brains and time to get legacy co-existing with the new core. I also wonder how much of GIMP's userbase uses it for complex composites with lots of layers and blending modes. Judging by the forums and tutorials out there, probably most of the users wouldn't notice if sRGB blending is replaced by linear.
There is a special case, though, that I wanted to leave for the end: Using GIMP for web mockups. Web browsers still use gamma blending for compositing RGBA images (a png with transparent background, for instance). It's true that creating mockups in linear space would give different results, but that could be solved by adding a special variant of the "normal" blending (simple porter-duff alpha-over op) that gamma-corrects both inputs, composites them and then linearizes the result. And maybe it doesn't have to be a special blending mode but a preview mode ("web preview" or something like that") that creates a projection with every alpha-over done in gamma-corrected space.
Anyway, that seems to be something that can be addressed later.
I'm curious to know how other users feel about this. I'd even suggest to comment everything legacy out in 2.10 and see how user community reacts. If it's too bad for the majority of the users out there, GIMP 2.8 would be still an option (I mean, if there are users who chose to stick with 2.6 because of the save/export thing, they can stick with 2.8 because of legacy looks). If nobody cares, happy-happy, joy-joy. :-)
Gez.
Simon Budig
2012-08-31 19:12:50 UTC (over 12 years ago)
[compromises in Gimp] so that old XCF files in a new Gimp look the same as always.
Well, it is not just about compatibility, it is also about trust of our userbase.
I think it is important that we do not give the impression that we mess around with the users data at the whim of the developers. Some people probably have invested lots of time in complex artwork where it is not exactly clear what to do to restore the original look, especially if you don't know where to steer towards.
Anyway, it probably is not that bad. We already discussed the possibility of legacy layer modes which would retain the old look but are basically unavailable or hidden in the layers dialog.
At the same time new layer modes with the old names can be introduced.
Bye, Simon
simon@budig.de              http://simon.budig.de/
2012-08-31 19:23:17 UTC (over 12 years ago)
Or you could rename old ones to "foobar-old" and just use "foobar" for the new ones.
2012-08-31 20:16:50 UTC (over 12 years ago)
El 31/08/12 16:12, Simon Budig escribi:
My question is:
a) Does the existing userbase actually care about it? b) Wouldn't doing a relevant change like that, but communicating it properly wouldn't be enough to avoid problems and keep users happy? (if such thing is possible :p)
GIMP has many users, but if you look for artists or designers using it for complex artwork the list is rather short, and probably that kind of artists will prefer linear blending because it does look better (just place a blurred gray circle on a magenta background in gamma and linear spaces and ask people which looks better, I bet no one will choose gamma).
I think it's about communication. If GIMP ditches gamma blending, but every time you open an old file you get a notice saying that layer modes appearance might change, and it is documented clearly that this change was made for the better, I doubt anyone will feel betrayed by developers.
And if there's a strategy to "bake" the old look into a layered or flattened image, then nobody will complain. I'm asking some friends about this, and everyone seems to be fine with an importer that warns about the appearance chance and offers the alternative of baking the appearance losing some editability. I'm not saying that asking a few friends is enough, but I'd really like to know how other users feel about this.
I think it's about communication. If GIMP ditches gamma blending, but every time you open an old file you get a notice saying that layer modes appearance might change, and if it is documented stating clearly that this change was made for the better, I doubt anyone will feel betrayed by developers.
It's like saying: "this is the right way to do it. Our old core didn't let us do it this way, but now we can. Now composites will look as they should, but perhaps that means that what you created with an old version will now look a little different".
And if there's a strategy to "bake" the old look into a layered or flattened image, then nobody will complain. I'm asking some friends about this, and everyone seems to be fine with an importer that warns about the appearance chance and offers the alternative of baking the appearance losing some editability. I'm not saying that asking a few friends is enough. I'd really like to know how other users feel about this.
Anyway, I wouldn't be so worried about users feeling betrayed. Users do that.
A lot of them felt the save/export separation as a betrayal and even some of them claim that they won't be using GIMP anymore because of that. Some people even complains about the bulky look of the new sliders. Some people even complains about the no-image window introduced in 2.6 saying the floating toolbox with a menu was better!
I wonder what's the real benefit of doing such thing. Ok, old files will be still functional and users will be able to work with them. But at the same time it introduces complexity and odd behavior of the application. For instance, a user may ask why the overlay mode works in that way in his old files but not with the new files. If that happens, the user will go to the forums, lists or IRC and ask. Somebody will have to answer why. Somebody will have to answer why untagged 8bpc images and, say AdobeRGB 8bpc images look different when blended. It will also mean that some users will create new files from scratch and then say "I want to use the legacy-normal mode, why can't I do that?". Keeping legacy visible will clutter the UI. Hiding it will mean more people asking where is it.
It sounds either like a mess or like a lot of hard work to make those situations co-exist, and the benefit is still only for the few guys that need to open an overly complicated composition made with an old GIMP to modify it, keeping the old look.
I'd prefer that all that effort is put on making GIMP a more powerful application and I bet that keeping legacy is a huge PITA for developers and it's far more interesting and fun to add new features and streamlining the application.
BTW, all this legacy stuff seems to go against the product vision. Making a tool for a specific audience means some compromises, and this is certainly a compromise that "high-end image manipulation" audience wouldn't mind.
Gez
Tobias Ellinghaus
2012-08-31 20:46:22 UTC (over 12 years ago)
Am Freitag, 31. August 2012, 22:16:50 schrub Guillermo Espertino (Gez):
Especially these people will be upset if their older work can't be opened and edited any longer. It's not the kiddies doing animated sigantures for web forums that the developers care about, it's the serious users which are the target in the product vision. And having several versions of GIMP installed in parallel is no option for them. I guess you are beating a dead horse here.
Gez
Tobias
2012-08-31 21:12:25 UTC (over 12 years ago)
El 31/08/12 17:46, Tobias Ellinghaus escribi:
Nobody said that it wouldn't be possible to open or edit old files. The problem here is appearance.
If you open a layerer composite in linear space it will look different than the same composite blended in gamma space. Some blending modes look almost the same, some of them don't. It also depends on the image. The effects of linear compositing would be more visible in some cases and almos unnoticeable in others. So, what I proposed was just using linear space for blending for everything (including old files) and offering an optional projection or "bake" mode for keeping the old appearance as close as possible. And that can come later.
It seems pointless to keep legacy code to take care of the old stuff and complicate things just to be able to manage a handful of old files.
I think I can consider myself a high end GIMP user and not a kiddy doing animated signatures. I'm discussing about making GIMP a high end tool, which probably involves in some point getting rid of the low-end legacy. It's a compromise, sure. But nothing keeps GIMP from getting a mechanism for importing and displaying legacy files later, on top of a sane and high-end pipeline.
Gez.
