building documentation?
| building documentation? | Michael Grosberg | 23 Mar 19:10 |
| building documentation? | Owen | 23 Mar 20:27 |
| building documentation? | Michael Grosberg | 24 Mar 07:10 |
| building documentation? | Owen | 24 Mar 09:26 |
| building documentation? | Michael Grosberg | 24 Mar 11:54 |
| building documentation? | Owen | 24 Mar 20:33 |
| building documentation? | Michael Grosberg | 26 Mar 11:25 |
| building documentation? | Ulf-D. Ehlert | 26 Mar 19:11 |
| building documentation? | Michael Grosberg | 27 Mar 19:32 |
| building documentation? | Ulf-D. Ehlert | 24 Mar 10:57 |
IT's taken some time (I had a rather optimistic estimate of tmy free time) but I'm finally making some headway with rewriting parts of the documentation. My current aim is to rewrite Gimplite Quickies. Problem is, I still don't know how to build the html. I was told here on the mailing list that Ubuntu has all the needed tools but I wasn't told what they are... Validating is not a problem, I have XML validation tools, but editing XML blindly can only go so far: I really need to see what I'm doing.
Can anyone help me with this?
BTW, I'm targeting 2.8, i.e., changing references from "save as" to "Export", etc.
blindly can only go so far: I really need to see what I'm doing.Can anyone help me with this?
This wiki entry may help you
http://gimp-wiki.who.ee/index.php/Hacking:Building/Linux#Building_the_Documentation
Owen
2011/3/23 Owen
Owen
OK, wiki says to type this:
./autogen.sh --without-gimp ALL_LINGUAS="en"
Then look for errors on missing dependencies, install them, repeat until autogen finishes successfully.
First of all I updated my local copy of GIT.
I installed the following packages:
gettext
docbook
automake
docbook2odf
pngcrush
pngnq
And got autogen to announce I can now use make.
I can either build html or PDF.
I managed to build a PDF, so that's good news, but when I try to build the
HTML I get this:
michael@michael-desktop:~/gimp-help-2$ LINGUAS=en make
Making all in quickreference
make[1]: Entering directory `/home/michael/gimp-help-2/quickreference'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/michael/gimp-help-2/quickreference'
make[1]: Entering directory `/home/michael/gimp-help-2'
Cleaning up 'en' xml files ...
*** Making html for en ...
I/O error : Attempt to load network entity
http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk.xsl
warning: failed to load external entity "
http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk.xsl"
compilation error: file stylesheets/plainhtml.xsl line 10 element import
xsl:import : unable to load
make[1]: *** [html/en/index.html] Error 5
make[1]: Leaving directory `/home/michael/gimp-help-2'
make: *** [all-recursive] Error 1
Any ideas? (I can reach the XSL using Firefox)
I can work with the PDF but I'd be happier if I could see the HTML result.
2011/3/23 Owen
Owen
autogen finishes successfully.First of all I updated my local copy of GIT. I installed the following packages:
gettext
docbook
automake
docbook2odf
pngcrush
pngnqAnd got autogen to announce I can now use make. I can either build html or PDF.
HTML I get this:michael@michael-desktop:~/gimp-help-2$ LINGUAS=en make Making all in quickreference
make[1]: Entering directory `/home/michael/gimp-help-2/quickreference' make[1]: Nothing to be done for `all'. make[1]: Leaving directory `/home/michael/gimp-help-2/quickreference' make[1]: Entering directory `/home/michael/gimp-help-2' Cleaning up 'en' xml files ...
I/O error : Attempt to load network entity http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk.xsl warning: failed to load external entity " http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk.xsl" compilation error: file stylesheets/plainhtml.xsl line 10 element import
http://docbook.sourceforge.net/release/xsl/current/xhtml/chunk.xsl make[1]: *** [html/en/index.html] Error 5 make[1]: Leaving directory `/home/michael/gimp-help-2' make: *** [all-recursive] Error 1Any ideas? (I can reach the XSL using Firefox)
Could I suggest that you run autogen.sh again, and read the last 20 or so lines.
Just see what programs weren't found and install them.
Now if you have the style sheets on your computer, it shouldn't have to go to the net to get them. Install all the stylesheets you can find (I think you were using Ubuntu so just search synaptic for stylesheets )
I remember having problems getting this external link to work, maybe 5 or 6 years ago, and since then have used local copies
HTH
Owen
Michael Grosberg (Thursday, 24. March 2011) [...]
You have to install the DocBook stylesheets (package name probably "docbook-xsl" or "docbook-xsl-stylesheets"; source: http://sourceforge.net/projects/docbook/). Then you'll have a local copy of ".../xhtml/chunk.xsl" and xsltproc should use this version.
Bye, Ulf
Keiner schreibt, daß er nichts zu sagen hat; doch die meisten, die schreiben, sagen nichts als das. -- Karlheinz Deschner
2011/3/24 Owen
Owen
Thanks! It's working now. And with a launcher to a small script that generates a draft of a single file, I can preview with the click of a button, like God intended :)
I see you've already changed the wiki, so add the following: docbook-xsl (this is the one with the stylesheets) docbook-utils (solved a number of dependencies)
There might be more packages necessary; I added a bunch of other packages,
don't remember which, I just ticked anything that seemed like it was related
to docbook.
Also, I still get one line of missing dependencies:
checking for dot... no
I couldn't find something called "dot" in synaptic and it seems to be
working without it anyway.
Now, some more questions: 1. There are two folders, both with XML files: XML and SRC. I understand XML is the one files are built from, and SRC is the one GIT uses to fetch files. But how do the two interact? do I copy files manually or is there some tool or script to update one or the other? In other words what is the work process here?
2. UI screenshots: Do you have a preference for the theme used in the screenshots? The wiki says screenshots should use the "default theme" but is it the Gnome's or Ubuntu's default theme I should be using? Gnome's default is Clearlooks, right?
3. I intend to replace the astronomy images used in the quickies with images more representative of something a normal user would use, everyday objects such as cars, animals, plants, tourist attractions and if I find the right subjects, people. These are good looking images I took myself, but I want to know if I need to do anything rights-wise, you know, do I need to explicitly release them under the GPL or CC or what have you, and if I do, how do I do it.
4. it's a long shot, but does anyone here use Notepad++ and has the correct HTMLtidy settings file to correctly reflow and indent docbook XML?
On Thu, 24 Mar 2011 13:54:08 +0200 Michael Grosberg wrote:
I am totally out of my depth here, but here are some ramblings
I am pretty sure this is all controlled by the Makefile. have a sqizz if you are happy reading that stuff
I am pretty sure what is meant here is that the "Default" is that set out in the preferences under themes, .../share/gimp/2.0/themes/Default
Too hard, Ulf or Roman may help here.
Don't know Notepad++, but there is a linux program "tidy" which does a fairly good job once you psyche it out.
Owen
2011/3/24 Owen
This is the library that NPP uses to clean up code anyway. And it produces well-formatted, line-wrapped XML. The only difference is in the tag:
the existing XML files indent the tag this way:
content more content
While tidy produces output like this:
Other tags are identical. would that be a problem?
Owen (Thursday, 24. March 2011)
Yes, English is a special case (no po/pot files), the files are just
copied when you type e.g.
'make html-en'
or
'make xml-en'.
I think you are right. But IMO it's much more important which OS and (under Linux) which desktop manager is used. IMHO we should use distribution-independent (default) themes - e.g. Gnome's default theme rather than Ubuntu's.
I wonder if we won't get a copyright problem if the images are replaced... And even if not, shouldn't we show respect for the original author?
Ulf
Daß Götter stets nur in Menschengestalt kommen, hat noch keinen Gläubigen nachdenklich gemacht. -- Karlheinz Deschner
2011/3/26 Ulf-D. Ehlert
Obviously not - the entire thing is under the GNU Free documentation License. The original images were taken from Astronomy picture of the Day, and checking the "About" page, I see they were not released under any kind of free license; some of them may be copyrighted. If anything, replacing the images will make the doc more free. As for my own pictures, I figure if I add them to the documentation they fall under the GNU FDL. Anther reason for taking the time to replace all of them was that I wanted all the screenshots to have a similar theme (clearlooks, which I believe is the Gnome 2.x default) and I had to replace at least some because the interface has changed.
As for respect, I have all respect to Carol Spears who invested her time and effort to write the original tutorials, and I kept the credit in the introduction. But while it is natural for tutorials on personal website to maintain a casual tone and have tangential interests such as astronomy feature in the tutorials, I believe official documentation should be more professional. These are, after all, quick tutorials for those who don't want to read the entire manual to get some small task done; I tried to make it as short and to the point as possible.
