Autosave Plugin
Autosave Plugin yahvuu 07 Jul 18:06
yahvuu
2009-07-07 18:06:42 UTC (about 16 years ago)
Autosave Plugin
Hi all,
periodical autosave is long standing demand (bug 138373). While in my regard this is headed in a totally wrong direction [1], there's nothing wrong with having a plugin that works this way.
Somewhat suprisingly, i couldn't find such a plugin, so here's some dirty PyGIMP which at first glance seems to do the job. Perhaps someone gets inspired to create something worth uploading to the registry.
Usage: - start GIMP from a terminal (so the script's messages become visible) - toolbox: File->Activate Autosave (activate only once)
Every 30 minutes the script saves backups of all opened images to a temp folder. The backup files won't be deleted when GIMP exits, so some manual clean-up will be required from time to time.
have fun, peter
[1] http://bugzilla.gnome.org/show_bug.cgi?id=138373#c25
#!/usr/bin/env python
import tempfile, os from time import *
from gimpfu import *
def autosave(): backupInterval = 30*60
backupFiles = {} print "Autosave activated"
while 1: sleep(backupInterval)
print ctime(time())
curImages = {} for k in gimp.image_list():
curImages[k.ID] = k
curIDs = curImages.keys() oldIDs = backupFiles.keys()
newIDs = [x for x in curIDs if x not in oldIDs]; delIDs = [x for x in oldIDs if x not in curIDs];
# create (empty) backup files for new images for id in newIDs:
prefix = 'gimpbackup-ID' + str(id) + '-' fn = tempfile.mkstemp(prefix = prefix, suffix = '.xcf') os.close(fn[0])
backupFiles[id] = fn[1]
# remove closed images' backups for id in delIDs:
filename = backupFiles[id] del(backupFiles[id])
try:
os.remove(filename)
except:
print "ERROR: ", sys.exc_info()[0]
# backup images for id, filename in backupFiles.iteritems(): img = curImages[id]
try:
print "saving " + img.name + '-' + str(id) + ' to ' + filename pdb.gimp_xcf_save(1, img, img.active_drawable, filename, filename) except:
register( "autosave",
"Autosave dirty hack",
"Periodically saves all opened images to a temp directory", "public domain",
"public domain",
"2009",
"/File/Activate Autosave",
"RGB*, GRAY*",
autosave)
main()
