Tutorial: Making a pencil drawing from a photo
Written by , translated by redforce · Created on Jul 04, 2008, last updated over 13 years ago CC BY-NC License
Comic artists have it easy - they can scan their pencil drawings and then edit them. But how to make a realistically looking pencil drawing from a photo? In this tutorial you will learn how to convert almost any image into a good-looking pencil drawing, and yon even won't need edge detection filters. All you need are a few different layer modes.
    Open any photo you like. If you want to do the tutorial exactly as shown here, feel free to use the photo of Angelina Jolie (download link on the right side below the tutorial details).
    Duplicate the background layer. On the duplicate: remove the colors by using Colors / Hue-Saturation. Set the saturation to -100:
    Duplicate this color-less layer again. Now you have 3 layers.
    Now choose Filters / Blur / Selective Gaussian Blur, value: 4. Then use Colors / Invert. Then change the opacity of the layer to 50% to get a grey layer that shows the photo’s edges very weak.
    Merge the layer with the layer down: right-click the layer in the Layers window and choose “Merge down”.
    Duplicate the now merged layer and change the new layer’s mode to “Dodge”.
    Now the pencil drawing is finished!
    If you want to point out the grey lines some more, you can do so as follows:
    Merge the two grey layers so that you can find the line drawing on a single layer. Duplicate the layer again and change its mode to “Multiply”.
    Repeat this step as often as you like (until the width of the lines is OK).
    On my image I have applied a layer mask over the line drawing so there is a transition between photo and line drawing. (To do so duplicate the original photo and move this layer to the top of your layer stack. Then right click this layer in the layers dialogue and click “Add layer mask”. There should be a white are beside the layer. Click it to make sure you work on the layer mask. On this you can paint (i.e. using the Paintbrush tool) with black and gray tones to make some parts of the layer contents disappear (paint black = make disappear, paint white = show, paint gray = make semi transparent). So you can make a cool transition between your pencil drawing and the original photo).
    Have fun!
This topic (Making a pencil drawing from a photo) has been rated 4.3/5.0.
Russ
almost 8 years ago
Under Image/Mode the only options I have are RGB, Grayscale, and Indexed....
Russ
almost 8 years ago
I am on step 6 and can't figure how to change the Mode to Dodge. Please help
Toby Wilson
over 8 years ago
OK nevermind newbie mistake ...I was on the wrong layer
Toby Wilson
over 8 years ago
Did this on the Angelina file and it worked first time. The second time I could not get the opacity to come out right .. I see a transparency layer underneath.
eel member for about 9 years eel 3 comments
over 8 years ago
So sorry to be off topic but i'm a newbie here and don't know where else ask for help with this:
I tried to post in a new discussion (diagonally bordering pixel selection) but repeated received the error
"1 error prohibited this discussion from being saved
There were problems with the following fields:
Messages base Message may be spam (please try again later)"
Any advice from anyone greatly appreciated.
eel
Ekxhh66
over 8 years ago
As you can see from the blood demands diagram, only inseparable of the numbers has to be higher http://viagrawithoutadoctor.net/ viagra without a doctor prescription or discount than it should be to depend on as either costly blood difficulties or depressed blood problems:
hackerb9 member for over 9 years hackerb9 2 comments
over 9 years ago
Here's a better way to make a pencil drawing from a photo. Download the G'MIC plugin for the GIMP. Go to Filters -> G'MIC. In the list of filters, open up the "Black & White" section. In there, click on "Pencil portrait". Click OK. Wait a while as this can be CPU intensive, but the results are worth it. I've attached an image with the default parameters.
By the way, I shouldn't have been so harsh in my previous post. This article isn't "useless"; it actually does a good job of demonstrating how Difference of Gaussians edge detection works.
over 9 years ago
This tutorial is useless as the exact functionality (making a copy, blurring it, subtracting) is already builtin to the GIMP: Filters -> Edge-Detection -> Difference of Gaussians.
If you set the smoothing radii in the dialog box that comes up to 4 and 0, you get exactly the same effect. I'm attaching a picture so you can see.
The article mentions that the technique works "without edge detection", which makes me think that the author accidentally reinvented DoG edge detection not knowing that it was a standard function. Kudos to them, and it's kind of neat to see it done by hand, but it's not necessary.
unknown
over 9 years ago
Nice!!!!!! REALLLY good tutorial!!!!!
mynamegoeshere
about 11 years ago
Awesome!
0832
about 12 years ago
Great article!
As for the final step, I tried mask. This is the result. I am not good at it. http://i.imgur.com/n1oxHhS.png
Then I tried Free Select Tool and added 2 black layers. I change the opacity of the layers. Select / Feather, value: 30, Edit / Clear created the blur area.
http://i.imgur.com/pQmog5w.png
Ashok Koparday
about 12 years ago
Hi devv,
I appreciate this style of doing line drawing.
I however haven't understood step 7.
If someone can clarify I will be glad.
Thanks for teaching your beautiful art,
Best
Dr. Ashok Koparday
Joe
about 13 years ago
Very good article. This is the way to go for a quick digital drawings. I still prefer the old-fashioned hand-drawn method... http://www.photostodrawings.com
Aparna
about 13 years ago
Can u please provide me the video for above pencil sketch conversion
vijenthan
over 13 years ago
i like this softeares
FATj2112 member for over 13 years FATj2112 3 comments
over 13 years ago
Yes,this is good,it would be a bit better if the screens displayed were in English!
The text was....
Peggy
over 13 years ago
anmol.zia
over 13 years ago
nice....!!
quincy
over 13 years ago
cool
Paul Sauve
over 13 years ago
This is the best technique I,ve seen so far for making line drawings.
Thank you
sana rani
over 13 years ago
i kile this drawing.
Daroo
over 13 years ago
Thx
over 13 years ago
Sujtih: I updated the last step. Hope that helps you in achieving the transition effect ;)
Sujtih
over 13 years ago
i had almost finished it.. I wanted to make a pencil draw effect.. this tutorial was nice.. And by viewing this article, i went to do that exactly with the same pic.. But, as i am new to GIMP, i cant get the last part.. "On my image I have applied a layer mask over the line drawing so there is a transition between photo and line drawing."
Can anyone brief with steps how that effect can be achieved???
Shannon
about 14 years ago
It's even simpler than the other commenter said now, re: Artistic->Predator filter
1) duplicate layer,
2) desaturate
3) Predator filter, no pixelize
4) Colors->invert
surya
about 14 years ago
nice work......
HearPump member for over 14 years HearPump 1 comment rated this topic with 2/5
over 14 years ago
there is a much more simple way to do it in 2 steps:
1- Filters->Artistic->Predeator
2-Filters->Edge detection->Sobel
Features:
1- you get the drawing on an alpha channel allowing you to put any background you want.
2- To change line opacity just use layer opacity from the layer window
And your done :) ....Hope u loved it
Nathan Yap
over 14 years ago
How do i make the line more clearer? gimp newbie here
stratus
over 14 years ago
Nice tutorial. Just to clarify the STEP 2. after duplicating the layer, you have choose the duplicated layer "Background copy" in the layers dialag. If you don't see the Layers dialog, then click ctrl-L to see the dialog; then highlight the "Background copy".
To apply the desaturation, you have to use Colors->Hue-saturation dialog. Not colors->colorize. Colors->Colorize does not show the dialog as you see in the step 2 picture.
Have a nice art!
Sarah Robbins
over 14 years ago
Worked great! The first layer barely showed up, but when I added a few multiply layers, it came out really nice.
dufus member for over 14 years dufus 2 comments rated this topic with 5/5
over 14 years ago
Great tutorial! Thanks! Short and simple with tremendous results.
Anonymous rated this topic with 5/5
about 15 years ago
That was really good. My lines turned out too light, so I increased the contrast. It turned out sort of grainy, though.
superdit rated this topic with 5/5
over 15 years ago
hey thanks for the tut, it very easy to implement
over 15 years ago
in the layers dialogue right click on the layer that has the line drawing: "Add layer mask" (select white in the popup dialog). there will now be a new layer right beside the layer now in the layers dialogue. it will be fully white. click it to activate it. this is the so called mask -> you can only draw black and white and gray tones. then take the gradient tool, set FG and BG color to black and white and drag a gradient from (i.e.) left to right. then the part that is black on the layer mask becomes (semi)transparent.
hope that helps ;)
Jabba rated this topic with 5/5
over 15 years ago
How did you do that? Could you explain that part step by step? The end result with the half pencil image is pretty cool.
rejith rated this topic with 3/5
over 15 years ago
how to change image to pencil drawing in photoshop7?
Sandra rated this topic with 5/5
over 15 years ago
I am an absolute beginner but desperately need to be able to do this exact thing for an important project. I've downloaded the progam and followed each step, but each time I try, at Step 4 it all goes to pot. How do I set value 4 to the selective gaussian blur? I've tried dozens of times - I can even get all the way to setting the duplicated merged layer to 'dodge' but what I end up with looks nothing like a pencil drawing! It's getting close to 'banging head on the desk' time so can someone PLEASE tell me what I'm doing wrong?
Ibnu Zain
over 15 years ago
Great! Awesome! Thanks for the tutorial. I never guess that effect will be as easy like that :D thanks for sharing.
Raymond
over 15 years ago
I like What Ive learned so far and I have Archived a lot by using gimp please notify me when new things are out on gimp THANXX!
Anon
almost 16 years ago
If you go to Wondows/dockableDialogs/Layers the second thing from the top is Opacity and you can just slide it to 50%... you can also use the box to change the mode and create a duplicate layer
Thanks for the tut
matteob8
about 16 years ago
Very nice tutorial. I'm using Gimp 2.6.3 and there's some minor differences in the dialogs, e.g. in the "Selective Gaussian Blur" there 2 parameters "Blur radius" and "Max Delta". I made some experimentation to find a good result.
Bye
Karen
about 16 years ago
How do I change the opacity to 50% on gimp2.6
Mark
over 16 years ago
No comment. Just thanks for the great tutorial.
claudegals
over 16 years ago
Great tutorial... Keep up the good work...
kdroxx member for over 16 years kdroxx 2 comments
over 16 years ago
My image turned our very good.
But can someone tell how to keep half of it in colour ??
over 16 years ago
Moku
over 16 years ago
I have the same problem as blackrain. Though I have experienced that following your steps sometimes results in something different (XD) and I have to alter the steps sometimes - but in the end, it would always work.
By the way, blackrain option two you will find under hue something, but not colorize in 2.6.
So, my problem is step four. I tried to trick this effect with a bumb map and some other stuff. It still wouldn't work. I feel stupid, for not getting that one right, because it's one of the easiest I've read so far. ~.~
Thanks
Moku
ShockwaveLover member for over 16 years ShockwaveLover 7 comments
over 16 years ago
This is an awesome tutorial. For those asking, Opacity can be changed via a slider in the Layers, Channels and Paths Toolbar (the one with the gradients and colours on it)
Adrian
over 16 years ago
Excellent tutorial - thanks! And thanks to devv for pointing out where to find "dodge" - sich things not always obvious to the newbie!!
josh
over 16 years ago
I can't figure out how you change the opacity to 50% on gimp 2.6
nick
over 16 years ago
the toolbar that has the copies on it it doesnt show up! why?
nick
over 16 years ago
how to do you change the opacity to 50%?
sandyroyale
over 16 years ago
Thank you, that was exactly that i searched !
ño
over 16 years ago
excellent tutorial! thank you ^^
isthur
almost 17 years ago
trim's tutorial gimp nya
Victor Ramirez
almost 17 years ago
Hi, good tutorial, congratulations. I've experimented a bit and increased yellow in color balance, previous to desaturate(don't know if makes difference), and substituted selective gaussian blur by "focus blur" value of 8. The results are pretty good and the lines are more thick.
Can this proccess be automated as a script fu?
Anders
almost 17 years ago
Hi. Have get the plugin pencil-drow..for gimp.How do i install it i the program?
joshuam
almost 17 years ago
im new o gimp and dont know how to change the layer opacity. Can someone tell me please
GameCreator member for almost 18 years GameCreator 9 comments
almost 17 years ago
It would be good effect if used with some trick to flatten colours. Then it would look like coloured sketch or watercolour ;)
Guillermo Maldonado
almost 17 years ago
Have you tried edge detection, I think it works a bit cleaner and the traces are better.
Good tutorial though.
Regards.
almost 17 years ago
it should work definately. the technique is using only very basic things such as layer modes. i dont think 2.6 has changed something here
blackrain
almost 17 years ago
can this tut work in gimp 2.6.0? cause, i've tried it and it dosen't work...
almost 17 years ago
in the layers dialog look above the opacity/transparency ruler. there is a dropdown called "mode"
tyler
almost 17 years ago
how so you change the layers mode..i dont know how to do that..
about 17 years ago
take a picture of yourself. use a bright / white background and apply the steps shown in the tutorial!
jonesrachael member for about 17 years jonesrachael 1 comment
about 17 years ago
how do i make this for my self?
Beaniebaby2468 member for over 17 years Beaniebaby2468 5 comments
about 17 years ago
Cool effect. :) Would you be able to make a tutorial on blending two images together?
