Tutorial: Create futuristic looking tech pattern
          Create a new image: 640×480 px. The Background should be plain white. Now choose Filters / Render / Clouds / Plasma. Take these values: 10.000 / tubulence: 7
          Go to Colors / Desaturate: Brightness and choose OK.
          Now we’re giving our pattern the special look which it will have at the end. We’re using the Dilate filter, a very simple filter that smallens the dark areas in an image. Don’t be confused if you look at the quick description when hovering the entry in the filter menu – I think currently in Gimp 2.4.4. this is a wrong description. Choose Filter / General / Dilate. After this repat that filter 30 times. Use CTRL+F to repeat the filter quickly.
          Got to Filter / Map / Make seamless.
          Sharpen the picture now using Filter / Enhance / Sharpen: ~85. Now we’re giving our picture some color: Use Colors / Color Balance
 Shadows: -50 | 30 | 30
 Mids: 0 | 30 | 50
 Highlights: -65 | -40 | 20
        6
          If you zoom into the image very closely you’ll notice some gradients that are not very nice looking.
        7
          To get rid of this we use Filter / Blur / Selective Gaussian Blur. Values: 5 / Max Delta: 13
        8
          Now we want to have some cool glowing edges so that everything look really future style like. Zoom back to 100% (do this fast by clicking the “1”-key). Click “duplicate layer” in the layers dialog or just use the hotkey: CTRL+SHIFT+D On the duplicate use Filter / BLur / Gaussian Blur: 10. Set the layers mode (directly above the opacity ruler in the layers dialog) to “Lighten only”.
        9
          Thats all, we are finished! The softer result is in the left part of the picture below. Option 1: If you want your edges to be sharper and more clearly looking use Filter / Enhance / Sharpen (40/50) again on the background-layer. Option 2: If you want the whole picture a bit darker (less white glow and more saturated colors) simply create a new totally black layer above all layers and set the layers mode to “Overlay”. Have fun with this ;) Hope you enjoyed this easy tutorial.
This topic (Create futuristic looking tech pattern) has been rated 5.0/5.0.
