Tutorial: Exploding Planet
Written by , translated by Paraknight · Created on Dec 09, 2007, last updated over 13 years ago CC BY-NC License
Various special effects are just there to get to know some techniques that you might need once. The result of this tutorial will probably not be further used, but it still looks cool ;)
    Like some others, this tutorial is an implementation of an existing Photoshop tutorial.
    Create a new image (700px * 700px) with a black background colour.
    Download the attachment to this tutorial (right), open the JPG and copy the cracked soil (ctrl+c) into your new GIMP-File onto a new layer. Press CRTL+T to transform and type in 700×700 pixels. Now move the layer into the middle, so that everything can be seen.
    Optional: To achieve an exact positioning, you can also use the alignment tool. Click the tool, click on the layer with the cracked soil. Now go to: “Relative to:”. Then click the icon for the horizontal and vertical middle each once – your layer should now exactly fit in the size of the image!
    Now, stretch the active layer on a ball: Go to Filters / Map / Map object and select “sphere”. See the settings in the picture below. In the “light” tab select: No light.
    Invert the colors (Color / Invert). You will get a blue and white sphere:
    We will now add the exploding rays. For this we first need the sphere streched on the layer: Filters / Distorts / Polar coords. Disable the bottom-right checkbox “To Polar”. Click OK.
    Then go to Image / Transform / Rotate 90° CW.
    Click Filters / Distorts / Wind with the values:
    Wind
    Direction: Right
    Edge affected: Leading
    Threshold: 5
    Strength: 37
    Use the filter again by pressing CTRL+F.
    Now we must undo the stretching from before to get our sphere:
    - Turn the Layer by selecting Layer / Transform / 90° CCW. It should now be on the top side.
    - Now select Filters / Distorts / Polar coords. Check the box for “To Polar” again.
    Then it looks quite cool. Take the Select Eliptical Regions tool (Key E) make a selction around the planet – invert this and cut the white edge away.
    After that go to Select / None to make the existin selection dissappear.
    Press CRTL+B to make the tool window appear – then L to activate the Gradient tool. Search for the gradient seen on the picture.
    Turn it around and go to Colors / Map / Gradient Map and you have your exploding planet!
    Optionally, you could duplicate the planet layer. Soften this layer with the value 11, turn the transparency of the layer to 65% and change the layer mode to “screen” or “color”. Thus, it reached a little more color intensity and softer transitions. Have fun with it.
This topic (Exploding Planet) has been rated 4.7/5.0.
scarfish
almost 12 years ago
I guess the other commenters are smarter than me. It took me a few minutes to realize on step 9 you just meant to reverse the gradient. Cool effect and process. Thank you.
Todo Gimp
almost 13 years ago
Hi devvv
I've created a spanish version of you tut
http://www.todogimp.com/?q=general/explosion-de-un-planeta
Thanks
hanxiong
about 13 years ago
Mine is here:
http://hanciong.deviantart.com/#/d3aycjv
hanxiong
about 13 years ago
Why don't you use Filters -> Light and Shadow -> Apply Lens in step 3? I think the result is more realistic that way.
ghornicule rated this topic with 5/5
almost 14 years ago
I just think gimp is fantastic all the way around.Your work is incredible.
bananalover rated this topic with 4/5
almost 14 years ago
mine looks pretty cool, but i dont get the yellow flare in the cracks of the planet... any ideas why?
Someguy rated this topic with 5/5
almost 14 years ago
I found something cool.
Do not use the given image, instead create a new layer, it should have equal width and height.
Fill this with the pattern 'Dried Mud.'
Follow the tutorial, but DO NOT INVERT COLORS EVER.
You'll get a cool looking Sun. Enjoy~
Shelby
almost 15 years ago
oh and that soften with value 11 thing I figured was a gaussian blur. i feel stupid now xD
Shelby
almost 15 years ago
Shelby
almost 15 years ago
I figured it out, when you do the coloring with color/map/gradient map you have to have the blend mode on burn not normal. at least thats what I did to get it to look darker. Before my planet was too bright and didnt look quite right.
Shelby
almost 15 years ago
At the end where it says:
"Optionally, you could duplicate the planet layer. Soften this layer with the value 11, turn the transparency of the layer to 65% and change the layer mode to "screen" or "color". Thus, it reached a little more color intensity and softer transitions. Have fun with it."
How do you soften the layer with the value 11?
Darlingpresley member for almost 15 years Darlingpresley 9 comments
almost 15 years ago
woaaahhhhhhh love it :)
Breil
almost 15 years ago
Mine's not a sphere,instead it's a chunky planet and I do this in GIMP v. 2.6.6(the 2008 version)
xandercm member for about 15 years xandercm 1 comment
about 15 years ago
Great tutorial! I combined this with the Star field tutorial and modified the planet to a mirrorball.
RikarduJ
about 15 years ago
Hm...in step 2 i press Ctrl+T and i can't do anything that says and i even search for gimp tools for it (im a begginer)
Please help me!
FELIXnx01
over 15 years ago
Thank you very much. This is the first tutorial I posted for a forum and there where some problems because I haven't posted the credits. I'm going to insert the autothor's name and the link to this tutorial. The URL of the translated tutorial is this:
http://gimpworld.forumfree.net/?t=35345596&st=0#entry291808448
The Tutorial is an image but don't worry, there's a link to the homepage of this site.
Thank you very much. If there are some problems please write and I'll do my possible.
"Long life and prosper!"
redforce member for over 17 years redforce 230 comments
over 15 years ago
FELIXnx01, of course, please just mention the author's name (devvv) and a link to this page, according to the license. If you tell us the URL of the translated tutorial, I will add it to the "Available in other languages" list.
FELIXnx01
over 15 years ago
Can I translate this tutorial for an italian gimp based forum?
Rafi member for over 15 years Rafi 1 comment
over 15 years ago
Nice tut........keep em commin
Zeratul554 member for almost 16 years Zeratul554 1 comment
almost 16 years ago
i loved this tutorial and used it on my homepage i also used a bluish gradient it looks real cool
amy
almost 16 years ago
"Filters / Distorts / Polar coords. Disable the bottom-right checkbox "To Polar". Click OK."
this box was already checked for me but i tried it anyway and when i clicked ok it just gave me a weird curved semi circle
matt
about 16 years ago
How do you soften in gimp 2.2
paulseph
about 16 years ago
but other than that this rocks, im very pleased with the result thanks :)
paulseph
about 16 years ago
similar to lolzlolz below
paulseph
about 16 years ago
I found that that last invert on step 8 is not necessary, in fact the result of that made it look like a weird dark red cracked ball w/o the exploding effect.
devvv member for over 17 years devvv 1475 comments
about 16 years ago
i've corrected it! thanks. gradient map is found in the base colors menu not in filters / colors.
Colors / Map / Map gradient
Arbiter
about 16 years ago
With the last step. There is no Map gradient option in gimp 2.4
What do you think could replace it.
Ztoph member for about 16 years Ztoph 4 comments
about 16 years ago
Can U do this on a human, or another object??
anuja
over 16 years ago
simple and very realistic effet.
over 16 years ago
it was an error, i corrected it already ;) thanks!
lolzlolz
over 16 years ago
no its supposed to go right i think
maybe not
Koantig member for over 16 years Koantig 1 comment
over 16 years ago
Cool stuff. In step 6, the direction of the wind should be 'right' not 'left' though.
over 16 years ago
the image needs to be square, and in step 2 make sure the layer that contains the soil is also exactly square. you can try Layer / Layer to image size.
Mike
over 16 years ago
My mapping comes out ovalish... not a cirlce.
lexor
over 16 years ago
he didn't make it, he found it online lol
backdrop001
over 16 years ago
I'd actually would like to know how to make that soil pic you had us download, that would be perfect for something i'm trying to make in gimp, is there a tutorial for that?
lolzlolz member for over 16 years lolzlolz 2 comments
over 16 years ago
nvm working now
over 16 years ago
there's no gradient that matches that color, so i have a weird result that doesn't have the same color,
any ideas?
thanks
Justine
over 16 years ago
How to make the screen black?? lols
LukasT
over 16 years ago
I just love this site :) Cool tutorial
over 16 years ago
Thanks to Paraknight for translating this tutorial from German to English!
