Tutorial: Stylish buttons
Written by · Created on May 25, 2007, last updated over 13 years ago CC BY-NC License
Stylish buttons
Buttons are pretty nice for many things in the web. As long as you dont use them too much they can give your website a good look. In the following tutorial, we're going to make some cool and stylish looking buttons. At the end you can colorize them with a very simple technique.
    Open a new file. 120×30px. Black background.
    Create a new transparent layer.
    - Selection / All (or just press CTRL A)
    - Selection / Shrink: 3px.
    - Selection / Rounded Rectangle.
    Now choose any fore- and background-color you like. i.e.: FG #ab6000 and BG: #f88c00. Fill this new layer with the standard gradient. (Take the Gradient-Tool and draw a gradient from top to bottom), so that the brighter color is seen at the top.
    Still let the selection active! Create a new layer, fill it totally white. Go to Selection / Shrink: 1px and remove the selected part. A 1px border should remain.
    -Selection / None
    In the layers dialog set the layers mode to “Soft light”. Transparency / Opacity to 60%. The layers look like this now.
    Now choose the Text-Tool (T). Write any text you like, choose white as color for this text.
    Move the text a little to the right and choose the paths-tool (B).
    - Add a new empty layer.
    - Do a path as seen in the picture.
    You can end the path while holdig CTRL down and clicking the point of your beginning.
    After that press ENTER to become a selection out of the path. Fill this selection with any color brighter that your background. I.e.:##ffcb4b.
    - Selection / None to get rid of the selection.
    Duplicate the layer and move the duplicate a little bit to the right.
    Now we’re doing the glossy part of the button.
    Activate the colored gradient layer. Right click it in the layers dialog and choose “Selection from Alpha”. Click the layer at the most top – then add a new layer on top of it.
    - Selection / Shrink: 1px.
    - Press L to active the Gradient-Tool.
    As gradient choose the 4. one from the drop down menu (named “Color to transparent”). Click in the top are of the button and move your mouse a little to the bottom. When holding CTRL while drawing the gradient it helps you to get an exact horizontal gradient.
  11. 11
    Now if you want you button in any other color do the tutorial again, haha. Damn no, I’m just joking ;) If you want to test some other colors do this:
    Above all layers create a new empty one, fill this layer with the color you want to test. Select “Color” in the layers mode drop down. And instantly your buttons color has changed. You can also try gradients!
    Tip: You can only use the base color tones. Fades to grey don’t have any effect.
    Your buttons could look like this:
This topic (Stylish buttons) has been rated 5.0/5.0.
trandoductin
almost 7 years ago
This is such a cool button. I scripted it to automatically quickly create a button.
https://www.gimplearn.net/viewtopic.php?f=3&t=677
devvv member for over 17 years devvv 1475 comments
about 7 years ago
Glad, you like it :-)
AllstarSeaworthyofNBC member for almost 8 years AllstarSeaworthyofNBC 4 comments rated this topic with 5/5
over 7 years ago
I made it. This is how i made it look like.
waynebunch member for almost 12 years waynebunch 1 comment rated this topic with 5/5
almost 12 years ago
Very nice, thanks for that.
Jay Trapella
almost 15 years ago
COOL
Alberto
over 15 years ago
Ok!^^ I think that i will translate it in march, anyway i'll write here when it's done, with the link too!
redforce member for over 17 years redforce 230 comments
over 15 years ago
Of course, we'll be glad if you translate the tutorial! As stated above, it is licensed by a Creative Commons license so you may use it for any non-commercial use as long as you credit this page. Please let us know the URL of the translated tutorial so we can put a link on this page.
Alberto
over 15 years ago
Hi! Congratulations for this tutorial^^ I followed it and i'm very satisfied!
Will you agree if i translate this tut for an italian gimp forum? Obviously i will credit this page! ;)
Make me know!
Amyk13 member for over 16 years Amyk13 5 comments
over 16 years ago
Yes! I did it, look at my button!
over 16 years ago
you could maybe enhance the glossy part when you mouseover the button ;)
click
over 16 years ago
I like it! But how would you make it look like it's being clicked?
AtenTora
over 16 years ago
Great tutorial. I did the gradient at the end from the top of the image not the button and down about 15px. I think it turned out well.
And Amyk13, set the color of the gradient to white, and use the FG to Transparency setting. Also, for me anyways, it's Alpha to Selection.
over 16 years ago
I don't understand stepp 10
