Tutorial: Make an explosion effect
Written by · Created on May 08, 2012, last updated almost 13 years ago CC BY-NC License
This tutorial demonstrates how to use GIMPs extremely powerful brush dynamics to create a cool explosion effect pretty easy.
    Create a new empty file with black background. Size can cary – I used 1024×768px.
    Next, create a new transparent layer. On it use the free select tool to make a small 4-edged selection – like mine seen on the image. Set FG color to white and go to Edit / Fill with FG color. De-Select all (Select / None)
    Use the rectangle selection tool and draw a selection around it. Press CTRL+C to copy this to the clipboard.
    Sidenote: With GIMP you can use the clipboard as an on-the-fly-brush. You can draw the clipboard contents using the paint tools.
    Now choose the Paintbrush tool. In the dropdown of the brush use the very first brush – this is the content from the clipboard you can paint with.
    After you set the clipboard brush set size to 170px. Open the dynamics options and in the gradient choose the Shadows 2 gradient. Also Check the Apply Jitter option and set it to 20.
    • Now go to Window / Dockable Dialogs / Paint dynamics.
    • At the bottom press the “Create new dynamics” button.
    • In the matrix that shows up choose the “Random” column and check vales in the rows for:
      • Size (varies the size of the brush based on the standard size you entered in the settings of the Paintbrush tool)
      • Angle (rotates the brush randomly now)
      • Color (takes a random color out of the colors that you have in the gradient you choose)
      • Aspect Ratio (shrinks, shears and disforms the brush)
      • Jitter (uses the jitter value from the settings)
    These paint dynamics are now active unless you set the “Dynamics off” in the Paintbrush settings.
    Go back to the layers dialog (or press CTRL+L to make it show). Click the eye symbol to make the layer invisible. Creat a new transparent layer and paint on the canvas (in the center) to create the base of the explosion.
    Next set the size of the brush to 370 and paint some bigger parts at the sides.
    Now go to Filter / Blur / Motion blur. Set “Zoom” and use a length of 30 and apply it.
    Create a new layer. Go to Filter / Light & Shadow / Supernova. Set the nova to the center, choose a light orange-yellow color and the values Radius 50 / Spokes 180 / hue 0. Then apply the almost same motion blur again but with 200 length. Then blur the layer using Filter / Blur / Gaussian Blur: 15px and set the layer mode to Screen.
    Rightclick the top layer in the layers group and choose “New from visible”. On it apply a slight S-curve in Color / Curves to higher the contrast a bit.
  10. 10 colorbalance_explosion.txt
    Now go to Color / Color balance.
    Shadows: 0 / 0 / -5
    Midtones: 5 / 0 / -10
    Highlights: 0 / 0 / 0.
    Alternatively right-click the file (attached to this step) and save it. Then import it in the Color balance dialog at the top right.
    After that apply Blur / Motion Blur: Zoom, 15px lenght and you’re done ;)
    Hope you enjoyed it!
This topic (Make an explosion effect) has been rated 5.0/5.0.
krystian
almost 5 years ago
Thank you so much, a fantastic tuto, with I learn a lot of things
Yoshi
almost 9 years ago
Thank you it's very useful
imagemturbo.com
almost 12 years ago
Great tutorial!
dthomas731 member for almost 15 years dthomas731 1 comment rated this topic with 5/5
almost 13 years ago
Fantastic tutorial. I "changed" it up a bit.
almost 13 years ago
it is a new feature of GIMP 2.8 - so it is not available in former versions like 2.6.x
corona radiata
almost 13 years ago
I can't find paint dynamics in window > dockable dialogs.
Using gimp 2.6.12
bindesh
almost 13 years ago
Simple and sweet :-), animation with blur is quite useful in Games.
Coche member for almost 16 years Coche 13 comments rated this topic with 5/5
almost 13 years ago
pretty cool devvv!
